Welcome to the North American Subaru Impreza Owners Club Wednesday October 16, 2019
Old 12-30-2015, 09:17 AM   #1
jtlane
Member#: 406373
Default Anyone running meth with a vf48??
I would like to know some results of anyone has dyno number fixing to buy cool mist with fail safe
jtlane is offline   Reply With Quote
Old 01-01-2016, 06:32 PM   #2
jtlane
Member#: 406373
No one????
Old 01-01-2016, 10:28 PM   #3
wrx43v3r
Member#: 331119
Originally Posted by jtlane View Post
No one????
I run it on a small 16G which is pretty close to a VF turbo. It works and I'm sure it will work with the VF. You and I will get more power out of it with a bigger turbo in my opinion, but it did give me a boost. I'm not going to provide dynos because I don't care enough, and my dyno and results won't be relevant to you. Every car is modified differently and will experience different results.
wrx43v3r is offline   Reply With Quote
Old 01-17-2016, 12:45 PM   #4
91boostedb20
Member#: 234837
2005 Legacy GT
obsidian black pearl
I installed an aem meth kit on my buddies 05 wrx with a vf48. We turned the boost up to 23psi and I was able to add 8-10 degrees timing under boost conditions. It bumped torque up a bunch. I kept the afr's rich at 11:1 for a safety net. It was well worth it.
91boostedb20 is offline   Reply With Quote
Old 01-17-2016, 08:38 PM   #5
Horner
Member#: 324477
2002 2.0 vf43+ meth
6mt wrb sedan
My vf43 ej205 with a lot of boltons(ewg, elh, etc) made 314hp 308tq on a dynojet. Another car I built for a buddy with a ported fp 18g on a ej205 with very similar mods made 331hp on a mustang dyno that we were told reads 10% lower than the dynojet. Theoretically that should put that setup between 350-360 on the dynojet. I'm not sure that his tq numbers were or his base 93 pump maps put down but my car picked up 8%hp and 12%tq. Just some food for thought for comparisons sake
Also forgot to add my car increased 4psi and 5 or 6 degrees of timing going from the 93 map to 93+meth
Horner is offline   Reply With Quote
Old 02-01-2016, 10:37 AM   #6
JMlegacy
Member#: 341649
What mixture were you using horner?
and what did pure water get you?
JMlegacy is offline   Reply With Quote
Old 02-01-2016, 10:43 AM   #7
zman17
Member#: 357718
2007 WRX
I'm running a vf39 on 50/50 water meth solution. I'm using "boost juice". Car made 330awhp and 340awtq. 07 wrx
zman17 is offline   Reply With Quote
Old 02-01-2016, 11:46 AM   #8
JMlegacy
Member#: 341649
what was previous no meth power level? Have to compare
Old 02-01-2016, 01:00 PM   #9
zman17
Member#: 357718
2007 WRX
Not sure. Bought the car currently running the meth kit.
