Welcome to the North American Subaru Impreza Owners Club Tuesday November 13, 2018
Old 11-11-2004, 09:44 PM   #1
chucktoo
Member#: 59539
2005 Outback 2.5 XT
Default Thoughts on Water Injection
I am getting ready to do methanol-water injection as the next step in the search for more WHP on pump gas.
I have read much of the aqua-mist forum .
http://www.aquamist.co.uk/phpBB2/index.php
It is clear you want to inject after the intercooler and before the throttle plate.
A bunch of people are doing pre-turbo injection . It makes sense it is like a cool moist day . I worry about the impact on the compressor blades life- anyone have experiance with preturbo injection ?
Thanks Charlie
chucktoo is offline   Reply With Quote
Old 11-11-2004, 10:57 PM   #2
Wes_FSTGDB
Member#: 59400
2013 335XI MSport
2008 BMW 335XI Space Grey
Umm, I would go with alcohol injection. Me and about 20 other guys in Anchorage, AK all went in on a group buy from SMC on there WRX kit. The kit works fine and it added some real WHP. I guess if you wanted to, you can buy the aquamist kit and instead of putting water, just add alcohol.
Depending on my settings, I can be running at 100 octane at 16/17psi.
Check out SMC's website:
SMC Enterprises
-Wes
Wes_FSTGDB is offline   Reply With Quote
Old 11-11-2004, 11:41 PM   #3
attitude
Member#: 52043
04 sti
how does that kit work? any issues? how do you have it set up? i.e. it kicks on at 12 psi, and the pump kicks on at low speed, then as the boost goes up it gradually speeds up until you are at max boost? how controllable is it?
attitude is offline   Reply With Quote
Old 11-12-2004, 12:10 AM   #4
SaabTuner
Member#: 67608
You cannot use any Alcohol other than Methanol in the Aquamist setup or it will corrode the seals.
Alcohol injection works fine, but for the same amount of fluid a mixture of water/methanol will have a greater effect on octane. Water is also cheaper than alcohol.
Either way though. The damage to the compressor wheel is long-term. By the time you have any appreciable damage it will be time for a normal rebuild.
Adrian~
SaabTuner is offline   Reply With Quote
Old 11-12-2004, 07:32 AM   #5
chucktoo
Member#: 59539
2005 Outback 2.5 XT
Hi Adrian
So you are saying the corrosion/erosion of the compressor wheel is not too great ? Have you been running a system with a jet before the compressor ? If so for how long and what percentage of the water goes through the compressor ?
Thanks Charlie
FS : Meth / water injection kit NEW! defi gauges boost, egt JT's06sti Engine/Power/Exhaust 7 06-18-2010 12:45 AM
Idiot on water injection, help me!!! OCrex Water/Methanol Injection, Nitrous & Intercooler Cooling 7 04-13-2005 08:38 PM
Thoughts on Water to Air IC sideways motorsports Newbies & FAQs 7 02-01-2004 06:16 PM
Thoughts on water injection DJWRX Water/Methanol Injection, Nitrous & Intercooler Cooling 29 11-30-2001 07:30 PM
What's the skinny on water injection in a turbo engine? Digital_Boy Technical Forum Archive 5 08-26-2000 01:08 AM
