Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Old 01-07-2007, 11:52 PM   #1
KSwrxWAGON
Member#: 56639
'03 WRX Wagon
Default SSautochrome TMIC Install Question
For those who have installed these before, did you need to trim the coupling between the TMIC and throttlebody? I have read through the writeup on scoobymods and the comments here, but nobody mentioned this as a tight spot.
I have an '03 WRX and the effluent port from the intercooler is nearly touching the TB (fitting w/o the coupling to see how close it is).
Just thought I'd ask before I go hacking a coupling apart. Thanks for the input! This thing is a PITA...but it was cheap on ebay .
KSwrxWAGON is offline   Reply With Quote
Old 01-07-2007, 11:58 PM   #2
dibblejr
Member#: 94070
05 LGT
I didnt have to mod anything, but some have, go figure. It is not that bad just dry fit everything.
BTW I had the perrin coupler, but when I originally put my alky system in I used the stock coupler without cutting any off.
Good luck
Jay-R
dibblejr is offline   Reply With Quote
Old 01-08-2007, 12:06 AM   #3
emeessen
Member#: 117741
2012 STI Ltd SWP
2006 Saab 97x Arc
For me, the stock coupler was too short (ie it barely made contact with both the TB and the IC). I bought a new coupler online and had to trim it to fit.
Don't be afraid to modify your parts, just make sure you measure twice and cut once...
emeessen is offline   Reply With Quote
Old 01-08-2007, 12:08 AM   #4
Ziggyrama
Member#: 53665
2011 STI Stg2 w/ ELH
Focal 2way Active w/ DSP
I trimed mine 1/2 inch. The entire fit is very snug. Make sure you get it all lined up first and then cut it. Good luck.
Ziggyrama is offline   Reply With Quote
Old 01-08-2007, 12:08 AM   #5
dibblejr
Member#: 94070
05 LGT
+1 for another good reply. Measure 2X cut 1X
Old 01-08-2007, 12:41 AM   #6
djoye
Member#: 50072
2017 STI
WR Blue Pearl
I bought a 3" coupler, trimmed it at least 1/2". Once you get that coupler trimmed down right you should be able to get the TMIC to fit straight.
I also used a dremel to trim some from the driver-side IC bracket (black bracket piece) so that the IC would fit better.
djoye is offline   Reply With Quote
Old 01-08-2007, 01:43 AM   #7
Mustang Raper
Member#: 84388
2002 WRX,FPG,6MT
Sedona Red Pearl, Carbon
Mine fit perfectly, no trimming or anything, just a little wiggling to slide it in.
Mustang Raper is offline   Reply With Quote
Old 01-08-2007, 09:23 AM   #8
KSwrxWAGON
Member#: 56639
'03 WRX Wagon
Thanks for the replies, they help a lot. Looks like I'll be measuring and trimming...better get some extra pieces just in case.
Thanks again.
Old 01-08-2007, 12:49 PM   #9
Rexfan
Member#: 50993
02 WRX Wagon
2.5/Blouch Dom 3/Meth/6sp
I installed one on a buddies 02 wagon. No trimming was involved but we're thinking of trimming the coupler a 1/2 inch plus or minus. The drivers side bracket lined up but not the passenger. Where did you guys get couplers from?
Rexfan is offline   Reply With Quote
Old 01-08-2007, 01:24 PM   #10
KSwrxWAGON
Member#: 56639
'03 WRX Wagon
That's how mine is. The stock y-pipe doesn't line up at all when I'm test fitting it. The y-pipe is about 2 inches closer to the firewall than it needs to be. Hopefully a Samco y-pipe will be a bit easier.
There's all kinds of aftermarket manufacturers for hoses/couplers. Samco and Perrin make them as well as others. Check out ebay or the vendors section on Nasioc.
Old 01-08-2007, 01:34 PM   #11
Rexfan
Member#: 50993
02 WRX Wagon
Default ?
Yep, I am on it now. I want a red Perrin coupler for my own setup.
Old 01-08-2007, 02:29 PM   #12
engz
Member#: 112824
2002 PSM bugeye
WTT:GreddyEvo2.4.HKShiper
Nvm!!!
engz is offline   Reply With Quote
Old 01-08-2007, 03:02 PM   #13
nicholam
Member#: 133936
2005 WRX Wagon
Stage 4 Silver
I have y-pipes and all hoses for the ebay tmic. I bought an extra set. http://cgi.ebay.ca/JDM-02-03-04-05-0...QQcmdZViewItem
I'll let it go for $50 plus shipping.
nicholam is offline   Reply With Quote
Old 01-08-2007, 07:07 PM   #14
PJAWRX03
Member#: 47426
2003 Impreza WRX
For the guys that have no fitment issues did you use the ic hoses supplied with the intercooler and do you purchase the Intercooler recently. I think they made some changes so it fit better. just wondering for a potential buyer.
PJAWRX03 is offline   Reply With Quote
Old 01-08-2007, 07:23 PM   #15
dibblejr
Member#: 94070
05 LGT
My TMIC came with nothing but the PCV tubes, I used what I had.
Jay-R
Old 01-08-2007, 08:09 PM   #16
nicholam
Member#: 133936
2005 WRX Wagon
Stage 4 Silver
Wups, I guess I should have looked at the link I've posted. I'll sell this for $30, not $50.
Old 01-08-2007, 08:36 PM   #17
Rexfan
Member#: 50993
02 WRX Wagon
My buddies only came with bov. No hoses were inlcluded. He had a Hyperflow TMIC that had a problem. We used his old hoses without any major problems.
Rexfan
TMIC Installation question CJ3B Newbies & FAQs 4 08-25-2007 12:48 PM
ssautochrome TMIC bpv question stkbox Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-07-2007 03:35 PM
FS: SSAutochrome TMIC and APS TMIC BOV Capt Crunch MAIC Private Classifieds 6 02-13-2007 05:34 PM
SSAutochrome TMIC installed today on 03 WRX Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 192 08-26-2006 10:37 AM
TurboXS TMIC install question roybfr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 11-01-2004 03:11 PM
