Welcome to the North American Subaru Impreza Owners Club Saturday November 17, 2018
Old 04-29-2018, 06:38 PM   #1
Zbrule
Member#: 453359
Default 17 WRX Idle issue
Put a new motor in my wrx after I blew it up, first start up went great, however I am having idle issues. The idle is staying around 2k-2500 even when it warms up. Currently running a grimmspeed intake, ebcs, and ets exhaust. Any help would be greatly appreciated. Ill link a video of the idle as well.
Zbrule is offline   Reply With Quote
Old 05-04-2018, 02:46 PM   #2
subaru2010
Member#: 484831
2010 Impreza 2.5
My idle issues were related to spark plug, mass air flow sensor, and spark plug wires. Did you check that?
subaru2010 is offline   Reply With Quote
Old 05-08-2018, 04:19 PM   #3
VicPOP13
Member#: 482325
2018 WRX
Did you scan for codes?
VicPOP13 is offline   Reply With Quote
Old 05-13-2018, 11:37 AM   #4
Coltjack
Member#: 485914
My 09 did the same thing I cleaned the MAF and had a vacuum hose from the BPV to the throttle body disconnected may try that and see if it help
Coltjack is offline   Reply With Quote
Old 05-25-2018, 02:35 PM   #5
yoshi717
Member#: 486413
hmmm i have similar issue but i got 97 1.6 L and no mass airflow sensor
yoshi717 is offline   Reply With Quote
Old 05-25-2018, 04:15 PM   #6
subaru2010
Member#: 484831
2010 Impreza 2.5
Engine also needs to re-learn your driving habits. In the non-turbo impreza you can spend 10 minutes getting the engine to re-learn your idle. I don't know if the WRX can do that.
