07-13-2012, 09:29 PM | #101 |
Member#: 317404
Hi Guys,
I have followed the pulley discussions on many forums over the last 20 years. IMHO, The discussions come down to two things. 1. Lots of theory and text book explanations of how different types work. Which is good. Lots of mis-understanding out there. 2. If someone has bearing issues, they look for something to blame it on (right or wrong). If the crank had a lightweight pulley, that must be to blame ! ! ! Human nature AND not necessarily wrong. OTOH, In a Mazda Miata forum it was commented that a ltwt undampened pulley didn't cause any issues unless there was also an aftermarket turbo kit installed. So, here is my 2 cents and a discussion point. Is it a detonation issue? Does a heavier and or dampened pulley help when there is increased detonation due to other causes? If there is no detonation problem are there no pulley concerns? I can see that the additional weight would keep the crank from pounding the bearings. Any thoughts? John
09-18-2012, 04:57 PM | #102 |
Member#: 295516
SCIC
Vehicle:2004 WRX Silver |
Was wondering if any of you who run the light weight pulley notice a drop off in power with the A/C on? I know all cars lose power as the the A/C kicks in pulling power to it's own belt, but my wrx just plain dies.
My theory is with a lighter crank pulley the A/C belt slows it down a bit more compared to if it had a heavier(stock) pulley generating more momentum. That or I could be way off base with my car, it just seems my car loses a significant amount of power with the A/C blowing. |
05-11-2013, 09:06 PM | #103 |
Member#: 356037
NESIC
Vehicle:06 WRX TR Obsidian Black Pearl |
Thank you. Perfect info!
05-15-2013, 01:15 AM | #104 |
Member#: 355766
You are a true guru, a master at presenting information.
01-07-2014, 10:58 PM | #105 |
Member#: 377887
Vehicle:2004 Impreza WRX San Remo Red |
Hey Unabomber, i have a aftermarket lightweight exedy flywheel and clutch its still stage 1. And According to exedy's website its a OEM replacement part's. So the question i am getting at is, if my tranny is lighter than stock and i install a aftermarket lightweight pulley(i am looking at grimmspeeds 2.2lbs pulley) will that lack of rotational mass be a problem? Like you said the solution would be to re install the OEM pulley if there was a problem, but i am having trouble finding information on light weight trannys with lightweight pulleys. Thanks for the help
01-08-2014, 08:02 AM | #106 |
Big Ron
Super Moderator Member#: 18062
The core of the problem, after years of guesswork is in the lightweight flywheel itself. They can cause missfire CELs. Adding a lightweight pulley now or later will not affect this. So if you are not throwing a missfire CEL now, the lightweight pulley addition should not affect it. Some cars will not throw a CEL with a lightweight flywheel though so its a hit or miss thing. If you want a lightweight pulley, send me a PM with a pic of a hot chick and I can get you a source for a discounted one.
01-08-2014, 08:57 AM | #107 | |
Member#: 377887
01-25-2014, 12:23 AM | #108 |
Member#: 114502
SCIC
Im dealing with an issue on my 2004 STi.
My crank pulley seems to be moving forward and it has a lot of "play" to it. I found out when I was replacing my belts. My AC belt was completely off the drive pulley and the other belt is a bit aged. We replaced them with the Gates Blue belts. Upon start up, the AC belt started jumping off the pulley again. Thats when we noticed the crank pulley was being pushed forward and a lot of the rubber thats on the inside of it was chipped off and worn. From what I have been reading the crank pulley is just that...a pulley. People are calling it a harmonic balancer but ive read that its NOT that. Just the pulley. Did Subaru change that in 04? Because I can see the rubber inside the pulley..if that makes sense.. |
01-25-2014, 01:28 AM | #109 |
Member#: 378161
RMIC
Vehicle:2013 STI sedan white |
nice write up
07-02-2015, 09:27 PM | #110 |
Member#: 424862
My engineering buddy scanned a stock crank pulley and then modeled his own super light weight underdrive pulley. I asked how much power it would save and he didn't know so we did the calculations. Essentially it takes no horsepower to spin a pulley at constant speed but it does take power to accelerate it. The actual horsepower is based on a lot of things but the difference between two is all based on the moment of inertia. With 3D modeling software it gives us accurate moments of inertia. His pulley has a 22 times lower moment of inertia. WOW! So then we calculated how much power a stock pulley uses if accelerating from 2500 rpm to 6000 rpm in 3 seconds.... Less than half a horsepower. So his uses 22 times less than half a horse power so yes it makes a difference but no it's not enough to notice. You will notice a difference in reving and shifting when the engine is out of gear because that happens in a much shorter time.
