08-16-2012, 09:23 PM | #1976 |
Member#: 23553
Vehicle:2005 STI - Insanity! 2014 WRX - Daily |
Ok, I am convinced. The turbo stays and the car gets drunk. Due to my little fuel issue earlier in the year, Phil has strongly suggested that I run the car the way it is until 2000 miles. At 2000 miles I will be swapping to E85 and Redline 15w50. I will NOT be swapping turbos (at least not this year).
08-16-2012, 09:36 PM | #1977 |
Member#: 23553
In other news, I see that a ton of tuners and engine builders have been experiencing cracked blocks lately. They all seem to have the very latest "post tsunami" build date blocks which is exactly what I currently have. A friend recently told me that Maxwell Power is no longer building new blocks due to this issue. I talked to Nate from TPG and he is also aware of the situation and feels that the stock blocks are only good to about 500whp on a dyno-jet or 450whp on Mustang. Has anybody else heard anything?
In the meantime, I think I am going to get the car tuned on E85 but limit the power to 450whp for the balance of 2012 and 2013. Then during the winter of 2013/2014 I will look into either swapping to an older "pre tsunami" block or possibly do sleeves. Who knows, maybe there will be a better solution out by then. |
08-16-2012, 10:03 PM | #1978 |
Member#: 32669
SCIC
Vehicle:2007 2.34LR, EFR7670 LINK G4+ hybrid STi |
That's news to me. I haven't noticed any uptick in cracked blocks or sleeves lately. Who's breaking them?
08-16-2012, 10:40 PM | #1979 |
Member#: 283784
RMIC
Vehicle:2015 MUSTANG GT PP GUARD |
I think your falling into the something is going to happen to my car blah blah blah phase. Enjoy the car!! Watch the AFRs and oil pressure and check the oil level during fill ups. As long as its a conservative tune and you have a fail safe for the meth you should be fine!
08-16-2012, 10:43 PM | #1980 |
Member#: 214121
TXIC
Vehicle:2005 604whp/543wtq fp3586 twinscroll |
That's a low whp limit on e85 I made 510whp at 22psi on a mustang dyno with a very similar setup
You will be at like 17 psi and 450whp Not even coming close to pushing it!! If that's all you really ever want to push it I would go to a 30r size turbo crazy fast spool and still be capable of 480ish on e85 Last edited by shilohb; 08-16-2012 at 10:55 PM. |
08-16-2012, 11:00 PM | #1981 |
Member#: 23553
08-16-2012, 11:17 PM | #1982 |
Member#: 32669
SCIC
But that block was a 2-3 year old block. You know if you look hard enough you can always find something to be worried about. If you're going to spend all your time doing that what's the fun of owning the car if you're afraid to drive it.
I'm a little apprehensive when I put a new motors in for about 6 months as I slowly ramp up my beatings. After that its on. If you can't ever relax and just drive your car you might as well part it out because you'll never be comfortable with it. Your situation is a little different because you've experienced so many issues but it seems like you really are just looking for reasons to fail again. |
08-16-2012, 11:21 PM | #1983 | |
Member#: 151809
South East
Vehicle:2007 WRX Black |
Enjoy the car. Stop expecting things to happen. |
08-16-2012, 11:21 PM | #1984 | |
Member#: 283784
RMIC
08-17-2012, 03:31 PM | #1985 |
Member#: 23553
I wasn't talking about the OP, I was talking about what Phil was talking about in regards to failures cropping up. Its pretty scary to think that I could loose another $10,000 long block. Hell, it even blew the radiator apart!
08-17-2012, 04:30 PM | #1986 | ||
Member#: 48219
Vehicle:. Always drive the race line . |
How about whoever is slower around a tarmac circuit buys beer at the next meet? |
08-17-2012, 04:40 PM | #1987 |
Member#: 32669
SCIC
That's not uncommon. My cars have always spooled better on the street than on the dyno. It can be a function of ramp rate and the fact that a dyno doesn't exactly replicate the load a car sees the street.
