Welcome to the North American Subaru Impreza Owners Club Friday April 20, 2018
Old 02-09-2012, 01:14 AM   #1
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Default need tune vf39 kelford cams tvg deleates
Building motor 2002 wrx with kelford 199e cams, modded injectors, sri, sti tmi, tbe, walbro fuel pump, ported throttle body, tvg deleates, catless uppipe, I need a tune close enough to get me started I would be thankful for any help, I am new at this open source tuning stuff. I have flashed a xpt tune to my present motor but thats about it. I have repaired hundreds of subarus but not tuned any.
thanks Dan
Old 02-09-2012, 10:21 AM   #2
quazimoto
Member#: 70395
You could just purchase an E-tune. Contact Phatt-botti tuning.
Old 02-09-2012, 10:30 AM   #3
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Thats kind of the plan, I was just hoping someone would have something close so i could start it and break in the cams.then I was going to fiddle with it and see if I could figure it out and if I couldn't then buy one. So if anyone has a tune they are messing with that should be close enough to get me started that would be great.
Old 02-09-2012, 04:08 PM   #4
quazimoto
Member#: 70395
Thats a pretty horrible idea. Especially since your installing injectors and an intake at the same time. You didn't even list what SRI you are using. If you are new to tuning this would not be the setup to learn on.
Old 02-09-2012, 06:43 PM   #5
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
It's a spt but I 90ed it into the fender well for cold air, if someone is running someting similar it should start and run the 20 min I need to season the cams I can watch my wide band and make sure it's running ok. what do you want me to learn on? I have one running wrx and one I am building, I would rather learn on my extra car not my dd.
Old 02-11-2012, 12:41 AM   #6
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
^^ um....you should learn on a mostly stock car by changing 1 part at a time.
learning how to change the maf correctly is a chore in itself....then add in modded stockers......then cams.....you're asking for trouble.
My suggestion is to put the stock injectors and stock intake on and break the car in that way.
And make the AF Correction range +-40% just in case
Old 02-11-2012, 11:14 AM   #7
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Thanks I understand that but my mostly stock wrx has a xpt stage 2 and 220k on it it's next to get rebuilt. I do plan on learning on it but it's on it's last leg. The other is built and waiting for the install (I work 60 to 70 hrs a week when the shop is biz ) it should go in this next week if I get a couple of hours. I was hoping someone would be running something similar and have a good tune then it would need a min amount of work to dial in. I know how complicated this is, I know there is alot to learn, I can see everyone want's you to buy a tune, I know how to buy a tune and load a tune, it's time to learn a little more. I will buy a tune if no one comes up with a tune that is close but that helps me learn nothing, great. Thanks for the advice though.
Old 02-11-2012, 11:39 AM   #8
Phatron
Member#: 36033
CEO PhatBottiTuning
As a tuner I wouldnt even do it because the fueling isn't going to be spot on.....
You don't want to be trying to tune the car during this time.
Your best bet is to put the stock stuff on....
Old 02-11-2012, 03:37 PM   #9
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Ok I understand but I modded my injectors, I deleated my tvgs, I don't have any of my stock intake or filter and my tdo4 is gone.
Old 02-11-2012, 04:35 PM   #10
Phatron
Member#: 36033
CEO PhatBottiTuning
I'd seriously take the intake and injectors off your dd and put them on your build car to break it in. Then learn how to scale the injectors/intake on your dd.
Or at least throw them on your dd and get the maf and injector scalar dialed in THEN put then in the build car with those values.
Old 02-11-2012, 07:19 PM   #11
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
at least throw them on your dd and get the maf and injector scalar dialed in THEN put then in the build car with those values.[/quote]
I could do that. thanks for the idea that sounds like a good place to start if I can't come up with a tune that is close. If someone is running cams, modded injectors,cai and a vf39 there tune should be very close though and that would be easier.
Old 02-11-2012, 07:39 PM   #12
Phatron
Member#: 36033
CEO PhatBottiTuning
I could make a tune that's "close" but then u have the cams too....and that changes everything. The point is that u don't want to be tuning during break in.
