Welcome to the North American Subaru Impreza Owners Club Sunday March 23, 2025
Old 01-25-2025, 11:54 AM   #1
StimpyV2
Member#: 388341
2004 Wrx wagon
Default Intermittent P0107 MAP circuit low EJ207
I’m currently having an issue with my V8 207 swap. It has operated fine for years, but now I have an issue. I get a P0107 code that actively disappears on acceleration, when I’m off the gas or idling the code comes back. During the times when the CEL is on the AFRs are very lean (from my AEM wideband) and runs very bad.
I’ve replaced the front o2 sensor with a new denso, cleaned the MAF, and inspected for vacuum leaks. Should I be looking at the MAP sensor? TPS?
I’m at a loss at the moment, I’m 500 miles my house so I don’t have access to my garage, but I do have logging abilities with romraider.
If someone could help out I’d appreciate it.
StimpyV2 is offline   Reply With Quote
Old 01-25-2025, 03:57 PM   #2
StimpyV2
Member#: 388341
2004 Wrx wagon
*** small update, I unplugged the MAP sensor and it idles very lean but becomes drivable at 1/3 the normal boost level and runs smoothly other than idle.
If it is in fact the MAP sensor what my options as currently mine has the JDM one (PN: 22627aa260 denso) and these seem to be unavailable.
Old 02-03-2025, 07:03 AM   #3
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
I probably have one or two spares of those map sensors. Let me know if you can’t find one but you can probably source one on eBay.
D-Rodman is offline   Reply With Quote
Old 02-26-2025, 03:12 PM   #4
StimpyV2
Member#: 388341
2004 Wrx wagon
It was in fact the MAP. Replaced it with a one from eBay and it fixed my issues.
