09-26-2010, 01:40 PM | #1 |
Member#: 219497
Vehicle:1997 Impreza L Black |
Internal paint job WAS good
I went out to autozone and picked up some paint. I spent about a week doing the paint job off and on using what i believe to be the appropriate paints, but now the job is chipping. when doing the job i covered all the parts i didn't want to have ruined and took some out, but the dash was a huge problem and i have no desire to do the whole thing in the car again.
A. what kind of paint should i be using for which parts and B. how can i take out the entire dash so as to have better access to it for the job here are some pics of the job so far, still incomplete id=2821http://www.mysubie.com/vehicle?id=2821
09-26-2010, 02:23 PM | #2 |
Member#: 220484
Vehicle:2003 PSM WRX - Sold 2006 RPW STi |
sweet mother of god
09-26-2010, 02:38 PM | #3 |
Member#: 155986
Vehicle:E92 M3 Jerez |
Looks sweet bro.
09-26-2010, 02:44 PM | #4 |
Member#: 145708
South East
Vehicle:2007 WRX TR TopSpeed Built =D |
insert face palm
09-26-2010, 02:45 PM | #5 |
Member#: 257035
South East
Vehicle:2017 WRX/STi Pure Red |
lulz...
09-26-2010, 03:02 PM | #6 |
Member#: 201661
RMIC
Vehicle:2013 STI 2002 Forester |
I think entering a demolition derby might fix the problem
09-26-2010, 03:07 PM | #7 |
Member#: 187179
Vehicle:14 STi Cocain |
u spray painted the seats
09-26-2010, 03:08 PM | #8 |
Member#: 222041
South East
Vehicle:2009 Impreza 2.5i PRP |
Not my thing imo
I've painted mine, BUT I took out the pieces and prepped them well, you got a problem cause unless I'm not seeing it you didn't sand your dashboard (I'm on a cellphone so clarity isn't the greatest) What you should do is take that paint off Cover everything, take your stencail lay it and tape it. Then sand the stencil and apply the appropriate coats. Keep the stencil on after each coat. And remember lightly sand between coats so the paint has something bind with. I also found the krylon seems to work the best for plastics interior plastics, and has been holding up well on my grill exterior as well! Let me know about anything else you did procedurely |
09-26-2010, 03:11 PM | #9 |
Visiting NASIOC Timeout
Member#: 230710
Vehicle:2004 STi John Tuned! 04 AW Shwagon |
09-26-2010, 03:12 PM | #10 |
Member#: 162681
Vehicle:2002 Impreza Wrx Midnight Blue Pearl |
Okay I am not gonna flame. So what you probably didnt do was clean the surfaces 100 percent, then you probably didnt use a abrasive to give the paint something to hold onto. Just something to scuff the surface ever so slightly. Also there is an adhesive promoter that should have been applied to the surfaces right before you painted them. All of these things can be found in your autozone auto paint section.
And no, I dont have the interior of my car painted. |
09-26-2010, 03:41 PM | #11 | |
Member#: 225034
Vehicle:2006 STI WRB |
I dont know what you had as an visioin but i hope that was not it. Man that is nasty if you did not start with a clean surface then you need to start over. use a 50/50 alcohol water mix to clean then prime, paint, sand/scuff, paint. This process should give good results. Also vinly interior, or anything with some flex, is never a good thing to paint. the fabric or material will flex, bend and bow and return to its natural location. the painted layer will not do this. Instead of the paint flexing it will just crack. Last edited by Dave_zok; 09-26-2010 at 03:49 PM. |
09-26-2010, 04:09 PM | #12 |
Member#: 257035
South East
ive painted the interior of a few cars including 3 of my own i've found 220 grit sandpapaer for me works the best.. wash the area first with dawn dishsoap diluted in water so it gets rids of any armor all or grease from other "shine" makers lightly sand, clean again tape off and stencil your design if you cant actually remove your dash (its just easier to remove to prevent overspray and dont have to worry about messing up with your restricted angles and at the end if your using that autozone interior paint i tried and ended up with good results by giving it 1 slight coat of the clear engine enamel to prevent it from cracking in exposed sun
09-26-2010, 04:54 PM | #13 |
Member#: 229396
Now Ive seen it all, i guess im going back to bed.
