09-20-2012, 10:18 PM | #1551 |
Member#: 152036
E. Canada
Vehicle:2005 Sti Wrb rhd |
The rears are more cups then perches so the plates sit right in them
09-20-2012, 10:38 PM | #1552 |
Member#: 95901
Sorting through the shed I found an old sin I never weighed properly:
Green Brackets of Death and hardware weight from a 2004 WRX. Whopping 2.130 kg*. *Yes, I tared out the old sign on which the GBoD sit. |
09-22-2012, 10:39 PM | #1553 |
Member#: 176134
SCIC
Vehicle:1995 Coupe, Sedan & Wagon! |
Final weight - 6 lbs shaved 16.5 pounds off |
09-23-2012, 01:19 PM | #1554 |
Member#: 95901
Nice bue. What is the diameter and wall thickness of the main tube? Mild Steel? DoM?
09-23-2012, 01:48 PM | #1555 |
Member#: 176134
SCIC
sheeiittt.... ill have to ask.
09-26-2012, 05:22 PM | #1556 |
Member#: 95901
Installed Turn In Concepts Giuyngmyo Fender Cowl Braces.
Giuyngmyo: 758 grams. OEM: 571 grams. Installing these on a wagon was a bitch. Resorted to taking off both fenders so I could get my big fat hands in there. Gained 187 grams , but my front's stiff. |
09-26-2012, 05:54 PM | #1557 |
Member#: 176134
SCIC
i would hate to weight braces. probably 1.5 pounds each LOL
...i should just for ****s n giggles. |
09-26-2012, 07:01 PM | #1558 |
Member#: 95901
Damn Bue. Those look beefy. 1.5 lb? I'd say 1.5 kilos.
09-26-2012, 07:46 PM | #1559 |
Member#: 190502
International
I have the TIC fender braces too, if you consider the amount of mud and crap I dug out from behind the lower rear fender liner whilst installing them I'd say they didn't add any weight
10-03-2012, 08:20 PM | #1560 |
Member#: 95901
I'm preparing for a local HPDE and wanted to remove a bit more. I plan on taking out the rear seats and the passenger seat for the event.
Rear WRX Wagon 60/40 fold down seats w/o headrests 18.42 kg. Removed for HPDE only, you haters. Also plan to leave all of the cargo area padding and cover behind. 4.08 kg. I'll put all this back in after HPDE. The reason I had the seats out was to get at rest of the child safety seat anchors from the Right Rear. 451 grams Removed. |
10-03-2012, 10:04 PM | #1561 |
Member#: 176134
SCIC
you should have saved all your scrap metal, and smelted it into a mini subaru version of your wagon LOL
10-05-2012, 12:59 PM | #1562 |
Member#: 95901
You're not far off. I have about 85% of the metal I cut off stored in my shed, labeled, and bagged. I think I've a sickness.
On topic: OEM WRX Momo Steering Wheel with SRS and cruise control stick: 2938 grams. The extra 22 grams came from other parts. Bell Works Short Hub 116 for GD Subarus: 285 grams OMP Corsica Steering Wheel, Smooth Leather, 350mm (OD/1956/N): 1007 grams. Removed 1.646 kg. The Bell Works Hub and OMP wheel has to be one of the easiest installs I've done in recent memory. I think I was done in 30 minutes. Probably took just as long to take the photos, write this post, add, and store the old parts. Also the OMP wheel is one high quality unit. The leather is perfect and stretched just right around the whole wheel. The stitching and glue: impeccable. I'm also glad I went with the 350mm large diameter and smooth leather. Honestly I wish they made a 375mm or 400mm wheel. The 350mm feels small compared to the OEM. |
10-05-2012, 01:03 PM | #1563 |
Member#: 176134
SCIC
dude turn that into a mini car LOL
Make a mold from a model car, fill with metal! |
10-05-2012, 01:35 PM | #1564 | |
Member#: 174294
Vehicle:02 WRX , 2013 FXT VF30 Stage 8 billion |
doing that is more like reorginizing the weight. Some might say that the battery should be inside the passenger area on the floor , but i the having it on the trunk would have a greater effect on the front to rear weight ratio which will also help handling. |
10-05-2012, 01:45 PM | #1565 |
Member#: 99102
South East
Vehicle:17 BMW M2 Long Beach Blue 6MT |
Just a few notes from my past experience: These cars are really not heavy. When your car weighs about 3800 without you in it... thats heavy. I just got out of an 06 GTO and stepped back into a subaru and this car is waaaaay more light and agile. My car was a mild bolt on car that did 380/385 and that thing hauled ass even weighing over 400lbs with me in it! I see a lot of people are pulling their interior, taking off door pieces, changing the steering wheel and for what? 30lbs? It doesnt make that much of a difference and for the way the car is slowly getting destroyed, its not really worth it.
