Welcome to the North American Subaru Impreza Owners Club Tuesday October 15, 2019
Mid Atlantic Impreza Club
Old 04-12-2017, 07:41 AM   #3926
*Jay*
Member#: 112519
Ordered a set of Continental DWS for $90 each on closeout!!!
*Jay* is offline   Reply With Quote
Old 04-12-2017, 10:52 AM   #3927
VXSS
Member#: 115345
'18 FXT Touring
Annoying emissions day....
VXSS is offline   Reply With Quote
Old 04-12-2017, 04:27 PM   #3928
roccer
Member#: 113674
2006 WRX Limited
WRB, 358whp/387wtq
scheduled a timing belt replacement serving for the ol' WRX and ordered a new radiator and hose kits to go in just as a proactive measure.
now to find time to put the summer wheels/tires back on....
roccer is offline   Reply With Quote
Old 04-12-2017, 09:30 PM   #3929
96accord
Member#: 145105
2007 Impreza WRX STi
'15 Accord (Daily)
Pollen...
96accord is offline   Reply With Quote
Old 04-15-2017, 10:49 AM   #3930
j4k3
Member#: 262126
2007 STI
Originally Posted by 96accord View Post
Pollen...
My hood is damn near yellow. I kind of hope it rains pretty good today so it gets rinsed off.
j4k3 is offline   Reply With Quote
Old 04-15-2017, 02:09 PM   #3931
04fpgreensti
Member#: 151655
2012 STI Limited
I don't touch cars... I pay people to do everything for me.
Ftfy
04fpgreensti is offline   Reply With Quote
Old 04-15-2017, 10:19 PM   #3932
norcaltuna
Member#: 286686
2003 WRX EJ207 VF36
Re did a door
norcaltuna is offline   Reply With Quote
Old 04-16-2017, 12:12 PM   #3933
j4k3
Member#: 262126
2007 STI
What door speaker setup is that?
Old 04-16-2017, 01:09 PM   #3934
norcaltuna
Member#: 286686
2003 WRX EJ207 VF36
Hybrid Audio Legatia L8v2 in the door L3v2 on the dash : )
Old 04-17-2017, 06:03 AM   #3935
Trunkless
Member#: 441809
2007 WRX Wagon
Bled the clutch. What a pain.
Trunkless is offline   Reply With Quote
Old 04-18-2017, 09:30 PM   #3936
corona672
Member#: 262902
'04 WRX Hybrid
It's a wrap!
Did both front wheel bearings over the weekend, and redid the brake ducting (Rev 3). I give them 1.75 weekends.
corona672 is offline   Reply With Quote
Old 04-18-2017, 11:02 PM   #3937
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Is that a Vette brake duct? What's the part #, and what are the inlet and outlet diameters?
Old 04-18-2017, 11:10 PM   #3938
norcaltuna
Member#: 286686
2003 WRX EJ207 VF36
Gettin silly
Old 04-19-2017, 06:25 PM   #3939
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Originally Posted by Patrick Olsen View Post
- Adjusted the headlights a bit. I knew they were aimed poorly, but the other day I obscured the driver side one as they were shining at my garage door and I realized that what I thought was the bright spot from the passenger side headlight was actually from the driver side. Hmmm, guess those are more screwed up than I thought! My driveway isn't particularly level, but I adjusted the driver side down and left a bit, and got the passenger side aimed up higher, so that's progress. I park in a parking garage at work with plenty of level surface to work with, so tomorrow I'll find a dark corner where I can aim the headlights at a wall and fine tune things a bit. I also have higher wattage bulbs to play with - 55/100W and 90/130W.
- Adjusted the headlight aim after work one day last week in the parking garage. I didn't do it the "right" way - taking actual measurements - just eyeballed it against the wall of the garage. Much better coverage now.
- Installed the 55/100W bulbs this afternoon. I don't get a ton of opportunity to use high beams around here, but I'm curious to see how much of a difference it makes. I think I need to upgrade the headlight wiring with relays feeding power straight from the battery before I try the 90/130W bulbs.
