Welcome to the North American Subaru Impreza Owners Club Tuesday October 22, 2019
Old 07-30-2014, 06:34 AM   #2501
vicious_fishes
Member#: 158864
2003 SOHC destroker
EZ's are better balanced than EJ's too so... it's a non-issue.
vicious_fishes is offline   Reply With Quote
Old 07-30-2014, 06:42 AM   #2502
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Before I keep forgetting further... Anyone interested in an untouched Link G4 harness? I bought I brand new for trade with a friend who bought my Link before realizing he should just do a 207 in his car with a USDM ECU. So I got the unit off him and he had gotten it off a Legacy with a 3.0L so I already have a pre-wired loom to use. That means... I have an extra one... Figured someone might want a back up oright find a used Link and want a fresh harness to do. Let me know!
Seraphinwolf is offline   Reply With Quote
Old 07-30-2014, 11:23 AM   #2503
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Originally Posted by Seraphinwolf View Post
Before I keep forgetting further... Anyone interested in an untouched Link G4 harness? I bought I brand new for trade with a friend who bought my Link before realizing he should just do a 207 in his car with a USDM ECU. So I got the unit off him and he had gotten it off a Legacy with a 3.0L so I already have a pre-wired loom to use. That means... I have an extra one... Figured someone might want a back up or might find a used Link and want a fresh harness to do. Let me know!
Got a pic? I know the G4 and the V88 (which is what I have) are supposed to be the same thing in different packaging, but I might be interested if it looks like it'll work for me.
Old 07-30-2014, 11:37 AM   #2504
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Yeah man I'll message you when I get home.
Old 07-30-2014, 06:02 PM   #2505
Seraphinwolf
Member#: 150922
97 OBS EZ30R
We REALLY need to see if the EZ pulley matches the F motors...
Old 07-30-2014, 07:27 PM   #2506
vicious_fishes
Member#: 158864
2003 SOHC destroker
way ahead of you. it doesn't
the only OTS pulley for ez's is some weird obscure thing from japan that's only advertised in yen. was on one of the legacy forum threads way back when they tried to get a big enough group buy for an existing pulley manufacturer to make one. never got enough (had 15 iirc, needed 30).
if you were to make them you'd certainly sell a couple dozen pretty quickly i reckon.
Old 07-30-2014, 07:41 PM   #2507
Seraphinwolf
Member#: 150922
97 OBS EZ30R
See that's what would shoot the price up... :-/ But we 'll see. I want it and other things made, so it'll likely happen. Even if just as a test/sample piece on my car.
Old 07-31-2014, 10:30 AM   #2508
phil.greiner11
Member#: 388081
2004 H6 STI
What else did you want to make? I have pretty good facilities and I am decent at fabrication I might be able to make some of it including the pully.
phil.greiner11 is offline   Reply With Quote
Old 07-31-2014, 10:42 AM   #2509
Seraphinwolf
Member#: 150922
97 OBS EZ30R
I'm pretty well covered at the shop and handy with fabbing stuff myself too. Thanks though. Mostly some first gen specific stuff and a few H6 specific things between the EG and EZ's
Old 07-31-2014, 11:00 AM   #2510
phil.greiner11
Member#: 388081
2004 H6 STI
Ok got ya well if you ever need anything just let me know I'm gonna be making most of my own stuff starting pretty soon. First thing is some beefy endlinks!
Old 07-31-2014, 01:46 PM   #2511
vicious_fishes
Member#: 158864
2003 SOHC destroker
i'm down for a lightweight/alloy crank pulley either way.
Old 07-31-2014, 06:13 PM   #2512
Seraphinwolf
Member#: 150922
97 OBS EZ30R
So guess what I did... I stopped at the shop since I needed to grab some stuff out of my car. So while I was there I dropped off the 3.0L pulley and talked about figuring things out. He'll start a general drawing and we can start making sure where there needs to be any tight tolerances for clearance of the timing cover and such.
Old 07-31-2014, 06:16 PM   #2513
Seraphinwolf
Member#: 150922
97 OBS EZ30R
So besides myself
Lowdown
Viscous
Phil
Pat you interested?
