Welcome to the North American Subaru Impreza Owners Club Monday October 14, 2019
Old 06-29-2005, 01:10 AM   #1
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
Default Started my swap today...JDM WRX stage 4
UPDATE! ITS ALIVE!!!
Here is the beginning of lots fun!
My JDM EJ205 that came today.
Got the pinks in today, notice AVCS junk there.
And just to make things fun; a VF39 with STI intercooler.
This pic is from when i frist got the car this summer.
Right before I stripped it.
Mod list:
Engine-
JDM WRX V7 EJ205, AVCS, 9:1 compression, big port heads.
JDM V7 STI ECU tuned by Tim Bailey of Surgeline tuning
JDM WRX harness
Deatschwerks 750cc injectors
TGV delete
NGK copper spark plugs one step colder
Walbro 255 fuel pump
3" exhaust made by me
Ebay up pipe, heat wrapped
Ebay down pipe, heat wrapped, added a high flow cat
Flipped intake manifold and Ported
Ported Stock header heat wrapped
Ported VF39
Ebay turbo inlet
Modified stock air box
Hummer H3 K&N air filter
Ebay front mount Intercooler with modified pipping
Slim radiator fan
Taylor battery relocation kit, anodized aluminum box
Drivetrain-
JDM WRX transmission (4.11)
V2 or 3 JDM STi Type R/RA R160 mechanical LSD
ACT street clutch and light weight flywheel
Group N engine and transmission mounts
SS clutch line
cable to hydraulic clutch conversion
Forester master cylinder with bleeder
Suspension-
Koni Yellow Inserts
Ebay coil Springs 450lbs/in front, 350 rear
Whiteline front & rear end links
Whiteline Steering rack bushings
Whiteline rear subframe lock bolts
Whiteline diff outrigger bushings
98 outback rear lateral links (no rear sway bar stock)
JDM GC8 20mm rear sway bar
Brakes-
SVX master cylinder (non-ABS)
WRX front brakes with Cobb pads
WRX rear disc brake conversion with ebc pads
SS brake lines
Exterior-
Carbon fiber hood
Rota Action 17x7.5 with Azenis 235/40
Interior-
Ultra Shield 6 point harness
Homemade harness bar
04 WRX front seats
Stereo delete
Defi boost and egt gauges
Autometer CF oil temp and pressure gauges
PLX wideband
TXS knock light
Stay tuned
Nick
RS_to_WRX_swap is offline   Reply With Quote
Old 06-29-2005, 01:23 AM   #2
strong_auto_concepts
Member#: 83716
'04 Burn-Up WRX
wrong thread, crap
strong_auto_concepts is offline   Reply With Quote
Old 06-29-2005, 01:38 AM   #3
JDM_Scobaru
Member#: 57809
Good Luck getting that STi Intercooler in there. I had to get my WRX one in and it was a PITA every time I had to take it off and put it back on again. You have to dent the firewall a lot, I mean hard, bang, bang, bang. Good stuff though.
JDM_Scobaru is offline   Reply With Quote
Old 06-29-2005, 03:36 AM   #4
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
UH how does that constitute a stage 4 thats more like a stage 2 IMHO for a JDM engine!! But you still should have alot of fun with it!
DuoMaxwell is offline   Reply With Quote
Old 06-29-2005, 07:03 AM   #5
xcntrk75
Member#: 60224
Man that motor is spotless…! Look like it’s going to be fun, keep us posted…
xcntrk75 is offline   Reply With Quote
Old 06-29-2005, 10:40 AM   #6
pezman04wrx
Member#: 66558
Likely my noob-ness, but isn't the USDM spec 2.0l the ej205 and the JDM spec 2.0l the ej207? ... Either way, it'll be one hell of a step up in performance regardless ...
pezman04wrx is offline   Reply With Quote
Old 06-29-2005, 10:47 AM   #7
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Looks like a gruppe s motor to me. I'm curious to see how that engine runs on the V7 ECU. Did Gruppe S tell you the differences between a V7 and a JDM WRX Engine with AVCS?
Good luck though
benjaminetanyahoo is offline   Reply With Quote
Old 06-29-2005, 11:40 AM   #8
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
wow that gonna be beautiful
i would speculate that he would get the ecu ecutek-ed anyway the v.7 or 2004 jdm wrx are close enough wiring wise
part number for ver 1-4 bumper
57720FA071 ~$140
Old 06-29-2005, 12:01 PM   #9
imprezkid
Member#: 71462
2001 2.5rs
STM
Ok, im KINDA a newbie here, but what is the difference between the jdm and american motors, and what did something like that set u back, it looks like new, good luck and thanks
imprezkid is offline   Reply With Quote
Old 06-29-2005, 12:04 PM   #10
imprezkid
Member#: 71462
2001 2.5rs
STM
Shes gunna be a SLEEPER!
Old 06-29-2005, 12:14 PM   #11
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
increased compression 9to1 vs 8to1
avcs
less emmission control devices
tuned for better gas
same turbo
same intercooler
no uppipe cat
i think thats about it
Old 06-29-2005, 04:13 PM   #12
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
EJ207 = STI, a much better motor.
