Welcome to the North American Subaru Impreza Owners Club Friday October 18, 2019
Old 09-13-2005, 10:12 AM   #51
MK1ofMnM
Member#: 6976
2006 F150
Originally Posted by BoostdScubaru
i will ahve a pic of the motor sitting in the engine bay in a week..
I'm subscribing, I can't wait to see this.
MK1ofMnM is offline   Reply With Quote
Old 09-13-2005, 11:47 AM   #52
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
yeah, so back to the LS1....how many lateral G's can the camaro take?...
Old 09-13-2005, 12:20 PM   #53
tool1128
Member#: 84306
2004 WRX
I second that notion!
tool1128 is offline   Reply With Quote
Old 09-13-2005, 02:00 PM   #54
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
Scoobie Steve is offline   Reply With Quote
Old 09-13-2005, 03:44 PM   #55
Boom05rs25
Member#: 95157
05 Impreza RS 2.5
OBP 5spd Winged
Boom05rs25 is offline   Reply With Quote
Old 09-13-2005, 05:42 PM   #56
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
Originally Posted by Boom05rs25
O and some1 burning everything some1 says is a good roll model....ive owned swapped v-8 chevys for over 10 years i dont need to no subby to give him chevy facts....so sit and spin.....you need a mother F'nn roll model...Son
Boom
PS. Get bent scubbiesteve and your slow as ass ride.... .....Look at some of the useless negative crap this kid has provided,and he has the ballz to say that about me?
IBTB.
Old 09-13-2005, 05:46 PM   #57
MPREZYA
SCIC
Member#: 85
Cut the crap the both of you... I get this reported one more time and the both of you will be sent to the penalty box.
MPREZYA is offline   Reply With Quote
Old 09-13-2005, 11:15 PM   #58
BoostdScubaru
Member#: 42188
back on topic..
motor will be here in a week...
BoostdScubaru is offline   Reply With Quote
Old 09-14-2005, 12:56 AM   #59
Homemade WRX
Member#: 33782
96 in the garage
I'm looking forward to seeing this...especially the video of the subie camming big time
Old 09-14-2005, 01:21 AM   #60
Baldturbofreak
Member#: 36886
2002 WRX,95 Tvette
Black/Red
How bout putting the Fwd K -member out of a northstar Caddy with it's 4t65E in the back of the car. it would become a mid engine 2 seater with a 32v aluminum v-8. It can be had for real cheap too. Think about it: motor, trans, lower control arms all on one frame/ You can reuse the strut towers on the subie. All you gotta do is replace the rack with some fixed tie rods. Off the shelf brakes/struts replacement parts.
You could even weld the spider gears on teh center diff and keep the front engine as well.
Baldturbofreak is offline   Reply With Quote
Old 09-14-2005, 02:18 AM   #61
BoostdScubaru
Member#: 42188
yeah its got a z06 cam in it and small head work....plus my bigass t-78
Old 09-14-2005, 02:27 AM   #62
02Toyowrx
Member#: 56520
If you are planning on making 550 hp.. why wouldnt you make it easy on yourself and stay with a R180 or a slightly larger Rxxx rear end.. this would be alot easier to bolt up and you could use aftermarket replacement axles... and also probably less weight.
I believe this will work fine... Subaru engines are so Wide. any measurements yet?
IF you use the current engine mount placement then I think you will have to move your firewall back. But if you move the engine mounts forward then you might be able to make up for the extra clearance needed.
For sure this would not be a suitable swap for a track car, althought would be ok for drag or a daily driver.
Good luck.. lets see some pictures
02Toyowrx is offline   Reply With Quote
Old 09-14-2005, 03:53 AM   #63
thesmokingman
Member#: 17751
Some pics to illustrate the size of the ls1:
LS1 in a 944 Turbo:
The beam going across the LS1 intake is the hood latch, which is not needed on a car using pins...
