09-11-2009, 01:30 AM | #1 |
Member#: 56761
Vehicle:9599 EJ255 EJ257 GC8 Rally Blues |
Will Legacy B4 Run w/ Suzuka Big Boys?
Legacy GT B4 at Fuji.. test runs...
Dammit, where are the subtitles..!!???? See specs/pics Below
09-11-2009, 01:32 AM | #2 |
Member#: 56761
Get a load of the engine bay.. anyone see a Flat 4 in there...?
09-11-2009, 03:39 AM | #3 |
Member#: 115154
Vehicle:2005 Outback XT White on grey |
like that thing even looks like a legacy to begin with...looks like they took a page out of NASCAR with that thing.
09-11-2009, 09:51 AM | #4 |
Member#: 4021
NESIC
Vehicle:1999 Legacy GT Ltd Quick Silver Metallic |
That's a Legacy ?
No, I don't think so. It is a racing car with a Legacy "grill" and legacy style headlights stuck in front. It is, however, far more sophisticated than your average NASCAR clunker. |
09-11-2009, 04:11 PM | #5 |
Member#: 32503
TXIC
Vehicle:2011 Tribeca 1995 Legacy Wagon |
What kind of motor IS that then?
09-11-2009, 07:56 PM | #6 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
09-11-2009, 10:14 PM | #7 |
Member#: 4021
NESIC
NASCAR is a spec series with tubular space frame construction, and 1970ies vintage motor technology (cast Iron block, push rods and carburetor). There are no electronic sensors, or Electronic Control Modules. While in order to be competitive in the series, the teams spend millions of dollars and man-hours developing and fine tuning the setups for each track that the cars run on, the truth is that the production cars that the NASCAR "clunkers" are supose to based on are actually more sophisticated as they have alluminium-alloy engine blocks, fuel injection and utilize more moderen Electronically Controlled fuel/air mixtures, ignition timing, and even in many cases electronically controlled (AKA "drive-by-wire") throtles.
While these NASCAR clunkers are exceptionally fast (even if they do resort to using "restrictor plates" on the super-speedways) and for the most part extremely safe vehicles, much of the technology in them hasn't changed a whole lot over the past 35+ years. Clearly this "Legacy" race car uses far more advanced technology than your average NASCAR clunker. |
09-11-2009, 10:17 PM | #8 |
Member#: 4021
NESIC
09-12-2009, 12:19 AM | #9 |
Member#: 56761
Why not the H6..? Could be in there... ??
Here are the Real Specs: Super GT GT300 Subaru Legacy B4 Specifications Length/width/height 4730mm (186.2-in.) / 1920mm (75.6-in.) / 1210mm (47.6-in.) Wheelbase 2750mm (108.3-in.) Unladen weight 1275kg (2811 lbs) Engine 16-valve DOHC EJ20 type Boxer w/restrictor-equipped turbocharger Displacement 1994cc Maximum output/torque Over 300ps/over 40kgfm (289.3 lb/ft+) Transmission Six-speed sequential Tires Yokohama 280-710 R18 (racing slicks) Steering Rack and pinion (power assisted) Brakes AP Racing (front: six-piston, rear: four-piston) Brake pads Project Mu Chassis Production chassis w/carbon upgrades Drive system Front-engine, all-wheel drive (Subaru Symmetrical AWD) Suspension Front/Rear: double wishbone Oil Motul Chemicals ThreeBond Windshield wipers Aeroblades Seat Recaro Safety harnesses Takata Rearview monitor Viewtec Battery Deka Super GT GT300 Subaru Legacy B4 Specifications Length/width/height 4730mm (186.2-in.) / 1920mm (75.6-in.) / 1210mm (47.6-in.) Wheelbase 2750mm (108.3-in.) Unladen weight 1275kg (2811 lbs) Engine 16-valve DOHC EJ20 type Boxer w/restrictor-equipped turbocharger Displacement 1994cc Maximum output/torque Over 300ps/over 40kgfm (289.3 lb/ft+) Transmission Six-speed sequential Tires Yokohama 280-710 R18 (racing slicks) Steering Rack and pinion (power assisted) Brakes AP Racing (front: six-piston, rear: four-piston) Brake pads Project Mu Chassis Production chassis w/carbon upgrades Drive system Front-engine, all-wheel drive (Subaru Symmetrical AWD) Suspension Front/Rear: double wishbone Oil Motul Chemicals ThreeBond Windshield wipers Aeroblades Seat Recaro Safety harnesses Takata Rearview monitor Viewtec Battery Deka |
09-12-2009, 01:18 AM | #10 | |
Member#: 120
AKIC
Last edited by Patrick Olsen; 09-12-2009 at 02:02 AM. Reason: No need to be such a meanie. |
09-12-2009, 11:04 AM | #11 | |
Member#: 115154
09-12-2009, 11:15 AM | #12 |
Member#: 36735
Vehicle:99 GF8 Impreza 2.0 2= 1998 BD + BK Legacy GT |
Wow, they have a 2.0 engine stuffed in there? Anyone else pause the vid when they took the hood off - how LOW is that engine in there - it's almost like the transmission stubs are lower than the center holes for the wheels.
