Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Old 05-10-2018, 12:34 AM   #26
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Originally Posted by subaru2010 View Post
I did take it to a Subaru dealership, but service wanted $3100 for the head gasket job. Then they wanted another $2000 for brakes/rotors/alignment and the rubber suspension parts.
I drove my car away.
Go to your local regional forum and ask there for help looking for a independent Subaru specialist shop in your area.
Iím sure you will get good help and better prices.
Bikelok is offline   Reply With Quote
Old 05-14-2018, 10:16 AM   #27
subaru2010
Member#: 484831
2010 Impreza 2.5
Update: Found an Indie Shop. Price for gaskets was $1700. After taking apart the engine they said the Tensioner which was recently done with water pump was not keeping the appropriate belt tension. Potentially another $170 for the part. Plus a rental which is $42. I'm at under $2000. They said I should get another 120k miles out of the Subaru. I'm so sad.
subaru2010 is offline   Reply With Quote
Old 05-14-2018, 04:27 PM   #28
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Sigh..........
Next time, state you will do work or not.
Your price is likely OK.
As stated before, check fluids, top as needed, go maybe a few years as is.
Yes, maybe tensioner rolled over and died. So be it.
Again, your car, your choice....I will not agree or disagree......
Charlie-III is online now   Reply With Quote
Old 05-14-2018, 05:09 PM   #29
subaru2010
Member#: 484831
2010 Impreza 2.5
Originally Posted by Charlie-III View Post
Sigh..........
I hope the car drives well, does not leak oil, and burn fumes into the vents. Lasts me many more years, 250K miles would be awesome - a first.
I have a 6 month warranty.
Old 05-18-2018, 02:12 PM   #30
subaru2010
Member#: 484831
2010 Impreza 2.5
Update: The shop said the leak was from the fuel return line in the back and bottom of the engine into the head gasket.
Now I wonder could I have just replaced that the fuel return line.
Old 05-18-2018, 02:44 PM   #31
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
So, we have gone from oil leak/failed HG's to a fuel leak.
Most leaks, I do/ask peeps to get the leak on your fingers, rub them together, maybe even sniff the leak to determine what fluid it is.
To peeps I really don't like, I ask them to taste the leak.....
I have not asked you to taste it....yet.
Go back and clean the engine off as I stated before.
Check for leaks.
Fuel leaks smell a WHOLE LOT DIFFERENT than oil or coolant leaks.
Really.
Fuel leak may only need to tighten hose clamps, free other than time to do it.
[looking for my silver spoon...../sarcasm].
Old 05-18-2018, 05:26 PM   #32
subaru2010
Member#: 484831
2010 Impreza 2.5
Check for leaks.
Really.
Well, they said they replaced the head gaskets, intake gasket, valve gasket, oil pan gasket, and cleaned the throttle body. Took 4 days of work/testing. Computer sensors/compression testing/road test.
I know there was oil in cylinder well 1 when I pulled the spark plug wire. Valve gasket was leaking. I really would have liked to know the source of the leak. Now I feel like I did a lot of work that was more preventative, and spent a lot more money.
Old 05-21-2018, 09:42 AM   #33
subaru2010
Member#: 484831
2010 Impreza 2.5
Spoke with shop, they said it was the oil return port on the head gasket. It was motor oil leaking.