09-26-2010, 05:06 PM | #14 |
Member#: 212818
Vehicle:2010 Impreza 2.5i Satin White Pearl |
09-26-2010, 05:08 PM | #15 |
Member#: 220259
Vehicle:09 2.5i SSM |
Hahahahahahaha
What exactly is a "DIY momo shift knob" ? |
09-26-2010, 05:16 PM | #16 |
Member#: 134272
HIIC
Vehicle:2007 Sti, UGM Rotated EFR 6758 |
Looks good man. You need to prep your interior pieces before you paint them using sandpaper, google it.
Also... Ensanguined Semblance makes absolutely no sense whatsoever.... Unless the next step is to cover your subie in blood? |
09-26-2010, 05:37 PM | #17 |
Member#: 172486
Vehicle:95 V4 STi-RA swap Stage 49.8 |
Mr. Smoke is crying right now. Not in a good way.
You painted your interior wrong. My entire interior is painted and it's going strong after 2 years. |
09-26-2010, 05:38 PM | #18 |
Member#: 214559
Vehicle:2005 Legacy GT |
I hear you can help the paint cure by lighting the car on fire.
09-26-2010, 05:41 PM | #19 |
Member#: 36838
Vehicle:2001 B50 RSTi Sedan 2011 DGM WRX hatch |
I'd probably re-do it but with more complementary colors vs mixing primary colors.
The combo just makes my retinas vibrate a bit when trying to see one color separate from another. http://en.wikipedia.org/wiki/Color_theory http://websitetips.com/colortools/sitepro/ -- Dave |
09-26-2010, 06:32 PM | #20 |
Member#: 243214
Vehicle:2014 WRX Premium WRB |
09-26-2010, 06:58 PM | #21 | |
Member#: 229396
I used to be in the sporttruck scene, painting dashes was very common, usually we would glass them, but when we didnt do it it was all about the prep work, in face the first truck i ever did back in 98 still looks like new....... wish i had pics of it, but we painted the dash and it ended up looking like the outside finnish. this just looks very elementry like someone had an idea (be it goo or bad who cares) and did not know the first thing about how to carry out the idea. i cant even imagine the work trying to correct it.......... |
09-26-2010, 07:17 PM | #22 |
Member#: 172486
Painting interiors that would hurt your rods and cones is something southern people like to do.
09-26-2010, 07:21 PM | #23 |
Member#: 151598
SCIC
Vehicle:04 Flared STi IG: @dallas_dunn |
09-26-2010, 07:47 PM | #24 |
Member#: 256642
Is this some sort of a joke? Really you PAINTED THE SEATS?? Good luck selling that car if you ever try.
09-26-2010, 08:29 PM | #25 |
Member#: 190454
Vehicle:2005 wrx stage II white like my bitch |
holy ****
Similar Threads | ||||
What shop does good paint jobs? | MagicMT | Bay Area Impreza Club Forum -- BAIC | 3 | 01-31-2012 12:49 AM |
I was thinking about a new paint job, Your thoughts??? | singincanary | Tri-State Area Forum | 17 | 08-19-2005 02:16 PM |
How much for a good paint job? | Siper2 | Interior & Exterior Modification | 11 | 07-19-2004 07:51 PM |
Anyone gotten a good paint job in LA for less than $2000? | BLCK DVL | Southern California Impreza Club Forum -- SCIC | 7 | 06-15-2003 07:48 PM |
How much for a good paint job??? Whose gotten one? | 96Lconversion | Interior & Exterior Modification | 18 | 02-27-2001 10:14 AM |