I'm curious as to the claim in the initial post of a 5 to 10 horsepower gain. It doesn't seem possible. Does anyone have any dyno curves to show this along with a list of what all was changed? I haven't found any in my searching over the last couple days. |
07-02-2015, 11:25 PM | #111 |
Big Ron
They were dyno'd back in the day, but I'm sure the plots are long gone. I did see them though....promise!
06-11-2016, 09:28 AM | #112 |
Member#: 338431
I read the complete topic. Power gains in the range of 5-10hp is possible. Check a dyno from a FA20 engine which adds almost 10hp:
Nowadays, even reputable engine builders sell lightweight pulleys. Last edited by nikitopo; 06-11-2016 at 09:42 AM. |
07-30-2016, 04:01 AM | #113 |
Member#: 451523
So is this why all the fancy after market pulleys dont have rubber in them ?
07-30-2016, 12:41 PM | #114 |
Member#: 450925
International
Vehicle:2017 Subaru Wrx STI Crystal Pearl White |
Harmonic Balancer
Ok, from my experience on working on LS motors, in particular to Ls2 and ls3 engines when I personally upgraded the under drive pulley (Harmonic Balancer) or in Subaru terms a (Drive Pulley) It does the same thing as a harmonic balancer but not exactly the same thing.
They both supply power to the alternator and electrics, very true. But what happened to me is when I got one of these forged name branded pulleys it basically didn't supply enough volts to the battery causing it to degrade and or die. This is what happened to me, it sucked so bad because it happened on my ls2 and ls3 engine. Then I gave up and bought a Subaru... planning on keeping it stock as I've learnt the lesson on modding. If you have not got the money to blow on defects due to the modification's then don't do it. Like me. But I did gain 7hp with that harmonic balancer so they do work. But what I suggest as someone that has lost a lot of money on modding is just stick with the oem stuff. Most Subaru wrx's and Sti's are driven as a daily driver and not a race car, so just use the oem stuff as it's been tested and it's been used for what? The past 8 years in the same engine? That says a lot. I just feel it's a safer bet. But hey, it could be fine modding the wrx's what do I know coming from the LS series engine's. |
07-30-2016, 12:45 PM | #115 |
Member#: 450925
International
If it starts to jump get a smaller belt and bring out the heat gun and blow on it. Make it really hot and then mold it to the pulley. This is what I did and it worked. Mind you it never jumped on my Ls2 6.0L GM engine after that. But it did not supply enough voltage to the battery. Healthy voltage is 14v but mine was on idle sitting at 11 and when driving sitting at 12 and when pushing it, it did not want to go over 14 which is what is the standard voltage is.
07-30-2016, 04:18 PM | #116 |
Member#: 448972
Good read
08-01-2016, 10:03 PM | #117 |
Member#: 446565
Vehicle:2013 Impreza premium dark blue |
great work!!
12-07-2016, 11:48 PM | #118 |
Member#: 444106
Ive put a grimmspeed pulley on my 03 wrx and now my rpms are high reving and it threw a p5107 idle malfunction fail safe can i reflash for the cel to disappear, could it be the throttle body or air valve. Do you think i will have to uninstall
12-08-2016, 12:24 PM | #119 |
Big Ron
Google knows not what p5107 is, so unless you fat figered it, you have other issues. If you idle is wonky, that is likely a dirty IACV when the sticky threads in the maintenance forum can help with.
01-29-2020, 09:06 AM | #120 |
Member#: 511179
International
Vehicle:2001 Forester 792 Royal silver |
will the lighter pulley make up a bit of rpm loss from a 4eat torque converter?
01-29-2020, 09:15 AM | #121 |
Member#: 70710
Vehicle:2002 04STi Swaped RS w/PPGS & 02 Wagon w/PPGs |
Exhaust FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 318 | 09-06-2021 04:50 PM |
Uppipe FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 396 | 07-09-2020 02:25 AM |
Downpipe FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 338 | 10-25-2019 12:04 AM |
Turbo Timer FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 93 | 06-22-2017 08:29 AM |
