Welcome to the North American Subaru Impreza Owners Club Sunday October 13, 2019
Old 09-28-2014, 11:29 PM   #226
galaske25
Member#: 402351
2000 impreza 2.5 rs
white
love the organization man, great thread and very helpful
galaske25 is offline   Reply With Quote
Old 10-01-2014, 03:20 PM   #227
bilbo93
Member#: 317073
very helpful
bilbo93 is offline   Reply With Quote
Old 10-16-2014, 11:47 PM   #228
99 rs
Member#: 100994
2005 Acura NSX-T
2002 IS300 Wagon
Spotted the new owner tonight (3rd after me). Car still running strong, all electrics work, no check engine lights, no faults he said. The body is starting to show its age but overall, everything still functional!
Old 12-22-2014, 10:58 PM   #229
silentt
Member#: 119995
2004 Outback XT
Peachy
When did the car pull a Michael Jackson?
silentt is offline   Reply With Quote
Old 12-25-2014, 07:55 PM   #230
Suby_T_Rex05
Member#: 365954
Default Swap gone wrong
I purchased a 2001 Impreza RS with a 2004 WRX swap already started. There is something wrong with the wiring, because the engine light is on, and says that the cylinders 1 and 3 misfire, then I'll get a code down the line saying cylinder 2 and 4 misfire. When I unplug the MAF sensor, the car runs better and doesn't bog down, where as when I have it plugged in, the car loses almost all power, no spool, and has a terrible misfire. I've replaced the MAF, IACV, Oil Breather cover on the right side valve cover, wastegate actuator, PCV, and I noticed I have a large amount of gas getting in the oil with the misfire and loss of power. I'm hoping this information can possibly make it so you can come up with some ideas of what I can look for.
Suby_T_Rex05 is offline   Reply With Quote
Old 02-12-2015, 08:24 PM   #231
nasiocjunkie
Member#: 80864
I'll have the tuna.
No crust.
Originally Posted by Brydon View Post
Addition Wiring on the 2002 WRX harness:
Injectors/Ignition needs switched 12volt Power
Can you point me in the right direction as to how to wire those with 12 vdc power thanks. I'm stuck in the water with a conversion I'm doing 00RS w/ 02 wrx motor swap.
nasiocjunkie is offline   Reply With Quote
Old 05-12-2015, 03:51 AM   #232
Flameworker
Member#: 420711
1999 outback sport i
green
Well done, excellent documentation! I was going to piecemeal parts from this and that, you have inspired me, I'll try n find a similar donor to mac my 99 outback sport. Thanks
Flameworker is offline   Reply With Quote
Old 09-23-2015, 03:23 PM   #233
Zendeta
Member#: 430735
I want to swap soon, I found an engine and trans for sale that I might pick up soon. This looks absolutely terrifying. I WANT to do the swap, but I also don't want to mess anything up horribly.
Zendeta is offline   Reply With Quote
Old 11-30-2015, 03:25 PM   #234
Outbacksti3273
Member#: 435263
2006 Impreza WRX STI
Default Nice work
Cool swap.
First thing was to strip down the WRX. I have no pictures of this as it was done in haste over the Christmas break between university semesters. For those that remember my old RS engine I had the intake manifold, valve covers and radiator tubing powder coated red. I wanted to do the same thing for this engine. So the engine disassembly:
TD04 turbo.
Outbacksti3273 is offline   Reply With Quote
Old 12-02-2015, 04:58 PM   #235
ibinyth
Member#: 435403
nice pictures
ibinyth is offline   Reply With Quote
Old 01-29-2016, 03:33 AM   #236
FlammableCash
Member#: 437274
This is basically what I want to do to my 01 Impreza OBS
FlammableCash is offline   Reply With Quote
Old 07-26-2016, 07:05 PM   #237
Raggamuffin96
Member#: 387053
This is a very well done build! Respect for all of the pictures, I know that takes time.
Raggamuffin96 is offline   Reply With Quote
Old 09-26-2016, 10:33 AM   #238
ale_caus
Member#: 385380
great job !!
ale_caus is offline   Reply With Quote
Old 09-26-2016, 10:35 AM   #239
ale_caus
Member#: 385380
Old 05-25-2017, 12:23 PM   #240
ryanalfaro
Member#: 427649
'01 Impreza RS
Silverthorn Metallic
I've just completed the leg work of this swap on my own car but my injectors are only getting 6V rather than 12. Is this the result of a bad ground?
ryanalfaro is offline   Reply With Quote
Old 11-09-2018, 09:37 AM   #241
Nsethadams
Member#: 493792
Default Extremely helpful
Will be doing a 04 sti swap on my 1998 this was super helpful and fairly detailed.
Nsethadams is offline   Reply With Quote
Old 02-28-2019, 06:23 AM   #242
Dave1513
Member#: 498393
Default 🤔
Iíve been thinking about attempting a wrx swap to my 99 gf8, I have a whole drivetrain from a 05 wrx, butbfrom what I read I can only use bugeye swap??
Dave1513 is offline   Reply With Quote
Old 02-28-2019, 01:00 PM   #243
nasiocjunkie
Member#: 80864
I'll have the tuna.
No crust.
Sounds like you have more reading to do. You can swap other turbo model subaru's into your RS ie wrx, sti, and legacy gt's. Motor, trans, rear dif, matching axles, complete wire harness with ecu, iWire service if you need to merge wire harnesses, fuel pump regulator, and ALL ENGINE BAY MOTOR SENSORS is the majors that you will need. Good luck with that swap you should post a conversion thread for that when you are done.
Old 03-02-2019, 08:16 PM   #244
99 rs
Member#: 100994
2005 Acura NSX-T
2002 IS300 Wagon
The 2005 drivetrain you have will work just fine. Do you have just the drivetrain or the whole car? You'll need the rest of the stuff that nasiocjunkie mentioned as well.
Old 03-20-2019, 05:03 PM   #245
_HKD_
Member#: 491739
2001 2.5RS
Default 01 RS to 02 WRX Swap
I have been studying your conversion project that you had performed several years ago and I really appreciate the work you did!
I apologize in advance if I have missed some things on your forum that could answer my question below.
Background: I currently own a 2001 2.5RS 2 door manual and came upon a wrecked 2002 WRX automatic car (complete) with only cosmetic damage.
Question: I'm just about done taking out the entire harness from the WRX and about to begin removing the harness from the RSóany suggestions as to how to merge an automatic WRX wire harness to a manual RS harness?
I plan to use my current RS manual transmission with an upgraded clutch to bolt onto the WRX motor.
_HKD_ is offline   Reply With Quote
A complete n00b's guide to changing the oil in your WRX (with pics!) perret318 Service & Maintenance 153 11-28-2013 01:17 AM
STi parts needed to complete kit, look inside RiSti05 Private 'Wanted' Classifieds 22 05-12-2009 04:00 PM
4EAT to STi gas pedal wiring guide Lamont Transmission (AT/MT) & Driveline 0 11-28-2008 11:38 PM
GC RS to USDM WRX/STI wiring guide aspect Subaru Conversions 3 06-30-2008 11:12 PM
HELP-Need to find a wire for switched 12V inside the cabin....anyone know? dchou Electrical & Lighting 2 02-07-2007 09:13 PM
