Welcome to the North American Subaru Impreza Owners Club Thursday August 16, 2018
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 02-26-2018, 02:59 PM   #1
chansdaman
Member Sales Rating: (1)
Member#: 457390
Default MD: 2002 WRX wagon hybrid built 5spd $7000
Basics:
-2002 Subaru WRX wagon
-EJ25 block, B25 STI head
-5-Speed manual (built)
-228K on body
~70K on engine/transmission
-Clear title on hand
-Clean CARFAX on hand
-3rd owner (including me)
-Dyno'd at 277whp/291 Torque
-Professionally tuned at Agile Automotive
Bad:
-Dents with paint issues on the left side
-Missing a couple interior pieces such as rear headrests, cargo cover
-Rust in rear right quarter panel
-Paint chip marks on bumpers
-Small power steering fluid leak
-Clunking noise from rear right (possible from the coilovers)fixed
-Typical rust for MD
Good:
Engine/drivetrain
-EJ25 block, B25 STI heads
-VF39 turbo
-JDM "pink" injectors
-Walbro 255 fuel pump
-Perrin turbo inlet hose
-Really nice turbo back exhaust with Borla Hush muffler
-Cosworth bearings
-Cosworth oil pump
-Cosworth crank
-Rebuilt transmission with Legacy GT gears (much stronger)
-Southbend Stage 1 HD clutch (~7K miles)
-DCCD's VSSPro (corrects lower speedo readings from the lower Legacy gears)
-Rebuilt rear diff
-TurboXS Hyperflow oversized top mount intercooler
-3 row aluminum radiator with new hoses
-Samco silicone hoses for most intercooler/coolant passages
-Ground kit
-Cobb Accessport
Brakes/Suspension
-CUSCO coilovers (zero 2R)
-GTSPEC subframe brace
-Whiteline Anti Lift Kit
-Upgraded Akebono brakes
-Braided stainless brake lines
-JDM FHI STI front strut bar
-CUSCO rear strut bar
-Spearco Assetto Gara rims with Continental ExtremeContacts
Recent maintenance/parts
-New Southbend stage 1 HD clutch
-Resurfaced flywheel
-OEM Coolant expansion tank
-OEM clutch slave cylinder
-New shift joint
-New coolant
-Redline lightweight shockproof fluid
-Replaced oil drain back hose clamp on the turbo
-OEM oil pan
-Akebono rotors and pads
-Brake fluid flush
-Valve cover gasket
-Rotated tires
-Spark plugs
-Fuel filter
-PVC valve
Interior/Body:
-Fairly clean interior
-JDM STI hood scoop
-JDM Subaru armrest extension
-Dynomat sound deadening materials in the rear
-Power windows/locks/cruise control, all electronics work, to include heat and A/C
I bought this primarily to be commuter, and as such put about $4,000 in maintenance/repairs (with receipts from Andrewtech Automotive) within the past year. I no longer have a commute, and with this being a 3rd spare car, it doesn't make sense for me to hold on to it. Although she isn't the best looking, this car is rock solid mechanically. No overheating (180-190F coolant temp while cruising), no misfires, no shifting issues, boosts to 17-18 psi, turbo flows well at 39 lb/min, and no check engine lights. The car handles like a go cart (albeit a little too stiff for my taste), very quick around town (max torque at 4K rpm), and has ton of headroom and cargo room (benefit of a wagon). The turboback exhaust is catted with a resonator, and Borla Hush has a nice muted sound, but still lets out a nice pop, as well as the subie rumble that we all love. I have the dynosheet and the tune files. With the engine, drivetrain/clutch and cooling system fairly new, this vehicle should serve the new owner nicely for a long time. I do not have receipts for the engine nor the tranny work (you can clearly see the EJ25 block stamp, and I added the speedo correction device for the regears, so it's all there), but still have ~$4K worth of maintenance/repair receipts from Andrewtech.
I have done my best to be as upfront as possible.
Price: $7,500 OBO
Located in Howard County, MD
chansdaman is offline   Reply With Quote
Old 02-28-2018, 07:40 AM   #2
AnthonyF24
Member#: 482700
2013 Hatch
Just joined looking for a bug eye. It looks like dew on the top of the car, is it? Making sure it's not paint fade.
AnthonyF24 is offline   Reply With Quote
Old 02-28-2018, 11:44 AM   #3
chansdaman
Member#: 457390
You're correct! It's front/dew. No paint fade up top. I got an estimate for the quarter panel rust repair, as well as take care of the driver side. To get it professionally done, we're looking at $1000. Again, this was my daily into Baltimore so it wasn't priority.
Another option is just to get the doors replaced. There is a 06 WRB wagon part out locally with both driver side doors in good shape. Seller is asking $500 for both (I think), and the quote for install was $200 per door.
Thanks for the interest!
Old 03-02-2018, 03:30 PM   #4
chansdaman
Member#: 457390
Taking offers.
Old 03-06-2018, 08:44 AM   #5
chansdaman
Member#: 457390
Happy Tuesday bump!
Old 03-10-2018, 02:25 PM   #6
chansdaman
Member#: 457390
Weekend bump!
Old 03-12-2018, 12:06 AM   #7
chansdaman
Member#: 457390
Some pics of receipts and carfax.
Old 03-16-2018, 03:29 PM   #8
chansdaman
Member#: 457390
Made a small update to original post. The CUSCOs are of Zero 2R variety.
Old 04-05-2018, 11:13 AM   #9
chansdaman
Member#: 457390
Bimonthly bump
Old 04-11-2018, 08:59 AM   #10
chansdaman
Member#: 457390
Increased the preload on the rear coilovers, and the clunking is now gone. Less bouncy in the rear as well.
Old 04-16-2018, 10:55 PM   #11
chansdaman
Member#: 457390
Added some updates (I guess I didn't know as much as I thought about the car!)
Comes with Whiteline Anti Lift Kit installed, JDM STI hood scoop, and JDM Subaru Armrest Extension (has two compartments)
Old 04-18-2018, 11:31 AM   #12
masonkabro
Member#: 484825
Wow, what a beautiful build!
masonkabro is offline   Reply With Quote
Old 05-23-2018, 04:46 PM   #13
chansdaman
Member#: 457390
Just received a new battery. Bump.
