05-08-2003, 01:07 AM | #1 |
Member#: 25905
SCIC
Vehicle:2003 Silver Wagon Tuned with Enginuity |
Best way to route wires on column mount boost gauge?
I just got my Autometer boost gauge and cup. The install looks straight forward enough, but I'm not sure where the best way to route the power and boost hose behind the dash.
I want to keep it looking as clean as possible! Anyone have pics showing the cable routing?
05-08-2003, 02:46 AM | #2 |
Member#: 16171
Vehicle:2002 WRX Wagon Race car blue/Gold wheels |
The factory option cup and guage have the wires/hose routed with a 1/4-1/2" black plastic corregated hose. I put an Omori guage in the stock cup and kept this routing, looks clean.
05-08-2003, 03:51 AM | #3 |
Member#: 25905
SCIC
Yeah, but do you have a side/angle pic so I can see where they route the corrugated hose? Do they just run it over the back of the steering column under that bit of rubber?
BTW, still enjoying the ECUTEK Jefe? |
05-08-2003, 08:18 AM | #4 | |
Member#: 25254
Vehicle:2003 WRX wagon |
05-08-2003, 10:12 AM | #5 |
Member#: 15106
yep, under the cluster rubber shield and above the steering column. should be a very clean setup.
05-08-2003, 11:24 AM | #6 |
Member#: 25905
SCIC
Thanks guys. I'll take some pics when I'm done to show it off. Hopefully the results will be show worthy.
05-08-2003, 02:52 PM | #7 |
Member#: 5238
Vehicle:GGA Black |
that's what I did thru the steering column. for power, I tapped into the fuse box vs. the stereo.
05-08-2003, 03:13 PM | #8 |
Member#: 16697
South East
Vehicle:2004 2.5 Hybrid 18g Wagon + LGT 1-4 g00dness! |
This is what mine ended up looking like..
05-08-2003, 04:13 PM | #9 |
Member#: 16906
Vehicle:2k3 wrx wagon PSM |
what kind of cup is that and where did you get that corregated hose from? looks real nice!
05-08-2003, 05:27 PM | #10 |
Member#: 16171
Sorry no pix from me Drees, I'm old and stupid and I don't know how to use these electrical thingees too good yet.
I luv the EcuTek, and Shiv has been admitted into my Suby hall of fame. Just finished a 3,000mile run with a full load and my car flies and get's good MPH ! Let's hook up at the Kart-Kave soon...Jefe' |
05-08-2003, 05:45 PM | #11 | |
Member#: 25905
SCIC
imprezive one: You can pickup the corrugated hose from either your local auto-parts store or even electronics stores (like radio shack) might have them. |
05-08-2003, 06:24 PM | #12 | |
Member#: 16697
South East
Edit: It requires some 'custom engineering' for it to work, but it will. You can find split-loom at nearly any autoparts store, wal-mart, target, etc.. Look for the electrical supply section. |
Firewall access question: best way to route a 0.75" coolant line to the trunk? | scooterforever | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 07-07-2008 11:26 PM |
column mount boost gauge | Wreqs | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 07-07-2001 11:35 PM |
Got my column mount boost gauge installed! | gpxl | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 18 | 07-01-2001 12:29 PM |
Steering column mounted boost gauge | OsakaGangsta | Interior & Exterior Modification | 3 | 05-29-2001 05:21 PM |
