03-18-2005, 03:03 PM | #1 |
Member#: 60224
02/03 vs. 04/05 WRX ECU and wiring connectors different? (pics)
I’m trying to verify the model year of ECU and Harness I have to accompany my USDM WRX drivetrain swap. Can somebody please confirm the following statement:
???? An 02/03 WRX harness will not plug into an 03/04 ECU and vice versa ???? I believe this to be true based on the following image detailing side-by-side, ECU connectors. 02/03 is on the left, and 04/05 is on the right. From this image, it appears that the connectors are physically different although the pin numbers remain the same. The connectors appear to be identically reversed (mirrored) between the two sets of years. This would lead me to believe an 02/03 harness will not plug into an 04/05 ECU and vice versa.
03-18-2005, 03:48 PM | #2 |
Member#: 8343
Vehicle:2005 2012 Jeep 2013 DGM BRZ |
They just represented the plug from the other direction, they are the same.
03-18-2005, 04:45 PM | #3 |
Member#: 60224
Not questioning your information, but how certain are you of this?
If I hold my ECU connectors up from my wiring harness, and am looking at the side which plugs directly into the ECU (opposite wires), it looks identical to the diagram on the left. |
03-18-2005, 07:48 PM | #4 |
Member#: 13617
Vehicle:2001 Legacy GT back to stock is a project too |
it depends on what way you are looking at and more specifically which section i think. We were looking through an actual service manual and depending on what picture you looked at, sometimes the pins were reversed like that for the exact same harness plug.
thats just my observations. Ben |
03-18-2005, 08:01 PM | #5 | |
Member#: 8343
Yes, I'm certain. |
02/03 vs.04/05 vs. 06/07 | GTPowered4.6l | Newbies & FAQs | 3 | 04-24-2008 08:51 PM |
WRX hood scoop air duct 02-03 vs 04-05 | Psychopat | Interior & Exterior Modification | 2 | 10-19-2006 08:29 PM |
02/03 vs 04/05 struts, wrx | AlpoRS | Brakes, Steering & Suspension | 1 | 06-03-2006 10:51 PM |
Rear Strut/Spring Differences 02-03 vs 04-05 | i-max | Brakes, Steering & Suspension | 3 | 03-23-2006 05:05 PM |
02 WRX ECU vs 04-05 WRX ECU | valor77 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 07-25-2005 09:03 PM |
