Welcome to the North American Subaru Impreza Owners Club Thursday January 24, 2019
Old 11-18-2018, 04:25 PM   #1
MtnXfreeride
Member#: 228010
2019 WRX Limited
Crystal White Pearl
Default Automatic touchless car wash on Ceramic Coat
Anyone here take their car through touchless car washes in the winter? Now that I have a white WRX.. literally every time there is a bit of slush it looks nasty after and its beyond ONR yet too cold outside to wash with a foam canon or 2 bucket. Hows the coating holding up to the harsh soaps they use?
MtnXfreeride is offline   Reply With Quote
Old 11-18-2018, 06:40 PM   #2
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Oh yes, it's a must keeping the paint clean.
I even go to the self carwash first to spray the wheel wheels and under carriage before going though the automatic touchless carwash because it does not clean the underside of the car well enough.
jasonwrx86 is offline   Reply With Quote
Old 11-18-2018, 06:54 PM   #3
grovlet
Member#: 372889
2005 Legacy GT
Well - not sure how good touch-less is at cleaning - better off just using a pressure washer or self wash for $3 pressure rinse....
grovlet is offline   Reply With Quote
Old 11-18-2018, 07:15 PM   #4
littledrummerboy
Member#: 94408
17 STI Sport-Tech
17 Impreza Hatch Touring
If it’s no problem on non-coated cars (I’ve used touchless for a decade on my old wrx), don’t know how it could be an issue on cars with ceramic.
littledrummerboy is offline   Reply With Quote
Old 11-18-2018, 11:57 PM   #5
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
I think he is more concerned about the coating being washed off by the acids.
Old 11-19-2018, 07:05 AM   #6
MtnXfreeride
Member#: 228010
2019 WRX Limited
Crystal White Pearl
Right
Old 11-19-2018, 08:48 AM   #7
littledrummerboy
Member#: 94408
17 STI Sport-Tech
My fault for not phrasing it correctly. I meant that ceramic is supposed to be better and more durable than a wax job so it should last. If it can't hold up to touchless soaps then what's the point of it? But I guess that's a different topic. fwiw, i think you'll be alright.
Old 11-19-2018, 09:31 AM   #8
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Two years in, and having only once used one of the "mandatory" top coat maintenance products, touchless washes haven't noticeably degraded the performance of the ceramic coating. If I'm honest, I run the Porsche through a touchless wash far more often than I wash it by hand. Water still beads up nicely.
Scooby921 is offline   Reply With Quote
Old 11-21-2018, 01:07 PM   #9
Cobrakai
Member#: 176408
2005 STy
As long as you're not paying for their BS "Tricolor polish" or rainX then it shouldn't have negative effects on your coating.
With that being said I've used the bottom tier wash on several coated vehicles when they're lightly to moderately dirty without issue.
You could give yourself a prerinse with some diluted APC in the parking lot on the heavily soiled areas.
Cobrakai is offline   Reply With Quote
Old 11-21-2018, 01:33 PM   #10
SubiFisher
Member#: 494331
I do the same as Cobrakai stated. Get the cheapest wash. Once you start getting all those other specials, it will take away from your coating's function.
I did it a few times and noticed water wasn't beading as good as it did. Ended up purchasing the soap to reset the coating and its back to as good as new. I keep a bottle of the quick detail spray for my cquartz coating in the car now and do a quick wipe down after any automatic touchless wash.
SubiFisher is offline   Reply With Quote
Old 12-12-2018, 01:52 PM   #11
Slim_Jim
Member#: 473831
2018 WRX STI Limited
Lapis Blue Pearl
Please correct me if I'm wrong, but any ceramic coating that I've seen doesn't wash off, you have to buff it off with an abrasive.
It would have to be a pretty strong acidic or alkaline solution to wash it off.
Slim_Jim is offline   Reply With Quote
Old 12-14-2018, 04:25 PM   #12
MtnXfreeride
Member#: 228010
2019 WRX Limited
Crystal White Pearl
This is exactly what I was looking for.. someone with a coated car that goes through these on occasion and has been coated for 2 years now. Thanks!