Old 04-19-2017, 06:29 PM   #3940
corona672
Member#: 262902
'04 WRX Hybrid
It's a wrap!
Ya, C6 Z06. 15829066 and 15829067, can be had on ebay for <$35.
Ducts are on the car now but the wheel side is ~2.5" OD and the bumper side is 4" ID. I bought a 4" OD to 3" OD Silicone reducer for the transition, and just built up the 2.5" to 3". The reducer was sutured to the duct via zip ties, and the ducting snugged up into the silicon reducer - but I would use a 3" OD coupler next time.
I can snag a picture next time the tire is off. The mounting hole on the duct lines up perfect with the lower ABS hose 'U bracket' bolt. I'm on 245's, and I will still rub slightly at full lock- but better than anything else I've tried.
Old 04-20-2017, 08:08 PM   #3941
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Thanks. I have some similar parts that I used to make brake ducts for my CTS-V. Guy I got them from wasn't sure what the source was, and whatever part #s they may have had appear to have been ground off. What I have are bigger - about 5" inlet (which was even bigger before I cut them back a bit) and 4" outlet. I've never figured out what they came from.
Old 04-22-2017, 03:15 PM   #3942
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
- Replaced the trailing arm bushings in the knuckles with some poly ones from TiC.
I bought a set of 3-jaw pullers at Harbor Freight the other day, made quick work of pushing the old bushings out.
- Dismounted the tires on the 5-spoke RS wheels that came on the car when I bought it. The wheels are in pretty sad shape. Actually, the wheels are surprisingly good shape - little to no curb rash - but the paint is terrible. I'll clean them up and paint them in the coming weeks. Still debating whether I want to put summer tires on those, or use them next winter and put summers on the V7 wheels that I have on the car now (still on winter tires).
- Planned to do lateral links, too, but didn't come equipped to battle the long knuckle bolts. Those are going to take some work.
Old 04-23-2017, 09:21 AM   #3943
j4k3
Member#: 262126
2007 STI
Got a Cobb airbox for almost free. Now to get an inlet and afta-maf hose to clean it up a little.
Old 04-23-2017, 01:35 PM   #3944
corona672
Member#: 262902
'04 WRX Hybrid
It's a wrap!
I keep the bolt hanging up as a constant reminder that anything on the Subaru can be accomplished haha.
Made a fender cowl brace yesterday. Still working on welding skills, but improving.
Installed brake duct picture.
Old 04-23-2017, 04:47 PM   #3945
Very WRXY
Member#: 295615
2017 WRX Premium
Pure Red
Enjoyed some country back road spirited driving.
Ordered new plates.
Very WRXY is offline   Reply With Quote
Old 04-23-2017, 07:53 PM   #3946
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Didn't do anything on my car because mav1c forced me to work on his. Frickin' moderator abuse of power!
Old 04-23-2017, 07:59 PM   #3947
Barrett17
Member#: 383935
2012 WRX
Changed the wiper blades. Woohoo. Bosch to Goodyear.
Barrett17 is offline   Reply With Quote
Old 04-24-2017, 09:10 AM   #3948
Butt Dyno
Street's closed, pizza boy
Member#: 17301
2016 FoST ST3
2006 Evo #17 STU
Turned my Saabaru into a Subaru
Thanks to Lance/Hypnotk @ Fast Lane Collision.
Old 04-24-2017, 11:56 AM   #3949
roccer
Member#: 113674
2006 WRX Limited
WRB, 358whp/387wtq
sitting around while Mach V changes my WRX's timing belt. figure 10.5 years old. might as well before age catches up to it.
while they're at it, replacing coolant hoses with Mishimoto silicone hoses and the stock radiator with a Koyo before the stock decides to nuke its end tanks.
Old 04-25-2017, 03:37 PM   #3950
tramp
Member#: 459629
2017 WRX base
WR Blue
Picked my '17 up from the body shop after replacing the door some f*&khead hit a couple weeks ago and just drove off. Most people suck.
tramp is offline   Reply With Quote