Stock 944 Turbo:
The LS1 is pretty effin small. And its light as hell too, and in fact in a 944 Turbo for ex. it is the same weight at the all aluminum 4 banger turbo it replaces. There potential here in a Subaru. Hell, Prodrive relocates motors 6 in back all the time...
thesmokingman is offline   Reply With Quote
Old 09-14-2005, 04:17 AM   #64
BoostdScubaru
Member#: 42188
i was thinkin about the r180s.. how much, and dont you have to replace the brakes and spindles and ****...?
Old 09-14-2005, 04:27 AM   #65
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
you ponder R200's? dirt cheap. fab up a S13 rear end
supermoose is offline   Reply With Quote
Old 09-14-2005, 09:00 AM   #66
BoostdScubaru
Member#: 42188
r200 is toyota??
Old 09-14-2005, 09:38 AM   #67
russd32
Member#: 63961
I can't wait to see it sitting in the car. As long as the motor is sitting as far back against the firewall as you can get it it shouldn't handle much different. If you ever get the chance to ride in a rx7 with a v8 it can be demonstrated how you can use the extra torque to make up for weight gains.
I would be willing to bet that by the time he swaps everything over he won't be more than an 100-200 pounds extra.
Are you planning on doing a custom gauge cluster or are you going to attempt to use the stock gauges.
russd32 is offline   Reply With Quote
Old 09-14-2005, 11:31 AM   #68
jefersun
Member#: 37716
2002 ej257 Black WRX
ls1 swaps are sweet, but in a WRX, eh... if it doesn't keep awd, whats the f'ing point! Get a rx7 and put your ls1 there. rx7 looks way better, they make kits, and it weighs 300 lbs less with the ls1 than a stock WRX.
Funny thing is, when you take the rotary out of the 3rd gen rx7 and put a ls1 in, it weighs less! (iron vs. aluminum)
jefersun is offline   Reply With Quote
Old 09-14-2005, 12:45 PM   #69
BoostdScubaru
Member#: 42188
actually im goin to try to get it down to around 2800 lbs with me in it....rwd scoob is what i want. and with the right suspension setup i can change handling characteristics.. yes i am doing a custom gauge cluster, and theres gonna be a lot of wiring to do, but im good at wiring so thats no biggie..i will be fabbing the turbo kit, and yes im doing a front mount
Old 09-14-2005, 01:30 PM   #70
supermoose
Member#: 9093
swap starr
r200 is the diff in all nissan FR cars, skyline, z, silvia. cheap and holds 500 rwhp no prob. u can get for 2-300 bux wth axels and such
h
Old 09-14-2005, 02:05 PM   #71
BoostdScubaru
Member#: 42188
yeah but im going for 800 WHP once the setup is in an spring comes around...
Old 09-14-2005, 03:19 PM   #72
Scoobie Steve
Member#: 2289
How do you plan to put 800whp to some 235 rear tires? Do you think it will be even slightly drivable?
Old 09-14-2005, 04:34 PM   #73
BoostdScubaru
Member#: 42188
its tubbed...
295/35/19
Old 09-14-2005, 04:40 PM   #74
Scoobie Steve
Member#: 2289
its tubbed...
295/35/19
Pics?
Old 09-15-2005, 01:44 AM   #75
ejsportcom
Member#: 88905
its tubbed...
295/35/19
tubbed = awsome, i can't wait to see pics of this set up, best of luck to you. I should have done this instead of my 6-speed swap....
ejsportcom is offline   Reply With Quote
Complete drivetrain from 2002 WRX in Chicago jaronis Drivetrain 3 09-19-2008 05:39 PM
Baja Turbo Drivetrain in '02 WRX Started uberspeed Subaru Conversions 18 07-09-2006 11:24 PM
2005 WRX OEM CD player in 2002 WRX??! uberspeed Car Audio, Video & Security 3 06-08-2005 10:23 PM
T-Stow/Trowbridge 9th overall and 1st in PGT at Ojibwe ProRally in 2002 WRX mvb Motorsports 0 08-22-2001 05:29 PM
