Welcome to the North American Subaru Impreza Owners Club Monday October 14, 2019
Old 04-01-2019, 04:11 PM   #8001
Mister_G
Member#: 499784
Originally Posted by Kami Speed View Post
Here are some! At stock height you should be ok with a 255/35 tire. But if you want to run 265/35 tires you will more than likely have to roll the rear fenders at least. We are a dealer of WedsSports wheels so if interested shoot me a PM and I can get you deal on these
They look great! Thanks for posting this, is the wrx on this photo on lowering springs or coils?
Mister_G is offline   Reply With Quote
Old 04-01-2019, 05:00 PM   #8002
Kami Speed
Member#: 96479
2006 WRX STI
Obsidian Black Pearl
^^ Eibach Lowering Springs.
Kami Speed is offline   Reply With Quote
Old 04-03-2019, 02:40 PM   #8003
akahenry
Member#: 401922
2018 STi
Has anyone fitted a 17x9.5 +38mm or 17x10 +38mm in an '18+ STi?
akahenry is offline   Reply With Quote
Old 04-07-2019, 06:55 PM   #8004
dpetro1
Member#: 487500
2018 WRX
Rota SVN 18x9 +40 with stock 245/40/18 dunlops. Lowered on Tein H-tech springs
Pretty mild setup, no rubbing or clearance issues, stock alignment specs.
dpetro1 is online now   Reply With Quote
Old 04-08-2019, 01:44 PM   #8005
bwilson7990
Member#: 443635
2018 WRX Limited
Lapis Blue Pearl
Default Stockers on OptionLab R716
Im lowered on RCE Yellows (stock struts) and currently running OptionLab R716s 18x9.5 +35 wrapped in the stock Dunlop 245/40/18s. Stock LCAs, aligned to -1.5 camber 0 toe in the front and a natural -2.0 camber 0 toe in the rear. I am about to get Firestone Firehawk Indy 500s in 255/35/18. I had a buddy that ran them with no issues on same spec wheels and suspension.
I really want to go 255/40/18 but don't want to roll fenders or modify anything else as it's just my DD and occasional AutoX-er. I'll post pics of the Indy 500s when they get mounted next week.
bwilson7990 is offline   Reply With Quote
Old 04-09-2019, 11:12 AM   #8006
SLO RU
Member#: 486037
2018 WRX
2018 WRX - Stock Suspension and no plans to change it because my driveway sucks.
I need new wheels and I was looking at the XXR 530D 18x9 +35
1) I should be able to run this wheel without issue, correct?
2) Would running the stock 245/40s be pushing it or should I definitely go with 255/35?
Thanks for any helpful info.
SLO RU is offline   Reply With Quote
Old 04-09-2019, 11:31 AM   #8007
Norm Peterson
Member#: 498642
'19 WRX Limited 6MT
'08 Mustang GT (the toy)
2) . . . 245/40s are tire industry OK'ed for fitment out to wheels that are 9.5" wide. Not "pushing it" at all to run them on 9's.
On edit, I'll let others deal with item #1. I try to stay out of the appearance side of wheel and tire fitment topics.
Norm
Norm Peterson is offline   Reply With Quote
Old 04-09-2019, 12:43 PM   #8008
bwilson7990
Member#: 443635
2018 WRX Limited
Lapis Blue Pearl
Absolutely without any issue. I am lowered 1" and running 245/40 on 9.5" wide wheels with same offset zero issues. Will look similar to my car above as far as fitment, but a little more fender gap, less poke, and definitely less stretched. I'd be willing to bet you could go 255/40 even without issues but don't quote me. I seriously considered going 255/40/18 on my 9.5" wide wheels but was worried about rubbing the rears being lowered and didn't want to modify anything further.
Old 04-09-2019, 12:57 PM   #8009
SLO RU
Member#: 486037
2018 WRX
Man, I looked through so many of the pages on this thread, guess I should have started from the last one, smh.
Thanks, I think I'll be happy with the results based off your car. I think I'll pull the trigger and order them tonight.