Anyone have a link to that LGT thread when they tried to get some?
Old 07-31-2014, 08:54 PM   #2514
vicious_fishes
Member#: 158864
2003 SOHC destroker
Old 08-01-2014, 02:54 PM   #2515
phil.greiner11
Member#: 388081
2004 H6 STI
Before I say yes your going to have to convince me that we def don't need a damper in it to take out vibrations. I heard of some weird/bad stuff happening to engines because they don't have one. Even the inline sixes which are just as well balance as the h6 need a dampener because of the forces on the crank shaft. This is all based on what I've heard/read so if anyone has any info id be very interested to hear it.
Old 08-01-2014, 03:14 PM   #2516
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Look at all the EJ Pulleys. Only the GrimmSpeed makes a dampened EJ one.
Old 08-01-2014, 05:33 PM   #2517
vicious_fishes
Member#: 158864
2003 SOHC destroker
ati or someone does a "superdamper" or however it's marketed. it's NOT cheap.
don't need it man. none of the EJ ones are and our engines are actually better balanced than the ej's.
Old 08-01-2014, 05:38 PM   #2518
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Horizontally opposed motors are pretty smooth due to their design and 6 cylinders balance that all out even more. EVO's and other in-lines will tend to run into issues pushing higher RPMs but now our motors.
Old 08-02-2014, 10:07 AM   #2519
Donutz
Member#: 148803
11 WRX 4dr
96 Impreza 3.6RS (EZ36R)
SOA was actually sent an email about this a few (well like 5 or 6 now) years ago and said the stock pulleys aren't harmonic dampeners. It's on here somewhere if you feel like fishing for it but you'll be fine without one unless you're making all the horsepower and feel like being overly precautious
Donutz is offline   Reply With Quote
Old 08-02-2014, 10:15 AM   #2520
phil.greiner11
Member#: 388081
2004 H6 STI
Ok yea I did some research and it looks like you guys are right so I guess I'm in. I just had to make sure. Let me know the price!
Old 08-02-2014, 12:02 PM   #2521
Seraphinwolf
Member#: 150922
97 OBS EZ30R
I'll keep people posted as soon as he starts the prototype drawing and can figure out materials and everything.
And as for the "unless pushing serious horsepower" at that point you are building the motor and unless you are being careless you have having the entire rotating assembly balanced.
Old 08-02-2014, 05:28 PM   #2522
RedMonkey999
Member#: 191476
2005 2.5RS
I'm in also. I said that ages ago, but I'm not on your list for some reason
RedMonkey999 is offline   Reply With Quote
Old 08-02-2014, 06:09 PM   #2523
Seraphinwolf
Member#: 150922
97 OBS EZ30R
So besides myself
Lowdown
Viscous
Phil
RedMonkey
Old 08-03-2014, 10:06 AM   #2524
OB2
Member#: 51500
1999 impreza rs-t
sylver
I just pass a rod on my EJ257 engine so I plan to replace it by a forged EZ30D engine.
The question is that I have the Vipec V44 of my old setup, and I want not buy an other ECU for fun! So do you think the V44 will be able to run the EZ30D engine?
OB2 is offline   Reply With Quote
Old 08-03-2014, 10:09 AM   #2525
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Unfortunately no. The V44 doesn't have enough built into it to run two more cylinders. Maybe ViPec will do an exchange or maybe they it Link make an extender to switch some other function into more cylinder controls?
Vag-Com cable resource thread cooleys04 Open Source Reflashes 283 04-03-2018 01:04 PM
The Impreza @$$ Thread - The Beautiful Impreza Backside! PICS! Upscale_Automotive Member's Car Gallery 8 10-03-2007 04:56 AM
The 2008 Impreza Photoshop thread...post them here adizon Member's Car Gallery 307 09-19-2007 11:36 PM
The 2006 Impreza/Impreza WRX/Impreza WRX-STi thread (merged thread) wrxpeed News & Rumors 938 05-16-2005 11:11 PM
Photo - Anders "loving on" the H6 Impreza Fred South East Region Forum 8 02-23-2004 05:04 PM
