06-20-2017, 10:15 PM | #11376 |
Member#: 416107
International
Vehicle:2002 WRX Wagon EJ207 Spec C 4EAT |
EJ207 Owners?
my mishi cap is fine. over a year no issues.
it has to go on the expansion tank not the rad.
06-21-2017, 12:16 PM | #11377 |
Member#: 21145
NESIC
Vehicle:2002 Enemy of Aku |
06-21-2017, 12:20 PM | #11378 |
Member#: 306719
Vehicle:2003 Sti Wagon @jn_garage |
06-21-2017, 12:34 PM | #11379 | |
Member#: 34361
Vehicle:04.7 STI WRB IG @got2boostit2 |
06-21-2017, 02:10 PM | #11380 |
Member#: 110078
Vehicle:02 Bugeye JDM STi OBP BLACK |
Yes, I installed a brand new oem IAC, today the car started to high idle, I pulled over and opened the hood to take a look at the throttle body mechanism where the throttle cable is attached. I think I just need to slack the cable, I pushed the mechanism to the closed position and the idle normalized. I'll report back after I adjust the cable.
06-24-2017, 08:12 AM | #11381 |
Member#: 110078
I rerouted the cruise control cable and gave the throttle cable a little more slack. No more mysterious high idling, problem fixed.
06-24-2017, 11:19 PM | #11382 |
Member#: 467325
Vehicle:2003 EJ207 v7 WRX White |
Fuel leak
06-26-2017, 05:02 PM | #11383 |
Member#: 330895
NESIC
Vehicle:2002 Impreza wrx blaze yellow |
I have my version 9 setup and ready to go but I have this cam sensor code po365. Anyone know if it's related to avcs function or anything like that? I have yet to get the car tuned and I'm pretty sure I have to invert the function of the neutral safety switch for the avcs to work. If its not due to that then the sensor must be faulty, I tried taking it out but it seems I have to disconnect the avcs solenoid to remove it which will be a pita. car runs real smooth otherwise with an idle around 700 rpm. It's getting registered this week and I'd like to figure this code out before I send it to be tuned. Any input would be great. Thanks. |
06-27-2017, 08:27 AM | #11384 |
Member#: 21145
NESIC
Well, you know generally where the leak is coming from, but before you can do anything, you will need to determine what exactly is causing the leak itself.
06-29-2017, 02:49 PM | #11385 | |
Member#: 459849
Vehicle:2002 Legacy GT 89N (titanium pearl) |
06-29-2017, 07:50 PM | #11386 |
Member#: 467325
No, havent fixed it yet. The gas is coming from that cylinder thing in the middle that is open
07-01-2017, 06:34 PM | #11387 |
Member#: 297799
South East
Vehicle:2003 WRX EJ207 version 8 |
07-02-2017, 12:46 AM | #11388 | |
Member#: 467325
From the firewall, the bottom goes to the filter, middle goes to middle, top goes to bottom which is not connected rn, just took it off to replace it with a new line. http://i.imgur.com/jKaeIvF.jpg |
07-02-2017, 08:53 PM | #11389 |
Member#: 110078
EJ207 Owners?
Can anybody tell me what gauge wire is the factory STi ground that goes from the firewall to the transmission?
I'm using the original wrx wire, looks ok but I have the intercooler out to inspect for blowby and bleed the clutch. Tuner asked to check all grounds due to possibility of weak spark. From looking at pictures on google, I get the impression the wrx ground wire is a narrower gauge than the STi. Your help is greatly appreciated. |
07-03-2017, 01:19 AM | #11390 | |
Member#: 467325
07-06-2017, 08:23 PM | #11391 | |
Member#: 297799
South East
Firewall -> Manifold Top -> Middle Middle -> Bottom Bottom -> Top My filter is in the tank now (STi hanger). http://i.imgur.com/nANagnF.jpg http://i.imgur.com/cF6LQwC.jpg http://i.imgur.com/Lk88kBA.jpg Looks like your vapor line is connected to the return line spot. |
07-25-2017, 11:27 PM | #11392 |
Member#: 79643
NESIC
Vehicle:2021 STI TE Terminal black pearl |
Hey brohams. My swap is giving me some issues finally. Version 8 ej207 into an 04 wagon, been running fine for years now. Just recently popped two CEL codes:
P0365 Camshaft position sensor B circuit bank 1 P0519 Idle air control system performance. It's running like hot dick and I'd like to get it fixed. Any suggestions? |
07-26-2017, 01:20 AM | #11393 | |
Member#: 21339
HIIC
Vehicle:2002 LHD STI V7 6MT 12.9@103MPH EJ205 4EAT |
07-26-2017, 09:05 AM | #11394 | ||
Member#: 79643
NESIC
I have not.
07-26-2017, 11:41 AM | #11395 |
Member#: 25194
RMIC
Vehicle:2008 Forester XT 5mt Dark Gray |
Check the rear cam sensors for oil contamination. For whatever reason, over time the rear sensors crack and allow oil into the electrical connection area. Thankfully, the replacement sensors (JDM specific), include a new sensor and pigtail wiring. if you do end up needing to replace these sensors, or even a solenoid, keep in mind that we have these items in stock at our Colorado based office.
[email protected] |
07-26-2017, 02:17 PM | #11396 | |
Member#: 79643
NESIC
Is there another sensor on the back side of the motor or are you talking about the connector on the back side of the solenoid? It's been a while since I've had to take one apart. http://i.imgur.com/HsUObom.jpg |
07-26-2017, 03:22 PM | #11397 |
Member#: 25194
RMIC
The sensor in the image is teh front cam sensor. There is an identical pair of them on the cylinder head towards the firewall. One on each side of the motor, with one just in front of the turbo.
07-26-2017, 03:26 PM | #11398 |
Member#: 79643
NESIC
Thanks. I'll take a look tomorrow but the front sensor/solenoid may just be the problem. That whole quadrant of the engine bay is covered with oil residue.
07-31-2017, 10:57 AM | #11399 |
Member#: 79643
NESIC
I've narrowed it down to that front sensor/solenoid. If there's oil residue that would indicate an issue with the solenoid instead of the sensor, yes?
07-31-2017, 04:25 PM | #11400 |
Member#: 71665
South East
Vehicle:1994 Impreza White |
Hey guys, this is a really helpful thread but I wish there was a whole ej207 forum.
I recently completed a V8 EJ207 swap into my 94 Impreza. Before the EJ207, I already had a 2003 USDM EJ205 installed with a merged harness and a GD WRX cluster. I had that setup for a few years and everything worked great. Now that I swapped the EJ207 and V8 ECM in, my Check Engine Light does not work. The only changes I made to the harness were to wire in a patch wire harness for the AVCS and rewired the TGV wires for AVCS on the other side. Any ideas? |
ej207 owner wants opinions | adbramsay | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 02-26-2011 07:29 PM |
Ej207 V6 | AndrewFD3 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 06-03-2010 04:53 PM |
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? | L'frise | Private 'Wanted' Classifieds | 7 | 06-03-2010 09:24 AM |
08 ej207 JDM dual AVCS heads on a built v7 ej207 | icev7 | Built Motor Discussion | 17 | 02-21-2010 03:21 PM |
Ver 8 EJ207 Owners Check In | spoolinsuby | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 21 | 10-17-2005 01:56 AM |