Old 04-09-2019, 04:02 PM   #8010
vlad11591
Member#: 295970
2019 STI
CWP
Thinking about running stock wheels with a set of RCE yellow springs.... My friend seems to think by running springs, that my shocks will be destroyed over time.... It's a 2018 WRX. Why would this be the case?
vlad11591 is offline   Reply With Quote
Old 04-09-2019, 04:33 PM   #8011
JRowland
Member#: 454620
2017 WRX
Red
https://forums.nasioc.com/forums/sho...postcount=1327
JRowland is offline   Reply With Quote
Old 04-09-2019, 04:50 PM   #8012
vlad11591
Member#: 295970
2019 STI
CWP
Originally Posted by JRowland View Post
thanks fam
Old 04-11-2019, 04:10 PM   #8013
seba112233
Member#: 498181
2019 WRX
Hi all, I'm a fan of the Gram Lights 57c6, older rim but I still see a few around and want to get them. I don't want to roll fenders so I'm thinking 18x8.5 +42.. it's my first time buying aftermarket rims so I wanted to know if my thinking is correct that these would not rub on a 0.8 to 1" drop. The offset is smaller than stock so I'm assuming they will be somewhat closer to flush than that but probably not really flush? It's hard for me to judge since so many run 9.5 wide rims
Thank you
seba112233 is offline   Reply With Quote
Old 04-11-2019, 05:33 PM   #8014
RutRut1124
Member#: 352605
2017 STI
https://www.willtheyfit.com/index.ph...8-5&offset2=42
RutRut1124 is offline   Reply With Quote
Old 04-11-2019, 10:12 PM   #8015
skeeter281
Member#: 403893
2015 STi Limited
WR Blue
Seba, you’ll be good.
skeeter281 is offline   Reply With Quote
Old 04-12-2019, 07:37 AM   #8016
Norm Peterson
Member#: 498642
'19 WRX Limited 6MT
Originally Posted by RutRut1124 View Post
I'm pretty sure that the OE offsets for all 2015 and later WRX and STi road wheels is +55. That would mean the +42 wheel is another 5mm (0.2") closer to flush than that willtheyfit screenshot shows.
Ref. 2018 factory shop manual and fastwrx.com
I'm only interested in dimensional accuracy here.
Norm
Old 04-12-2019, 12:08 PM   #8017
RutRut1124
Member#: 352605
2017 STI
Norm
I couldn't remember if it was +50 or +55, wasn't interested in investing that much time for something probably answered in the previous zillion pages. But good call on the +55.
Old 04-13-2019, 08:38 AM   #8018
evei0326
Member#: 451587
Default 2015 STi (My Cutlass Fish) - Summer and Winter Setup
Hello,
Finally, I post here.
Thanks to nasioc I have been planning my STi (VA) for 4yrs and here are my setup. (Stock suspension) (No Rub) (Not fender Rolled)
Winter - Stock 18 inch BBS - Kumho Wintercraft WP72
22.27kg Wheel and tire.
Thank you.
evei0326 is offline   Reply With Quote
Old 04-13-2019, 08:40 AM   #8019
evei0326
Member#: 451587
Summer - Lexus RC-F Wheel by BBS - Firestone Firehawk Indy 500
25.6kg wheel and tire.
60.1mm to 56.1mm hub adapter
Lexus style Lug with Subaru Thread.
(Lexus has 12x1.5 but Subaru has 12x1.25)
Thank you.
Old 04-13-2019, 10:25 PM   #8020
JRowland
Member#: 454620
2017 WRX
Red
Originally Posted by evei0326 View Post
Looks sweet.
Old 04-14-2019, 09:13 AM   #8021
rst.ack
Member#: 500326
2015 WRX Premium 6MT
Sorry if this question has been asked before -- I've done some research on the differences between forged and cast wheels (and some of the in-betweens such as flow-forming) but haven't really been able to find a definitive "answer" to my long-winded question: I daily my 2015 WRX Premium and I'm looking to put some new shoes on it. I don't plan on taking it to the track, however I do often drive spiritedly (to spice up my commute), and there is a chance I might look at doing the odd Australian hillclimb (I say Australian because we don't really have an proper mountains ). Is there any reason for me to look at forged wheels, or would wheels in the <$400/ea range (i.e. cast, flow-formed, etc.) be sufficient?
