Brakes & Suspension Forum sponsored by The Tire Rack |
01-28-2002, 10:55 PM | #1 |
Member#: 4418
Vehicle:2019 CTR White |
new pads and rotors or just pads??
Ok,
I have never had to replace brakes on a car before b/c I havent kept one as long as my impreza. All in all, I have not looked at my pads/rotors to see how bad off they are. What do I look for?? I have 24k miles on the car w/ 7 autocrosses (4 runs each) and well...it takes alot for me to stop my car. What is a good recommendation? Replacement of just the front pads or all four? What about the rotors? Thanks, -justin
01-29-2002, 11:43 AM | #2 |
Member#: 572
Your rotors may be glazed. Pull your front tires off and look for what are called hotspots, they will be a different color than the rest of the rotors (sort of multicolored). If that's the case, or if you just want to upgrade, buy a set of EBC Reds (these are not too harsh for the street). Then get your rotors cut, this will give you a nice flat surface for your new pads to work on and get rid of the hotspots. You also might want to consider stainless steel brakelines and some upgraded brake fluid.
Mark |
01-29-2002, 08:07 PM | #3 |
Member#: 4418
What pads are going to stop me faster?
1.Ebc green stuff 2.Ebc red stuff 3.Oem pad I already run dot4 fluid & plan to get ss lines in the near future. I do brake hard on the street and at autocross & I have heard from various people that ebc green stuff is pretty much the same as an OE pad when it comes to stop distance. -justin |
01-29-2002, 08:30 PM | #4 |
Member#: 572
Number 2. And this is assuming you have a decent tire on the car. All the brakes in the world aren't going to do squat if your tires aren't grippy.
Mark |
01-29-2002, 09:46 PM | #5 |
Member#: 112
NWIC
Vehicle:2011 Jetta TDI Black |
EBC pads will make your problems grow and grow..stay away from them ...please
01-29-2002, 11:35 PM | #6 | |
Member#: 4418
Oh and I have falken azenis tires grip on your tired! -justin |
02-01-2002, 01:48 PM | #7 |
Member#: 12224
Vehicle:2000 RS;Spec Miata Del Sol Si |
ebc greens are no better than oem
i have ebc greens on the front, and there is no difference. someone at cobb told me that ebc pads just cause problems. they cost twice what oem pads do, but are not better.
02-02-2002, 06:13 PM | #8 |
Member#: 112
NWIC
do a search on them, there are lots of cases of them leaving a glaze on rotors that causes squealing and other problems, There are too many proven pads that work great for our cars..no reason to risk being another EBC victim
Just installed new pads and rotors... | dlh1999 | Brakes, Steering & Suspension | 9 | 03-15-2009 01:33 PM |
Just installed new pads and rotors 2 days ago..... | kris84 | Mid Atlantic Impreza Club -- MAIC | 17 | 12-24-2007 08:15 AM |
Time to replace or upgrade pads and rotors? | Dub02 | Brakes, Steering & Suspension | 5 | 05-05-2007 12:23 PM |
Rotor appears to have scoring with new pads and rotor | will667 | Brakes, Steering & Suspension | 2 | 06-02-2006 09:45 AM |
new wheels and tires, or just new tires? | timo | Tire & Wheel | 11 | 01-04-2005 12:37 PM |
