Welcome to the North American Subaru Impreza Owners Club Sunday March 23, 2025
Old 06-12-2018, 09:24 AM   #76
J Pride
Member#: 475638
I did this to my EJ205 when one cam bolt gave out on me. After I welded a 1/2 nut on the head of the bolt. I was able to break it with a breaker bar by myself. I need to do it to two more of my ej’s. I’d like to start a thread for my 24 hour of lemons wrx (yes I got a wrx for the cheap) but I need 3 replies first. Can someone help me out please? Much appreciated
J Pride is offline   Reply With Quote
Old 07-05-2018, 01:45 PM   #77
skybluesube
Member#: 482372
2002 Subaru WRX Wago
My buddy snapped a head stud one time and that was a blast getting out. Thanks for the tip.
skybluesube is offline   Reply With Quote
Old 07-08-2018, 10:29 AM   #78
three60austin
Member#: 487595
I use this same method with suspension components on Midwest/East Coat cars. Works wonders. Great old school tip!
three60austin is offline   Reply With Quote
Old 04-19-2019, 08:01 PM   #79
sgtxRoflcopter
Member#: 500583
2015 WRX
Galaxy Blue
Umm. that is some innovative thinking
sgtxRoflcopter is offline   Reply With Quote
Old 08-14-2019, 07:53 AM   #80
User_Name_1944
Member#: 497803
Sometimes better to spend a little more and not have so much money invested in the lemon cars from my experience.
User_Name_1944 is offline   Reply With Quote
Old 08-22-2019, 10:38 PM   #81
Aaa246
Member#: 464588
smart
Aaa246 is offline   Reply With Quote
Old 10-13-2019, 02:57 AM   #82
Subi_Doobie
Member#: 507347
Great to know! I Went to remove mine to replace cam seals during a t-belt change. They were wicked tight so I left them alone. Good to know this for next time! https://youtu.be/Lsqts5oISK8
Subi_Doobie is offline   Reply With Quote
Old 10-13-2019, 02:59 AM   #83
Subi_Doobie
Member#: 507347
How bout reply to mine too! Lmao
Old 12-28-2019, 10:06 AM   #84
awcforever
Member#: 382066
2002 Subaru WRX
Another solution (not sure if mentioned) i used a 3” extension and a 17mm socket. The extension provides a place to seat my air hammer. Ram the 6 sided 17mm socket over the cam bolt. Takes a good bit of force but then it zips off with the impact. Then using the bench vice i use the air hammer to knock the cam bolt from the socket. Always works for me. I have a welder but for those who don’t this trick is great. Plus I have a very large collection of Chinese sockets I’ve collected in a drawer over the years. ***128513;
awcforever is offline   Reply With Quote
Old 07-31-2022, 11:31 AM   #85
Ollieparker1990
Member#: 530898
Great tip. Very helpful!
Ollieparker1990 is offline   Reply With Quote
Old 07-09-2023, 04:37 PM   #86
Eth207
Member#: 534824
Good stuff. Thanks for this
Eth207 is offline   Reply With Quote
Old 10-08-2024, 12:13 PM   #87
TonyaMorgan
Member#: 539100
Creative! BEFORE YOU USE 10mm ALLEN TOOL, guys, make sure to use SNAP-ON ONLY! The problem with the cam bolt is not the bolt itself but cheap auto parts store quality of the tool. I purchased 1/2 inch drive 10mm Allen from SNAP-ON and it works like a champ! No more problems, and I rebuild lots of EJ motors.
TonyaMorgan is offline   Reply With Quote
Old 12-06-2024, 03:59 AM   #88
Freddy82
Member#: 539724
Default Nice vid:)
Nice video regards from germany
Originally Posted by outfrontmotorsports View Post
***********We have seen a lot of posts regarding the removal of stuck cam bolts and methods of how to hold the cam gear in the futile attemps to remove these bolts with success. We have heard of horror stories of drilling, special bits and long times to do it, we have personally seen the results of dealerships using cut-off wheels/air chisels and the damage left behind on the gears that the dealer reinstalls.
the video was not edited, the motor we have is a ej205, three of the four cam bolts came loose with an impact gun, the forth one did not. this method for us is so fast that it's not worth the time to clamp the timing belt together, nor to use the cam tool. On really tight ones with the tool, we have chipped the gears. we have also seen broken head castings due to using a wedge/prybar on the cam lobes.
Often the cam bolt get really tight due to heat cycles, with the welding we do, the rapid heat applied to a stripped bolt makes them come off like butter, not damaging the cam gear at all. If you are local to us, we would perform this operation for $20 per bolt
<iframe width="425" height="349" src="http://www.youtube.com/embed/WjZ0XtLYtzc" frameborder="0" allowfullscreen></iframe>
http://youtu.be/WjZ0XtLYtzc
Freddy82 is offline   Reply With Quote
Old 12-06-2024, 04:00 AM   #89
Freddy82
Member#: 539724
Default Nice vid:)
Cheers and Happy Weekend
[quote=outfrontmotorsports;34607909]***********We have seen a lot of posts regarding the removal of stuck cam bolts and methods of how to hold the cam gear in the futile attemps to remove these bolts with success. We have heard of horror stories of drilling, special bits and long times to do it, we have personally seen the results of dealerships using cut-off wheels/air chisels and the damage left behind on the gears that the dealer reinstalls.
Stripped cam gear bolts scoobywagon06 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 03-23-2018 06:17 PM
How do you fix a stripped seat bolt? Jncominco2 Rocky Mountains Impreza Club Forum -- RMIC 11 02-19-2009 08:32 PM
stripped cam sprocket bolt limestoner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-02-2006 08:55 AM
Stripped banjo bolt hole in brake caliper? Fix it!!! thrdeye Brakes, Steering & Suspension 0 10-14-2005 03:10 PM
Anyone ever have a Intake Cam bolt snap off while driving???? fastlane Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-16-2005 05:18 PM
