05-19-2009, 06:46 PM | #1 |
Member#: 173241
TXIC
Vehicle:2002 s256 twinscroll now with one more gear |
high RPM knock
i have been trying to tune and everytime i try to add timing i will get knock form 6k up. both fine learning (1.05) and feed back (2.11) the thing is the car has done if from the stage two original tune. if i run 19degrees timing i am fine, but anything over it i get knock consistanly, even some times at 19 i will. i dont get any signs of knock anywhere else. now the biggest thing i am wondering is that how am i getting knock? all of my knock is turned off above 6k, and yet i keep getting it. my mods are
vf37-20g wheel oem twinscroll exhaust with 3inch straight pipe turbo back. perrin crank pulley modded stock injectors aps turbo inlet sti top mount walbro fuel pump. K and N drop in filter
05-19-2009, 07:29 PM | #2 |
Member#: 68448
NWIC
Vehicle:2008 WRX STi Cobb tunned by Surgeline |
Have a log?
05-19-2009, 09:16 PM | #3 |
Member#: 156973
International
Vehicle:2002 ADM WRX STi STi Black/Blue |
high load high rpm knock is the most dangerous type. The last thing you want to do is ignore it. This kind of knock is what kills engines.
If you are knocking above 19deg then unfortunately that is as much timing as your motor seems to support given the fuel used - or you are leaning out and that is causing the knock and not the timing. As posted above, do you have a log? Post it here and ppl will be able to better determine the problem and a solution. |
05-20-2009, 12:19 AM | #4 |
Member#: 173241
TXIC
yea i got a few give me a second, i have backed it down to 19 degrees, and i am fine, i just have never seen a car not be able to take more than 19 at redline, this seems like maybe it has something to with why i cant get my g/sec any higher than 250 even though i am making like 300whp
05-20-2009, 12:52 AM | #5 |
Member#: 173241
TXIC
log
here is a log, i have since pulled 1 degree of timing and now its alot better, but i just dont understand why i cant make more power
Code:
Time EL rpm FKC FLKC IAM timing Absolute Pressure Relative Pressure g/sec WGDC Target Boost TDC 0 0.43 1911 0 0 16 41 7.66 -7.5 14.31 92.94 -1.35 9.05 219 0.99 1979 0 0 16 27.5 14.93 0.14 33.21 93.73 15.37 9.05 422 1.02 1980 0 0 16 28 15.28 0.46 34.39 96.47 16.24 9.05 625 1.03 2029 0 0 16 28 15.64 0.81 34.75 96.47 16.67 9.05 860 1.05 2062 0 0 16 27.5 15.99 1.2 35.97 96.47 16.78 9.05 1063 1.07 2115 0 0 16 27 16.38 1.57 38.99 96.47 17.15 9.05 1281 1.09 2196 0 0 16 27 16.71 1.91 39.8 96.47 17.33 9.05 1485 1.11 2236 0 0 16 26 17 2.19 41.43 96.47 17.54 9.05 1703 1.12 2285 0 0 16 26 17.23 2.4 43.79 96.47 17.69 9.05 1922 1.15 2346 0 0 16 25.5 17.52 2.73 45.5 96.47 18.06 9.05 2125 1.17 2438 0 0 16 24.5 17.93 3.09 47.58 96.47 18.2 9.05 2344 1.2 2497 0 0 16 23.5 18.25 3.44 50.13 96.47 18.45 9.05 2563 1.22 2554 0 0 16 23 18.6 3.79 52.32 96.47 18.78 9.05 2766 1.25 2616 0 0 16 22.5 18.95 4.14 55.7 96.47 19.03 9.05 2969 1.28 2695 0 0 16 22.5 19.32 4.51 57.98 96.47 19.34 9.05 3188 1.3 2759 0 0 16 22.5 19.65 4.85 59 96.47 19.59 9.05 3391 1.34 2821 0 0 16 22.5 20.01 5.2 63.46 96.47 19.84 9.05 3594 1.38 2883 0 0 16 22.5 20.4 5.59 67.38 96.47 20.13 9.05 3813 1.41 2939 0 0 16 22.5 20.81 6.01 69.92 96.47 20.36 9.05 4031 1.44 3046 0 0 16 22 21.27 6.46 73.28 96.08 20.79 9.05 4219 1.47 3112 0 0 16 21 21.81 6.98 77.94 95.29 21.08 9.05 4438 1.51 3212 0 0 16 21 22.45 7.6 81.73 94.12 21.54 9.05 4672 1.56 3272 0 0 16 20 23.11 8.28 86.12 93.33 21.83 9.05 4875 1.62 3337 0 0 16 20 23.9 9.07 92.84 92.55 22.43 9.05 5094 1.69 3462 0 0 16 19.5 24.71 9.84 99.24 90.98 22.82 9.05 5297 1.76 3583 0 0 16 19 25.68 10.73 106.23 89.8 22.88 9.05 5516 1.85 3642 0 0 16 18 26.72 11.81 114.3 87.84 22.84 9.05 5735 1.94 3743 0 0 16 17.5 27.88 12.97 122.73 85.88 22.8 9.05 5953 2.04 3880 0 0 16 16.5 29.31 14.37 132.71 82.75 22.76 9.05 6172 2.14 3983 0 0 16 16 30.9 15.88 147.82 80.39 22.72 9.05 6391 2.25 4114 0 0 16 15 32.39 17.4 156.91 78.82 22.7 9.05 6610 2.33 4298 0 0 16 15 33.67 18.68 165.65 77.65 22.66 9.05 6813 2.41 4378 0 0 16 15 34.77 19.8 178.68 76.86 22.64 7.86 7031 2.46 4518 0 0 14 13 35.87 20.85 190.92 76.08 22.6 5.65 7250 2.5 4609 0 0 14 13 36.76 21.79 201.4 75.29 22.59 3.93 7469 2.53 4762 0 0 15 14 37.11 22.35 205.32 74.12 22.57 0 7688 2.53 4903 0 0 15 14 37.3 22.47 213.13 73.73 