Not all EJ205' are the same, the JDM has more torque and a better powerband.
Good luck though
I got it from Innovative Automotive, no they did not tell me the difference. But i didn't ask because i already knew. This motor was only $1600, but it didn't have the turbo, intercooler, harness and ECU. But it had less then 500 miles of run time.
57720FA071 ~$140
Thanks for the part number, can't beat the price of that part.
And yes the car will be tuned by PDX tuning first thing.
Old 06-29-2005, 04:18 PM   #13
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Stage 4(typically):
Catless or one cat
Upgraded turbo
Bigger injectors
Bigger fuel pump
and EM
wrxfactor is offline   Reply With Quote
Old 06-29-2005, 05:57 PM   #14
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
The STi is the EJ207 the JDM WRX engine is also a EJ205.
Z
Zephyr is offline   Reply With Quote
Old 06-30-2005, 05:56 AM   #15
Kotir
Member#: 17300
1993 Widebody Wagon
748whp e98
Nice man. If you need any help lemme know. I'm pretty close and I've done something similar
-Tim
Kotir is offline   Reply With Quote
Old 06-30-2005, 09:48 AM   #16
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Originally Posted by wrxfactor
Stage 4(typically):
Catless or one cat
Upgraded turbo
Bigger injectors
Bigger fuel pump
and EM
Subaru tuning shops in Aomori prefecture
Stage 1
Exhaust
Intake
Downpipe
Stage 2
Turbo
injectors
Fuel pump
EM
Stage 3
Headgaskets
Cams
Valve train
Stage 4
Full 2.2L kit
Old 06-30-2005, 10:15 AM   #17
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
What are you talking about? The STi intercooler fits perfectly in there, even with a strut bar. With plenty of room left to spare. See:
http://gallery8713.fotopic.net/p975168.html
http://gallery8713.fotopic.net/p2613987.html
Maybe because you don't have a "new age" engine.
garface is offline   Reply With Quote
Old 06-30-2005, 12:04 PM   #18
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
its
stage 4 via turbo-xs standards
stage 2 via vishnu
stage 3? via pdx group
stage 2.5+ via cobb
basically stages in America are completely subjective
Old 06-30-2005, 01:08 PM   #19
slafranc
Member#: 85382
2000 Impreza RS
Grey
The fact that it is written V7 on the ECU does not mean it is a STi Version 7 ECU I bought a JDM WRX-NB engine a few months ago and it came with an ECU that had V7 written on it. I got it check using the serial code and it is in fact wright ECU for my engine !
No remap required !!!! Although I wish I had the money to do it !!!
slafranc is offline   Reply With Quote
Old 07-03-2005, 09:19 PM   #20
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
Update The EJ18 is out along with the N/A crossmember.
I replaced the old crossmember with a WRX crossmember (bottem), I'm not sure if its JDM or USDM.
Now I'm waiting for a few parts to get here, then i can install the motor.
Old 07-04-2005, 03:22 AM   #21
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
its
stage 2 via vishnu
stage 2.5+ via cobb
LOL that figures I am totally on the wrong page with the staged program. I never really did a stage type thing I just sorta built the car up as funds came available. Can't wait to see this current project he has going finished!!
Old 07-06-2005, 12:58 PM   #22
BoneCake
Member#: 88573
2014 Impreza Sport
I would REALLY recommend a FMIC to you, bro... THAT would be a sick sleeper. Ebay kits can be had for <$500
BoneCake is offline   Reply With Quote
Old 07-06-2005, 07:40 PM   #23
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
Way down the road i have that planned, in addtion to EJ257 sb with a flipped intake manifold. As for now the budget is gone and i'm in "just get it running" mode.
Old 07-07-2005, 12:09 AM   #24
agterlik
Member#: 41626
SPB We make people
quit teh internet
I fit an APS TMIC with no problems, which is a good bit larger than the sti tmic, into my 01 rs with an 04 usdm wrx engine. Perhaps it depends on the crossmember I dunno.
agterlik is offline   Reply With Quote
Old 07-07-2005, 05:47 PM   #25
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
I see.... keep the stock hood and try to use a CF RS hood. Then you could pop the old scoopless hood on later when you plan to go FMIC. I wish I would've kept my stock hood from the TS....
Kreeger is offline   Reply With Quote
FS VA: NEW LOWERED PRICE! 04 WRB WRX Stage 4 w/PPG Bugeyeballa MAIC Private Classifieds 44 06-11-2010 01:08 PM
Started the swap today (vid)! Crashsector Mid Atlantic Impreza Club -- MAIC 10 03-11-2008 08:56 AM
Selling my 02 WRX stage 4 (my pride and joy) TheLegacy Private Vehicle 'For Sale' Classifieds 60 08-24-2007 12:28 AM
My Friends WRX Stage 4 Kit (with Dyno) Scoobs2002 Proven Power Bragging 13 11-30-2005 09:29 AM
Starting my 93L to 03 WRX swap this weekend in JersEY! Keith Tri-State Area Forum 36 07-28-2004 03:26 PM