You can do a few things to these cars that are key and can save a good amount of weight off the drivetrain - carbon fiber driveshaft, light flywheel, pulley, rotors, and wheels/tires. These should be the main focus. |
10-07-2012, 09:43 AM | #1566 |
Member#: 152036
E. Canada
Subarus don't like lighter fly wheels nor pulleys
And most of the stuff caddy took of his car is nothing you even see If you think saving a few hundred lbs does nothing ur crazy |
10-08-2012, 01:35 AM | #1567 | |
Member#: 98955
Vehicle:2011 WRX Hatch White |
Let's face it...you can strip all the creature comforts from your car and get your perfect balance and all that...and in the end a stock GTR will spank you with minimal effort. |
10-08-2012, 01:56 AM | #1568 | |
Member#: 176134
SCIC
10-08-2012, 02:05 AM | #1569 |
Member#: 194132
Vehicle:2009 WRX Sedan SSM |
pffft.... it's win win if you don't have friends and your girlfriend is tiny.
10-08-2012, 06:13 AM | #1570 | |
Member#: 158864
Vehicle:2003 SOHC destroker |
then again you don't drive around tracks with your fat friends in the car do you? and saying that people who think saving hundreds of pounds does a lot are crazy? you=clueless |
10-08-2012, 06:30 AM | #1571 | |
Member#: 271525
Vehicle:7/2 STi/WRX wagon SWP/AW |
10-08-2012, 01:22 PM | #1572 | |
Member#: 152036
E. Canada
Also if I had 120 gs to throw away I'd put it in the suby and spank all a$$ And yes in Canada the gtr is 120 gs |
10-08-2012, 01:38 PM | #1573 |
Member#: 174294
http://www.motortrend.com/roadtests/...91&188,shopper
So the GT becomes a GT-R. The world's fastest sub-$100,000 car; $75,000 to $80,000 is the likely price range 3.8L/480-hp/434-lb-ft twin turbo DOHC 24-valve V-6 Curb weight 3836 lb (mfr) power to weight=7.999999etc. PERFORMANCE (C/D EST): Zero to 60 mph: 3.5 sec Standing ¼-mile: 11.7 sec http://www.google.com/url?q=http://w...5XZmZhfkLdOO2Q http://www.google.com/url?q=http://w...AEmjCAQoW7Pctg http://www.modified.com/features/061...x/viewall.html You can also youtube time attack of Opera's cars against other tuners , to note that shop doesn't increase power just decrease weight. You can also do your own math on how to get a subaru to match the GT-R's perfomance and power to weight ratio . granted not everyone will do that or track there car but this thread is for pro-weight reduction if your anti-weight reduction please use facts and figures at least. |
10-08-2012, 08:50 PM | #1574 |
Member#: 190502
International
GTR is a heavy and expensive car compared to an Impreza, a guy in our club has one and has to replace a set of $1300 rotors after every track day. Sure its fast, like amazingly quick around the track, but you got to pay if you want to play.
10-08-2012, 09:50 PM | #1575 |
Member#: 176134
SCIC
he should have opted for the 50k carbon brakes and saved weight too!
Similar Threads | ||||
Total weight reduction or F/R weight distribution more valuable? | soslow | General Community | 17 | 12-11-2007 12:40 AM |
('93-'01) Weight Reduction Questions | subarumantoo | Impreza Forum | 5 | 05-01-2001 11:02 AM |
Some interesting facts about weight reduction | Imprezer | WRX Forum Archive | 5 | 02-25-2001 10:33 PM |
2.5RS Weight Reduction info and questions. | Frank | General Forum Archive | 21 | 02-16-2001 12:53 AM |
