Welcome to the North American Subaru Impreza Owners Club Friday March 21, 2025
Old 12-09-2023, 06:53 PM   #1
hawkeye06sti
Member#: 406859
2006 Impreza STI
Anthracite grey
Default Engine won’t start or stay on unless in throttle
I have a fully built 04 sti tuned on e85. About two months ago it got new injectors one fuel pump replaced and a new waste gate. Along with a new tune put out 711 at 30 pounds. It’s been driving fine since then. I took it to work the other day let it warm up then jumped in I randomly stalled once leaving the neighborhood but drove fine after. When I was in traffic it randomly began dying when not on throttle and rpm’s would jump when trying to keep the gas steady. When put in gear to move forward it sputters horribly and struggles to drive no matter the rpm I give it. I replaced the coil packs and plugs with proper gap and car still behaves the same. Any ideas ?
hawkeye06sti is offline   Reply With Quote
Old 12-27-2023, 06:42 PM   #2
spoolinsti05
Member#: 108051
2005 WRX STi
TGV gaskets. Or intake leak.
Sent from my moto g 5G (2022) using Tapatalk
spoolinsti05 is offline   Reply With Quote
Old 06-22-2024, 06:31 PM   #3
turbopollo
Member#: 538353
Something similar happened to me after my car was in a shop. I had 2 intake leaks. You can check, if you have one, the boost gauge to see if you are losing vacuum while idle.
turbopollo is offline   Reply With Quote
Old 06-25-2024, 02:29 PM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
vacuum leak..check hoses around intake manifold.
Old 08-05-2024, 10:39 PM   #5
arisebaking
Member#: 535438
It sounds like your 2004 Subaru WRX STI, which is tuned on E85 and has been performing well until recently, is now experiencing some significant issues. Even though you recently replaced a fuel pump, it's possible that the remaining pump is failing or that there is an issue with the newly installed pump.
arisebaking is offline   Reply With Quote
Old 10-07-2024, 05:43 AM   #6
shawtom
Member#: 539278
It sounds like a frustrating situation, especially after putting so much into your build! Given that it was running fine after the new injectors, fuel pump, wastegate, and tune, it’s strange that it’s acting up now. The random stalling and RPM jumping could point to a few things. It could be something fuel-related, maybe a fuel pressure regulator issue, or even a sensor like the MAF or throttle position sensor going bad. Since you've already replaced the coil packs and plugs, it might be worth checking the fuel lines or even the tune itself—sometimes things can shift unexpectedly after driving for a while.
I know how tough it can be to troubleshoot something like this, but with the work you’ve put into that beast, I’m sure it’s something fixable! Maybe someone with a similar setup might have dealt with this and can chime in with a solution.
shawtom is offline   Reply With Quote
Old 11-23-2024, 12:40 PM   #7
Mauled
Member#: 500169
Idk y but this post sounds like it's from a bot.
Mauled is offline   Reply With Quote
Old 11-23-2024, 09:48 PM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
I agree.
"Nuke it from space, it's the only way to be sure."
Old 11-28-2024, 03:27 AM   #9
linnellaa
Member#: 539673
If these checks don’t resolve the issue, it’s advisable to consult a mechanic. Advanced diagnostics may be required to pinpoint less obvious issues, such as problems with the ECU or more complex fuel system faults. Drive Mad
linnellaa is offline   Reply With Quote
Old 12-02-2024, 03:36 PM   #10
Mauled
Member#: 500169
Bot post alert.
Old 12-05-2024, 02:34 AM   #11
ructtouch
Member#: 539713
If these checks don’t resolve the issue, it’s advisable to consult a mechanic. Advanced diagnostics may be required to pinpoint less obvious issues, such as problems with the ECU or more complex fuel system faults. level devil
Heads up, we’ve detected some automated bot activity on the system, and while this might not always be an issue, it’s important to double-check everything to make sure there’s no unintended impact on your data or the system’s performance, so if you notice anything unusual, don’t hesitate to reach out for support.
ructtouch is offline   Reply With Quote
Old 02-20-2025, 03:01 AM   #12
Knotargeed
Member#: 540353
I have a fully built 04 sti tuned on e85. About two months ago it got new injectors one fuel pump replaced and a new waste gate. Along with a new tune put out 711 at 30 pounds. It's been driving fine since then. I took it to work the other day let it warm up then jumped in I randomly stalled once leaving the neighborhood but drove fine after. When I was in traffic it randomly began dying when not on throttle and rpm's would jump when trying to keep the gas steady. When put in gear to move forward it sputters horribly and struggles to drive no matter the rpm I give it. I replaced the coil packs and plugs with proper gap and car still behaves the same. Any ideas ?
I'm new to this field. Reading this,gunspin. I realize there's so much to learn.
Knotargeed is offline   Reply With Quote
