Welcome to the North American Subaru Impreza Owners Club Thursday September 20, 2018
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 07-06-2000, 05:40 PM   #1
GettingaSubie
Member#: 1492
Question How do I make ram air?
I am going to be buying a imprez and thought it would be cool to make a ram air system like the one on the transam. Is there anyway I can make my own box so rain doesn't get on it. Any ideas how to make it.
Thanks
GettingaSubie is offline
Old 07-06-2000, 06:03 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I'm thinking, I'm thinking....
8Complex is offline
Old 07-06-2000, 07:02 PM   #3
Matt Manspeaker
Member#: 107
Post
Don't spend too much time on this. If you want any real effect from ram air you have to go above about 85 mph since dynamic pressure is not high enough below that to significantly increase manifold air pressure.
If you REALLY want true ram-air.....get a turbo
Matt Manspeaker is offline
Old 07-06-2000, 07:29 PM   #4
Dan00RS
Member#: 1367
2000 Impreza 2.5RS
Blue Ridge Pearl
Thumbs up
Yes: Ram-air = TURBO!!
Dan00RS is offline
Old 07-06-2000, 07:44 PM   #5
Templar
Member#: 483
2010 RSV4
Aprilia Racing Black
Post
Also the problem with having your intake at the hood scoop on our cars is that it leaves your intake track too short and you end up losing a good amount of low end. Trust me on this, I have done it. You can ask Imprezer about his test with the filter that close to the throttle body too.
Templar is offline
Old 07-06-2000, 08:50 PM   #6
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Post
Time for a what-if that's been on my mind for awhile.... What if you were to take fiberglass or some other easily had body material and extended the IC scoop all the way to the very front leading edge of the hood, leaving it perhaps one inch high by ten or twelve inches wide. Way out on the edge like that (much like the Legacy stock intake that gets air right at the edge of hood and grill) you would get massive amounts of air, caught as it is forced over the car. With an intake this long and narrow, the water problem would be mostly cured, plus you get the long smooth passage neccessary to reduce turbulent airflow. Just a VERY rought vis. aid I threw toghther five minutes ago to get the point across (that and I LOVE this paint color)
<img src=http://a1060.g.akamai.net/f/1060/597/30minutes/www.zing.com/picture/pd982ad9a88b188258891a7531433b57b/ff97ff32.jpg>
Again, I know the picture is bad, but I think the idea may even be a sound one. Either that, or it's because I'm REALLY tired and need sleep NOW!!! You can use it as a ram-air setup for N/A or to get the huge amounts of high-pressure air off of the front of the car for a turbo's IC. Thoughts anyone?
North Ursalia is offline
Old 07-06-2000, 10:38 PM   #7
Keiho
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Talking
You know..that pic actually looks half decent! I like it!
Keiho is offline
Old 07-07-2000, 05:15 AM   #8
ndmorespd
Member#: 1657
2k RSish
BRP
Post
No the pic doesn't look bad at all... Maybe someone out there with a decent amount of fiberglass experience could pull it off..
Who knows, the filter could be adapted to pass air diagnally (sp?) then into the smaller pipe to make to bend into the intake...
Ok who has the experience now???
Mike
ndmorespd is offline
Old 07-07-2000, 06:32 AM   #9
HRE | giulio
Member#: 481
Post
Just remove the passenger headlight houseing, then build a cold air box around the aftermarket filter!
HRE | giulio is offline
Old 07-07-2000, 08:42 AM   #10
ndmorespd
Member#: 1657
2k RSish
BRP
Wink
giulio,
Sorry boss, some of us like to drive our cars on the street as well...
But hey thanks Anyway Giulio...
Mike
Old 07-09-2000, 09:35 PM   #11
Snyder2.5
Member#: 520
1999 Impreza RS
Post
Ive seen pics were people have turned there intake maifold around so as the front mount IC had a staighter path. Could you use this process and graft the TA Ram Air to it. Use the TA Ram Air Filter Box and Underhood stuff with our scoop. Just a thought? My neighbor has a TA I will tak a good look at everyhting and see if that would work Ill let you know
Snyder2.5 is offline
Mod in the making... Ram air duct, nearly finished frayz Member's Car Gallery 41 06-25-2006 11:08 AM
hack CAI to make ram air style intake? SLowery Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-13-2003 09:28 AM
How do you make a fast N/A 02RS?? IBO Normally Aspirated Powertrain 7 05-22-2001 02:28 PM
how do i make my stainless steel exhaust look new again? Keirik Interior & Exterior Modification 20 05-13-2001 11:53 AM
How do I make the car want to turn? MY99 2.5GT Legacy Forum 20 05-03-2001 11:43 AM