I'm sure you can all understand my aversion to spending $2-3k+ on a set of forged race wheels when I really only "need" a <$1k set of slightly weaker, slightly heavier wheels.
So far I've been looking at brands such as XXR, Work Emotion, Avid.1, Enkei, Rota, and Rays/Volk.
I'm looking at the tried and true 18x9.5 +38/19x9.5 +38 range (I think 19s might be a bit much - I like a little bit of sidewall).
rst.ack is offline   Reply With Quote
Old 04-14-2019, 09:54 AM   #8022
Norm Peterson
Member#: 498642
'19 WRX Limited 6MT
Based on your description of expected use, I don't think you need to look at fully forged. Rotary-forged should be entirely sufficient, if my experience with Forgestar F14's in 18x11 on a heavier car than the WRX (street and occasional track days) is any indication.
Fully forged perhaps starts making more sense if there are contingencies for top finishes (such as free tires) and the competition is very strong. But I know where a number of class lap records at time trialing were set by a car on flow-forged wheels.
Norm
Old 04-14-2019, 12:37 PM   #8023
danividi
Member#: 484789
Any poke with these ?
danividi is offline   Reply With Quote
Old 04-14-2019, 01:33 PM   #8024
danividi
Member#: 484789
Originally Posted by air0n'03 View Post
Just got my springs installed, this is day 1 so I'm curious to see what it looks like when it's settled. There is a slight stretch with my 245's but it's not bad. I will go 255's in the future.
RCE Yellow
Option Lab R716 18x9.5 +35
Federal SS595 245/40/18
Looks great , any poke with this setup ? I just got these wheels and wondering about what tire size to go with . Thanks !
Old 04-14-2019, 06:22 PM   #8025
PlayersLtd
Member#: 500366
First post so please take it easy on me and I appreciate any help...
I'm currently going through the process of correcting the wheel and tire set up that the previous owner set on my 09 Sti hatch and because I'm quite particular about what I want I'm finding it difficult navigating the world of wheel fitment.
Current set up:
year: 2009
model: STi hatch
wheel model: Cosmis XT 206R
wheel size/offset: 18x11 +8
tire brand/model: Azenis FK453
tire size: 255/40/18
suspension: Tein Felx Z
alignment: -3.5*F/0.0*R
fender mods: Bolt on flares
spacers: 20MM non hubcentric
Goals: Autocross / Track set up with aggressive appearance (i.e. some poke, dished) and daily drivable.
I want as little stretch on my tire as possible (for appearance and maximum contact patch) which as I understand means I will need to get away from the 11" wheel and drop down to a 10" which will keep a pretty aggressive look while allowing for better tire fit options.
I also want to eliminate the 20mm spacers altogether and build this into the wheel. At the same time, I like me some poke. I also would like as much dish as possible on my future wheel and I like the concave appearance.
So I guess my question is how does one go about combining all these details and goals and ensure a great fit including caliber clearance? At the end of the day I like the look and fit of the Cosmis wheels I currently have but I'd like to eliminate the spacers and get a properly fitted tire. How does a relative noob do this with confidence considering I can't exactly test fit a wheel before ordering? The last thing I want is to spend 3k + on wheels and not have them fill in the fender or be as aggressive as I want, or not clear the stock Brembo caliber, or rub more than currently.
In sum- I want a similar look but I want eliminate my spacers and get a better tire fit than what I currently have.
For extra info, so far my preferred wheels are:
Work Emotion M8R
Work Meister M13P
And my preferred tire is the Bridgestone Potenza Re 71R
The top two images are my car with current set up, bottom is an example of tire, fit and stance appearance that I would be happy with, not necessarily the wheels I'm after as I would prefer a deep, concave dish.
Thanks for any help!
PlayersLtd is offline   Reply With Quote
