Welcome to the North American Subaru Impreza Owners Club Saturday May 25, 2024
Old 04-14-2024, 08:22 PM   #126
SamsMK
Member#: 481225
I will say that this post is overwhelming, but I want to know if anyone with 2015 Still/ Harmon Kardon has done the CarPlay swap and retained all functionality? I want to do this when I get back to the states.
SamsMK is offline   Reply With Quote
Old 04-17-2024, 04:54 PM   #127
protivakid
Member#: 265148
2016 WRX
If you think this is overwhelming look at my crosstrek conversion post haha. That said yes everything should work as it does in your 2015 if wired up correctly.
protivakid is offline   Reply With Quote
Old 04-27-2024, 09:56 AM   #128
caffale
Member#: 368559
2017 WRX Limited
Hi, sorry to resurrect an old thread. I have a 2017 wrx that I have swapped a 2020 head unit (86431VA660) into. I have a 2.1a USB charger installed in the center console. Everything works, except CarPlay/AA. It doesn't seem like there is USB connectivity between the USB module and the head unit when I go into the diagnostic mode, however my phone charges when it's plugged into the USB module. Any insight here?
caffale is offline   Reply With Quote
Old 04-28-2024, 10:53 AM   #129
protivakid
Member#: 265148
2016 WRX
What is the part # on the 2.1a USB module you picked up? My best guess is it's newer and perhaps has the pin mapping changed like I found when I converted my sister's base Impreza in this thread here: https://forums.nasioc.com/forums/sho....php?t=2944986
Old 04-28-2024, 05:09 PM   #130
caffale
Member#: 368559
2017 WRX Limited
I am 99% sure itís 86257SJ131. I have tried swapping pin 5 and 6 with no change.
Old 05-01-2024, 12:35 PM   #131
protivakid
Member#: 265148
2016 WRX
I am 99% sure it's 86257SJ131. I have tried swapping pin 5 and 6 with no change.
I'd verify the exact part number on the piece before spending time troubleshooting too much else. I wouldn't be surprised if Subaru changed it for even newer years. If they did, TechNet should give you access to any newer factory service manuals for $35.
Also make sure you are using a 10gbps usb-c DATA cable, not just a charging one. https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