09-12-2009, 07:15 PM | #13 | |
Member#: 4021
NESIC
Tyre technology certainly has changed a great deal. The technology in terms of car set up and in motor preperation certainly has changed a great deal. Today teams of thirty plus people armed with laptop computers spent hundereds of man hours every week fine tuning setups for next weekends race. Thirty plus year ago most teams concisted of 8-10 people, motors and transmissions were run until they broke and maybe 3-4 people worked on these motors when they did eventually die. Back then they actually did use production engine blocks, and their motors typically didn't rev higher than 6,500 RPM for any length of time. Today, motors are changed for every race, and they typically run around ~8,500 RPM. The engine blocks while they are suppose to be based on a production block, are specially cast and machined. Toyota doesn't even manufacture a production cast iron V8. The top teams have engine shops of 30+ people who work night and day, dyno testing new engines experimenting with dyno simulations just how much stress one of their motors can take with out breaking. The second tier teams typically purchase motors from the top tier teams. Yes, teams are larger and they work much harder dialing in proper setup. However in NASCAR the basic technology has not changed in 30+ years. I happen to have an excellent understanding of what top level motor sports involves. Or at least I *think* I do. |
09-14-2009, 11:39 PM | #14 |
Member#: 56761
Hmmm, tire technology....
So what happened to Bridgestone? Seems they need a clue on this technology!
i would like to see the B4 GT run in Sepang, or Okyama .. w/ those twisty turns. :roOL:: |
09-15-2009, 02:09 AM | #15 |
Member#: 176626
International
That car would look awesome in my driveway!!
09-15-2009, 02:33 AM | #16 |
Member#: 56761
^ ^ Ohh My, I love this pic...! ^ ^ Last edited by krylon; 09-15-2009 at 03:53 AM. |
09-15-2009, 02:35 AM | #17 |
Member#: 56761
09-15-2009, 02:39 AM | #18 |
Member#: 56761
09-15-2009, 02:57 AM | #19 |
Member#: 133676
NESIC
Vehicle:2005 WRX Aspen White |
SWOOOOON
09-23-2009, 12:14 AM | #20 |
Member#: 56761
exhaust
Any one else catch the exhaust sent thru.. right under the left headlight..?
09-23-2009, 01:25 AM | #21 |
Member#: 115154
it's a pretty common area, shorter the pipes the better. But only if there aren't noise restrictions at the track theyre running.
09-28-2009, 12:15 PM | #22 |
Member#: 8048
International
You guys aren't missing too much by not having subtitles. Both drivers are saying the typical things you'll hear from them about a new race car.
09-28-2009, 01:02 PM | #23 |
Member#: 199588
Vehicle:2008 Legacy GT OBP |
Holy crap! That thing is mean lookin.
09-29-2009, 02:36 AM | #24 |
Member#: 86291
NESIC
Vehicle:'97 LegaSTi-2.5XTR '96 BrightonCoupeWRX-SR30 |
pre order?
10-02-2009, 01:01 AM | #25 |
Member#: 56761
more pics
will my 91 legacy ecu run without the knock sensor hooked up? | bobturismo | Engine Management & Tuning | 11 | 03-06-2004 04:05 PM |
1820 big boy at little boy price | IA Performance | Private 'For Sale' Classifieds | 6 | 08-05-2003 04:26 AM |
You want the Legacy B4, Legacy Turbo, or Six Cylinder? | BigElm | News & Rumors | 29 | 04-11-2002 06:48 PM |
Need a bigger turbo to run with the big boys!! | bottlefedwrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 26 | 10-05-2001 03:44 PM |
FS: JDM Legacy B4 grill with a red B4 emblem | yuji | Legacy Forum | 7 | 10-04-2001 12:40 PM |