08-17-2012, 08:35 PM | #1988 | |
Member#: 214121
TXIC
08-17-2012, 10:21 PM | #1989 |
Member#: 48219
You guys saw 1000 rpm quicker spool up? Maybe you guys misread my question. I didn't ask why a turbo car tends to spool up quicker on the street versus the dyno. I asked why Tom's car spooled up 1000RPM faster on the street. And what load sites was the ECU running off on the street as opposed to what was tuned on the dyno... especially in the 3500 to 5000RPM range...
08-17-2012, 11:11 PM | #1990 | |
Member#: 23553
08-17-2012, 11:12 PM | #1991 |
Member#: 32669
SCIC
I didn't see 1000 rpm difference but I did see a significant one. At least a 500 rpm difference. The 1000 rpm number can be manipulated based on how the tuner operated the dyno. If he was tuned on a Mustand dyno you could set it up so the graph showed spool you could never acheive on the street by loading the car heavily sort of like brake boosting on the street. The only thing that really matters is the way it spools on the street and that his tune was compensated for with road tuning.
08-17-2012, 11:18 PM | #1992 |
Member#: 23553
I wasn't going to post this but what the hell. Here's the graph and info:
08-17-2012, 11:24 PM | #1993 |
Member#: 23553
The thing that made me want to switch up the setup is that strange 45 degree angle that the torque follows. Given that the boost graph will look almost identical to the torque graph one could conclude that the car hit max boost (18psi) around 5250 RPM on the Dyno. Maybe Nate still has the logs. The thing that I dont get is that the weight setting on the dyno is 3625lbs which in my mind would load the car even more than normal for a Mustang 1100. I will have to look around for other big turbo graphs to see what they look like.
Obviously this isn't a "high performance" tune but I was expecting it to have a bit more "get up and go" in the 3000-4000 range. |
08-18-2012, 12:19 AM | #1994 |
Member#: 214121
TXIC
My car had a very similar dyno sheet on 93 and was a bit worried until we switched fuels and ran it on e85
this is my e85 tune my engine is sleeved 278/282 cams +1 valves |
08-18-2012, 12:37 AM | #1995 | |
Member#: 134949
VIC
Vehicle:'07 SWP STi Instagram | arthurlam89 |
08-18-2012, 08:35 AM | #1996 |
Member#: 214121
TXIC
08-18-2012, 09:03 AM | #1997 |
Member#: 23553
Have you guys looked at P&L's single scroll setup? This is what makes me want to down size the turbo a bit. This car has 450ftlbs @3800 RPM which is the stuff the hopes and dreams are made of. I have seen graphs of other mid sized Moore kits (verses my large sized) and the results are even better than the P&L setup.
P&L Proto type Comp turbo kit 450ftlbs@3800rpms, full boost 3300rpm 500whp! |
08-18-2012, 09:05 AM | #1998 | |
Member#: 214121
TXIC
08-18-2012, 11:34 AM | #1999 |
Member#: 86741
Vehicle:05 STi.. Built twinscroll35r Love/Hate |
Looks very promising! Almost makes me want to ditch the garagetuning twinscroll 35r for that kit!
08-18-2012, 12:44 PM | #2000 | |
Member#: 134949
VIC
Good spool on your car! |
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe | arco | SCIC Private Classifieds | 11 | 10-22-2010 01:09 AM |
Picture of my new Ultimate Racing twin scroll kit | blowbyu24 | Member's Car Gallery | 682 | 08-24-2010 08:12 AM |
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe | arco | Engine/Power/Exhaust | 9 | 10-02-2009 01:04 PM |
FS VA: JDM manifold, Twin Scroll kit, JDM Genome and more | quadzilla | Engine/Power/Exhaust | 38 | 09-18-2008 10:22 PM |
Pros and cons of twin-scroll turbo! | Carisma | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 59 | 07-04-2005 05:06 PM |