Even if u have the maf and injectors done from getting them dialed on your dd, the fueling could still be off by ~20% from the cams.
And with your custom cai if you do em all at once the fueling could be off by 40% initially.
Old 02-11-2012, 09:49 PM   #13
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I do understand that. My dd has 220k on it with the stock tdo4 leaking oil and making noise and I am sure the compression isn't up, so i'm not sure I could get close that way. So now what? This is a modded 58k motor so It won't be during break in I just need to season cams. I could take the intake and injectors off my dd but then both my winter cars would be not working and i can't drive my built falcon in the weather it does snow here.
Old 02-11-2012, 10:20 PM   #14
Phatron
Member#: 36033
CEO PhatBottiTuning
Idk man. Either go with the stuff u know the scalings for or don't. Up to u.
Old 02-23-2012, 03:31 PM   #15
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Still no one with a simular setup?
Old 02-23-2012, 03:46 PM   #16
Phatron
Member#: 36033
CEO PhatBottiTuning
if you're insistent on doing it with those parts open up the rom, type in the injector scalar, hilight the whole maf scale and multiply it by 10% and open up the AF corrections from +-15 to +-50
i just dont understand the thinking that after spending all the money on parts, you're gonna take a map for free from someone off the internet and load it on your car.
Old 02-28-2012, 03:34 PM   #17
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Was just looking for some maps to look at, I have no idea of what to do, looking to learn a little, You are still going to tune this car. rolled my other wrx it's in the body shop, so i'm a little behind right now, I expect to be done in the next couple of weeks, most of the engine is together.
Old 02-28-2012, 04:04 PM   #18
PhatBotti Tuning TKR
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
Phatron was in jersey with me when I tuned this exact same setup, literally part for part. Ended up running a 12.40 on 93 octane at the track with traps at 109-111.
-Mikey
PhatBotti Tuning TKR is offline   Reply With Quote
Old 02-28-2012, 09:24 PM   #19
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
-Mikey
That sounds great I look forward to getting it done.
Old 02-28-2012, 10:35 PM   #20
Phatron
Member#: 36033
CEO PhatBottiTuning
so it will run 13.0 @ 103mph on 91
your other cars not drivable....good time to snag those injectors and intake
Old 02-28-2012, 10:45 PM   #21
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Yes I can take the intake and air box but what injectors I have 420, 565 or 825. If you just tuned one with all the same mods couldn't you start with that tune and tweek it a little so it is safe?
Old 02-29-2012, 01:41 PM   #22
quazimoto
Member#: 70395
He could but you were insisting on trying to do this yourself,remember?
Old 02-29-2012, 08:49 PM   #23
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Sorry you weren't in the loop, pmed phatron last week and he is going to tune my car. I do still hope to learn something, maybe when I fix my other one.
Old 06-17-2012, 10:54 AM   #24
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Engine didn't survive the tune.. I pushed Ron to raise the redline to high and the oiling system couldn't keep up. It was runnind really good till that point. Not the tunners falt, all mine. Oh well another good excuse to build a better motor.
Old 06-17-2012, 11:27 AM   #25
Phatron
Member#: 36033
CEO PhatBottiTuning
I'm going to give u the benefit of the doubt right now and assume you dont understand how that statement sounds to people reading it and give you an opportunity to expound on the situation yourself.
Who's tuned AEM EMS w/ Kelford cams? (05 STi) bigmike25rs Other Engine Management 62 01-14-2014 08:25 PM
Kelford Cam install w/ supertech valves, need help on install SBW Built Motor Discussion 24 11-28-2011 09:42 AM
FS : MD: Element Tuning GT75 rotated kit, Kelford cams, intake manifold & 1000cc injectors Md05STI Engine/Power/Exhaust 33 04-07-2011 11:13 PM
Kelford cam card needed? korhan Built Motor Discussion 1 11-27-2008 03:58 PM
