09-17-2012, 04:06 PM | #1 |
Member#: 279660
2011 WRX w/ EWG/FMIC/STGII++ tuned by Tim Bailey
Facility: COBBTuning SoCal
Tuner: Tim Bailey Type of Dyno: Mustang Boost: 16 Fuel: 91 Peak HP at RPM: 326whp Peak Torque at RPM: 337wtq Relevant Power Mods: AEM Cold Air Catless Downpipe Invidia Q300 Catback TurboXS Bypass Valve Tial 38mm MV-S External Wastegate Grimmspeed EWG Up-Pipe COBB 3 Port EBCS DW65C Fuel Pump RacerX Front Mount Here's a cell capture of the plot Tim Bailey is the freakin man, this is the best the car has EVER driven. Couldn't be more happy with the numbers!!! Thanks COBB! |
09-17-2012, 05:23 PM | #2 |
Member#: 310184
Vehicle:2012 WRX Blue Pearl |
What turbo are you running? I can't see you making that much power on the vf at 16 psi on 91. nice numbers though. I have a similar setup with only bigger TMIC and was just curious.
09-17-2012, 05:41 PM | #3 |
Member#: 279660
VF52, stock turbo.
09-17-2012, 07:04 PM | #4 |
Member#: 203347
Vehicle:07 STi Blue |
nice numbers
09-17-2012, 07:40 PM | #5 |
Member#: 134940
Vehicle:2006 Impreza WRX TR vf39 ewg tuned ppg gears |
Nice numbers! But i cant imagine that with only 16psi n 91 oct....
09-17-2012, 07:54 PM | #6 |
Member#: 261612
Vehicle:2002 WRX - 750WHP 9.5s @ 150mph |
At peak power he's around 14-15psi. Just like all the other VF turbo's that are running "22psi!!11!!!". Phatron and Jr did this experiment not too long ago. Results are exactly as you see here. 22psi tapering to 14psi makes more peak torque, but similar peak power to a turbo that is 16psi tapering to 14psi.
09-17-2012, 08:18 PM | #7 | ||
Member#: 279660
yep, thanks man!
09-17-2012, 08:22 PM | #8 | |
Member#: 166005
Vehicle:2005 Saab 92x Beaten Silver |
There are various VF tuning theories, especially to keep them from tapering up so miserablely on 2.5's, but I can't find anything! |
09-17-2012, 08:35 PM | #9 | |
Member#: 261612
http://forums.nasioc.com/forums/show...postcount=4974 http://forums.nasioc.com/forums/show...postcount=4979 The first is the HP curves from the dyno and the second is the logs from the dyno in Virtual Dyno (to see TQ and boost). Junior tuned one with a normal (22psi) curve, and the other with a purposely low boost that didn't spool until very late. He was just trying to prove a point. In the case of besthaticouldo's tune, the reduced peak boost will give a much more linear power response and flatter torque curve. It will pull more smoothly and still have just as much top end as any other VF. I would have gone for more peak boost (because that's fun ), but this tune is probably a very nice one for drive-ability. |
09-17-2012, 10:09 PM | #10 | |
Member#: 166005
09-19-2012, 11:19 AM | #11 |
Member#: 269226
09-19-2012, 03:33 PM | #12 | |
Member#: 310184
09-19-2012, 04:27 PM | #13 |
Member#: 163631
Vehicle:07 Forester XT Dom 1.5XT-R |
Should not make much difference if you are only boosting 16 psi. The benefit of E85 is that you can run more boost without detonation. The point is that VF turbos are not big enough to flow high pressure at high RPM, it is like trying to go fast on a single speed bike.
09-19-2012, 04:33 PM | #14 | |
Member#: 261612
People think you need 22psi peak boost to make this power. The peak boost is completely irrelevant to peak power with a VF turbo. The only place boost matters (in regards to peak power) is right around 5k-6krpm's. A big peak (and then taper) will be more fun and likely faster overall, but it doesn't mean it will have more peak power. |
09-18-2012, 04:39 AM | #15 |
Member#: 203347
thanks
09-18-2012, 09:30 AM | #16 |
Member#: 245218
South East
Vehicle:2013 STI Limited |
16 psi peak? no way.
09-18-2012, 10:01 AM | #17 | |
Member#: 261612
See my posts above. Peak boost gives you high peak torque numbers. Boost at peak power is similar on this car as it is on most "22psi" VF setups. |
09-18-2012, 12:33 PM | #18 | |
Merci Buckets
Moderator Member#: 88606
Vehicle:2018 Grand Cherokee Velvet Red Pearl |
09-19-2012, 08:12 AM | #19 | |
Member#: 203347
09-18-2012, 11:56 AM | #20 | |
Knifey McKniferson
Member#: 188552
SCIC
Vehicle:PM SKIMSTI 4 help installin yur bike chain! |
I am not sure where this boost was measured, pre or post FMIC.... would you believe the graph if he told you it was 17psi? |
09-18-2012, 01:48 PM | #21 | |
Member#: 245218
South East
Let me correct myself. I see 16.4 on the dyno graph. However, the dyno numbers are irrelevant IMO without baseline numbers. That's what I was really getting at. |
09-18-2012, 02:37 PM | #22 |
Member#: 279660
same dyno, 8 months ago i made 306whp/336wtq on 19.5 psi on a stageII protune (intake, dp, CBE, 3port) not tuned by tim, that tune sucked.
09-18-2012, 01:23 PM | #23 |
Member#: 260549
SCIC
Vehicle:'69 Camaro '76XS750 '77CB750 |
Great work! Now get some bigger injectors a boost a pump and run some E85!
09-18-2012, 01:36 PM | #24 |
Member#: 311468
BAIC
Vehicle:'13 STI Hatch |
****ing awesome! I wanna see a video of this bad boy.
09-18-2012, 01:38 PM | #25 | ||
Member#: 279660
i'll get some vids soon, i'll have some autox vids from subiefest for sure. |