22.47 -0.11 7875 2.56 5052 0 0 15 13.5 37.26 22.39 217.14 73.33 22.43 -0.07 8094 2.57 5190 0 0 15 13.5 37.03 22.22 224.17 72.55 22.35 -0.04 8313 2.54 5399 0 0 15 14 36.78 22.06 226.26 72.16 22.3 0 8531 2.52 5470 0 0 15 14 36.72 21.99 230.01 71.37 22.22 0 8750 2.48 5572 0 0 15 14 36.62 21.87 233.56 70.98 22.14 0 8953 2.45 5734 0 -1.05 15 13.5 36.45 21.75 236.99 70.59 22.1 0 9172 2.39 5914 0 -1.05 15 13.5 36.18 21.6 232.32 70.59 22.06 2.96 9391 2.38 5957 0 -1.05 15 14 36.12 21.48 238.28 70.59 22.01 2.96 9594 2.35 6082 0 -1.05 15 14 36.01 21.21 238.72 70.59 21.93 2.89 9813 2.33 6266 -2.11 -1.05 15 13 36.04 21.27 242.61 70.59 21.89 2.96 10016 2.31 6313 -2.11 -1.05 15 13.5 35.91 21.17 241.75 70.59 21.83 3.33 10235 2.28 6372 -2.11 0 15 14.5 35.91 21.08 244.78 70.2 21.79 2.89 10453 2.25 6544 -2.11 0 15 15.5 35.97 21.17 244.78 70.2 21.77 3.63 10656 2.23 6614 -2.11 0 15 15.5 35.89 21.25 244.35 70.2 21.7 2.67 10875 2.19 6738 -2.11 0 15 16.5 35.93 21.27 244.35 70.2 21.68 2.96 11094 2.14 6787 -2.11 0 15 17 35.93 21.25 243.92 70.2 21.52 0 11297 2.12 6906 -2.11 0 15 17.5 36.12 21.35 245.21 70.2 21.5 0 11516 2.09 6919 -2.11 0 15 17.5 36.08 21.39 243.92 69.8 21.41 0 11735 2.07 7036 -2.11 0 15 18 36.1 21.48 244.56 68.63 21.15 -0.58 |
05-20-2009, 12:53 AM | #6 |
Member#: 173241
TXIC
not sure if i can post a map of even how, but if someone wants to see it i can email it to you
05-20-2009, 10:37 AM | #7 |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
Do you have a wideband? You could be leaning out as others have said
05-20-2009, 05:37 PM | #8 |
Member#: 173241
TXIC
actually i had an innovative, and had a problem with them and they wouldnt fix it so i just recently got rid of it, i will be buying an aem in the next month or so, i am actually looking and this guy with a pe1820, pretty much closest turbo to it, is making pretty much the same power, and he can only run 19 degrees timing, also, i wonder if its something to do with the turbo setup in general, i can run more boost and i am fine, just not more timing.
05-20-2009, 06:11 PM | #9 |
Member#: 68448
NWIC
Just a question but will moded stock injectors support a 20G under heavy timing? Is the duty cycle maxed for stock injectors with that turbo setup?
Just a question as I have not delt much with moded injectors. |
05-20-2009, 07:24 PM | #10 |
Member#: 173241
TXIC
well i am actually only at like 60-65%, so i dont think they are a problem, now it could be that they dont have a great spray pattern so it doesnt atomize as good as others, but i dont know, its a vf37 with a 20g wheel
05-24-2009, 12:37 PM | #11 | |
Member#: 164830
SCIC
Vehicle:2002 WRX G61 III OVE 58e |
I don't have a 20G, but on my 16G EVOIII my IDC's are no higher than 48-50% on my modded stockers. Upgraded fuel pump is a must as well. |
05-25-2009, 02:16 AM | #12 |
Member#: 85905
Vehicle:2004 WRX |
Ill chime in since Im the 1820 owner that you are refering too,
I seem to be limited to about 19 degrees uptop because I choose to run higher amounts of boost up top, rather than increase the timing. Its a balancing act. |
05-25-2009, 02:26 AM | #13 |
Member#: 192861
Vehicle:2011 WRX SWP |
what engine management are you using? RomRaider Cobb AP? Pro-tune OS?
Also Id look into getting a WB if you don't already have one, that would definitely tell you exactly where your at. A/F wise. |
06-02-2009, 12:51 AM | #14 |
Member#: 58670
Vehicle:2005 got muuuuu? |
did you figure out your issue?
06-02-2009, 01:13 AM | #15 |
Member#: 173241
TXIC
well i put a short ram on, and an sti intercooler, and i can push 20degrees timing, i have pretty much given up, i am now starting to build my JDM Ver8 207 and i will start all over with that one
06-02-2009, 03:51 PM | #16 |
Member#: 192861
sounds good.
High boost and high RPM? | Way2Slow | Engine Management & Tuning | 4 | 08-28-2005 12:52 AM |
Rough idle and high-pitched whine at high RPMs | fastenova | Legacy Forum | 10 | 11-21-2003 02:50 PM |
High pitched wistle at high RPM when under boost. | roybfr | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 10-15-2003 12:22 PM |
Knock if high RPM throttle lift...UTec | WRXTom | Engine Management & Tuning | 7 | 01-16-2003 09:07 AM |
high speed-high rpm power drain | KITTbri | Normally Aspirated Powertrain | 18 | 04-19-2001 06:22 AM |
