Welcome to the North American Subaru Impreza Owners Club Monday July 16, 2018
Old 02-13-2003, 01:24 AM   #1
ChristophWRX
Member#: 19009
2005 M3/WRX by clark
silver/white
Default questions about cel fix on exhaust? up pipe DP!!!
i ordered the turbo xs downpipe with catted mid pipe, 3 inches.
i want to avoid any check engine light, i am going to purchase the mil eliminators tomorrow for the rear o2 sensor, it worked for my friend (S-WRX), so i will give it a try. I am going with the perrin up pipe and wanted to know what i needed for that system to ensure no cel light. Well, anything that i need that does not already come with the perring setup, or would you recommend another up pipe?
hope this is clear, i would appreciate any information, thanks alot guys..
chris
ChristophWRX is offline   Reply With Quote
Old 02-13-2003, 01:33 AM   #2
iloveturbos
Member#: 22868
MBP
all you need for the up is a 2.2K (not just 2.2) ohm resistor. a pack of 5 at radio shack is $1.
iloveturbos is offline   Reply With Quote
Old 02-13-2003, 01:58 AM   #3
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
From what I just read...the Perrin setup comes with a workaround for the loss of the EGT sensor (most likely a resistor).
You will also get a CEL from removing two cats (UP and DP), so I would suggest also getting a Pony Express MIL eliminator (<$15) to modify your rear O2 sensor.
Good luck!
-=Eric
edit...apparently I didn't actually READ your post before I replied Disregard me...but it looks like you've got everything covered, EGT resistor, and rear O2 MIL eliminator
mexicanpizza is offline   Reply With Quote
Old 02-13-2003, 10:12 AM   #4
ChristophWRX
Member#: 19009
silver/white
Default ...
cool, sounds like i am good to go. i will call perrin and make sure that it sends the egt whatchamucallit....
thanks again....
christopher
05 WRX Stock parts: starter, timing belt, cams, short throw, DP, exhaust, up pipe... Paulys05wrx Engine/Power/Exhaust 4 06-29-2010 11:36 AM
FS: BNIB Invidia Bellmouth Catless Dp w/ CEL fix $275 picked up yo14jman Tri-State Area Private Classifieds 38 08-11-2009 08:03 PM
CEL fix on Godspeed DP PatSti Newbies & FAQs 0 02-20-2007 09:31 PM
question about CEL fixes Nettalp Newbies & FAQs 6 10-18-2006 03:45 AM
another question about cel fixes MtlPete Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-18-2005 02:49 PM
