Tire & Wheel Forum sponsored by The Tire Rack |
05-01-2014, 06:51 PM | #276 | |
Member#: 387455
E. Canada
Vehicle:2010 STI Hatch Satin White Pearl |
05-13-2014, 10:56 PM | #277 | |
Member#: 386586
E. Canada
Vehicle:2013 Impreza Red |
Answer found : 28811 AC020 Last edited by Laphroaig; 05-16-2014 at 12:29 PM. |
05-14-2014, 11:46 AM | #278 |
Member#: 97135
NWIC
05-14-2014, 06:58 PM | #279 |
Member#: 386586
E. Canada
Maybe I wasn't clear enough, I'm talking about the center cap :
And 10 YO CS is very good... |
05-19-2014, 10:33 PM | #280 |
Member#: 92646
Vehicle:MY03 WRX Toaster Silver |
05-21-2014, 12:37 PM | #281 |
Member#: 390609
do the
2002-04 WRX BBS option Size: 17x7" Offset: +55 Bolt pattern: 5x100 Wheel Weight: 15 lbs. (forged) OEM-equipped tire size: 225/45R17 fit a 2006 wrx with 24mm whiteline sways and endlinks in front and a whiteline 22mm rear sway with endlinks as well? |
05-21-2014, 09:28 PM | #282 |
Member#: 369168
Vehicle:2005 92X Aero 02 WRX, 06 OBXT |
Here's another set
2001-2003 H6 Outback Size: 16x6.5" Offset: +48 Bolt pattern: 5x100 Wheel Weight: 19.6 lbs |
05-22-2014, 12:35 AM | #283 | |
Member#: 97135
NWIC
05-27-2014, 08:05 PM | #284 | |
Member#: 4083
NESIC
Vehicle:2018 OB 3.6R Limited magentite gray |
06-22-2014, 01:34 AM | #285 |
Member#: 181973
I found the Crosstrek Rim Weight is approx 23lbs. It's not super accurate because I weighed it with the tire on (48lbs) and subtracted the stock tire weight of 25lbs. Hope this helps.
06-22-2014, 01:40 AM | #286 |
Member#: 181973
I think the 2012 Impreza Sport Rim to weigh approx 21lbs. Not super accurate because it was weighed with the tire on. The total weight was 42lbs and the tire's weight I had on there is listed at 21lbs so I'm guessing that it should be around 21lbs.
06-22-2014, 03:01 PM | #287 |
Member#: 355273
Vehicle:1998 Impreza Outback Black |
Thanks, this really helps me out!
06-23-2014, 09:28 AM | #288 | ||
Member#: 12029
I have used up all my image allowances in the initial posts, so I can't post any more wheels there until I combine some of the images, which takes time and work. (If anyone has the time and skills, I'd be grateful...) --Dan Mach V FastWRX.com |
06-26-2014, 12:51 PM | #289 |
Member#: 394659
Great thread, thank you
07-16-2014, 11:28 PM | #290 | |
Member#: 349400
Vehicle:2018 WRX Limited WRB |
PM'd you about these - looking for some pics of these wheels on the wrx (non sti) Sent from my iPad using NASIOC |
08-05-2014, 12:00 PM | #291 |
Member#: 398211
subaru forester 2.5i
Sorry if I'm in the wrong thread. I need help finding out what wheel cleaner is safe for my 2014 subaru forester 2.5i with all weather package. They look like they are painted but I'm not sure. Thanks
08-05-2014, 01:01 PM | #292 |
Member#: 68933
Vehicle:2023 WRX 6mt Solar Orange |
I'm seeing conflicting info on the bolt pattern for the 2015 WRX... is it 5x114 or 5x114.3 ??
Nevermind, apparently they are one in the same according to Tire Rack... Last edited by brad21; 08-05-2014 at 02:18 PM. |
08-05-2014, 04:46 PM | #293 | |
Member#: 97135
NWIC
Simple green works great, I really like this stuff - http://www.autogeek.net/mg10801.html its 5x114.3 but we use shorthand. |
08-12-2014, 11:54 AM | #294 |
Member#: 69459
Vehicle:2015 2.0 hatch crystal white |
offset on crosstrek rims
hi dan,
i'm confused on page 1 you list the crostrek rims as a +48, but these guys say +20 cars101.com and i seem to recall somewhere else listed them as +53 (i did a quick search and couldn't find it) does anyone have these, and are able to measure? i'm interested in putting them on my '14 narrow body, but need to know if how much poke i would get (may need to buy the xv flares to cover - i plan to raise the car about 0.5 front and 0.75 rear - give it a lowered crosstrek look ) |
08-12-2014, 12:12 PM | #295 | |
Member#: 97135
NWIC
They most certainly are not +20. They most certainly are +48. |
08-12-2014, 03:34 PM | #296 | |
Member#: 69459
Note: always consult your local dealer before purchasing any tires or wheels and with any questions this unofficial information should not be used for tire, wheel purchase decisions or vehicle speed or weight capability subject to change and correction without notice this is a cut and paste from the site i linked (the high light is mine) 2014, all models p225/55R17 95h M+S Yokohama Geolander G95 all -17x7 j alloy, offset 20 (0.79), PCD 110 (3.94) am i just not reading this right? |
08-12-2014, 03:38 PM | #297 |
Member#: 159474
NESIC
Vehicle:2017 Impreza Sport Lithium Red - OLDKID |
That can't be correct: 5x110 bolt pattern? 225 wide tires? Okay, maybe the tires are that wide, but no way the Crosstrek has that bolt pattern.
08-12-2014, 03:50 PM | #298 | |
Member#: 97135
NWIC
Not sure where in the page you're finding that - and http://www.cars101.com/subaru/crosst...strek2013.html doesn't mention offset at all. I have a crosstrek sitting in my driveway. |
08-12-2014, 03:51 PM | #299 |
Member#: 69459
good point. i think cars101 must be mistaken on this one.
and i don't have a crosstrek sitting in mine Last edited by nfisheremti; 08-12-2014 at 03:52 PM. Reason: added comment about xv |
08-12-2014, 04:07 PM | #300 | |
Member#: 69459
but you can see my confusion |
WTB : Alloy WHEELS or nicer oem subaru wheels to replace my ugly steel wheels | MR2fanatic | Tri-State Area Private Classifieds | 7 | 04-03-2011 09:24 PM |
WTT: OEM subaru wheels/tires for Gold 17" wheels | veselik3 | NWIC Private Classifieds | 2 | 05-16-2006 03:24 PM |
gauging interest: rs 16x7 gold wheels 5 spoke oem subaru wheels | anthonyrb98 | Private 'For Sale' Classifieds | 53 | 04-27-2006 12:43 PM |
Anyone have a set of OEM WRX wheels they want to get rid of? | Skibum4444 | North West Impreza Club Forum -- NWIC | 2 | 01-31-2003 12:48 AM |
Subaru Wheel Specs | Snowrider | Brakes, Steering & Suspension | 3 | 10-07-2001 09:20 PM |
