Welcome to the North American Subaru Impreza Owners Club Tuesday July 16, 2024
Old 10-31-2002, 11:51 PM   #1
Tattoo Collector
Member#: 19364
1998 Impreza RS
Black Mica Pearl
Default Everyone......Look.........Pistons!!!!!
I guess I made you look. Now that I have your attention. I need to know everywhere I can find higher compression pistons for my car. I emailed ION so they're getting back to me and JE only makes lowered compression ones unless I want to get custom ones. I don't want to pay crazy amounts of money, but I do realize it's going to cost me. If anybody has info on where to get these things, please let me know. Maybe if you give me a good lead, I'll give you a ride when I get it done.........
Planned Mods:
-Higher compression pistons
-Lightweight connecting rods (need somewhere to get these too)
-I am balancing the crank myself
-I am doing 2 angle valve job on the valves and 3 in the head (myself)
-port and polish
-Fidanza 9.5 lb flywheel
-Vitek stage 4 clutch (or cobb, haven't decided)
-STI motor & tranny mounts
-ProECM
-Extrude Hone Intake (possibly)
-New fuel pump and injectors if I need it
Can anyone think of anything else that I might need to do, or should do while I have the engine apart?
Thanks.
Nathan
Tattoo Collector is offline   Reply With Quote
Old 11-01-2002, 01:15 AM   #2
dcoty
Member#: 3149
01 V7 GC/R32 sky
Id be interested in purchasing these pistons with you as well since you are on your way to where I want to be. Heres my mods:
borla headers
randon tec hi flow cat
strommung cat back
cobb cai
unorthodox ud pulley
custom ported and polished cylinder heads
cobb racer camshafts
custom ported and polished intake manifold
cobb springs
cobb retainers
custom matched vavles
ACT street clutch
lightend stock flywheel (14 lbs)
upgraded fuel pump
STi motor mounts
STi tranny mounts
I have the unichip and rev module to do the fuel timing and raise my redline to 7,500 rpm, it will be installed on the 11th this month.
Pistons are my next wish, but not anytime soon, however, i would still like to find some. I also need new fuel injectors to be on the safe side.
Nice mod list, let me know if you find anything! Did you try J&E pistons? My brother has a set for his turbo audi 90, I dont know if they offer for us. Anyway, good luck!
Dan
dcoty is offline   Reply With Quote
Old 11-01-2002, 02:47 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
TWE has custom forge 11.0:1 pistons.
jeremy
Old 11-01-2002, 09:38 AM   #4
PeterJ
Member#: 14727
2002 impreza RS
Paeco industries http://www.paeco.com These guys do all sorts of things for 4 cylinder engines. You can just about get any compression you want. I don't think they list all prices on the site but you can ask for a catalog, which has loads of more information anyway.
Edit: piston sets $380
PeterJ is offline   Reply With Quote
Old 11-01-2002, 10:34 AM   #5
EJ25
Member#: 10768
On the side, thin metal gaskets are a cheap way to raise your compression a bit... I am interested in hight compression pistons as well. 11:1 at least... maybe 12:1 if there is enough clearance...
EJ25 is offline   Reply With Quote
Old 11-01-2002, 01:19 PM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Cobb Tuning has the option to have them do a fully built NA block with 11:1 compression. You might want to try and give them a ring.
-Jon
Old 11-01-2002, 01:43 PM   #7
Pinochle
Member#: 638
93 L, 00 RS, 04 TS
pat + nat
Sounds great! Lemme know when you find something! I'd totally be interested in checking them out!
Pinochle is offline   Reply With Quote
Old 11-01-2002, 06:10 PM   #8
moogooob
Member#: 15764
00RS -Dumb all over
A little ugly on the side
Default educate me please.
Just for a comparison to demonstrate the effect of different pistons.
Say we had identical cars with the exception of compresion ratios(due to different pistons). What would be the characteristics of each car if they were:
8:1
9:1
10:1
11:1
12:1
moogooob is offline   Reply With Quote
Old 11-01-2002, 09:56 PM   #9
obyone
Member#: 16523
Yes, but what octane would you need to run to keep your engine from destroying itself?
obyone is offline   Reply With Quote
Old 11-02-2002, 10:50 AM   #10
Pinochle
Member#: 638
93 L, 00 RS, 04 TS
pat + nat
Default Re: educate me please.
8:1
9:1
10:1
11:1
12:1
This is a great question. Anyone want to tackle this one? I'm too tired. Haha!
Old 11-04-2002, 10:53 AM   #11
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
If you search back a ways, there was a compression ratio vs boost thread done. While it is forced induction, a lot of the same principles may apply. From what I recall, anything much over 11:1 on the backside of the bell curve and isn't useful.
-Jon
Old 11-04-2002, 01:16 PM   #12
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
19 Audi RS3, 13 Armada
I know 14:1 compression in a bored 427 makes a real loud cracking pop exhaust tone that is unparalleled!!
While you have the engine opened you could bore and stroke it drop compression to 8:1 and prep the heads for boost
Youve heard the saying:
High Compression is Cool, Nitrous is Nice, but Boost Blows them all away.
MY99 2.5GT is offline   Reply With Quote
Old 11-04-2002, 01:34 PM   #13
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Okay so that was a pretty cheesy saying. I didn't invent it though. I saw it on some guys T-shirt at an NHRA DragRace Event. It actually said "High Compression is Cool, Nitrous is Nice, But I'll Take Mine Blown".
I have to confess my uncle's 69 Camaro with a bored 427 with 14:1s sounds so viscous and makes pretty good power. However my dad's Camaro with Blown 383 stroker makes a nice whine and easily makes more power then the 427. Cost wise parts are so widely available for these big V8 engines and the power gains from doing high compression compared to the low cost of what actually needs to be replaced and work that needs to be done to prep for hi comp it seems pretty favorable to go that route over supercharging.
However what most people have found is that the gains acheived by fully prepping a 4 cylinder engine for hi compression NA use and increasing displacement isn't worth the money and time when low boost options are much less hastle and cost competatively and will provide better end result.
Just Opinions
Brad
Old 11-04-2002, 09:37 PM   #14
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
(nods in agreement with MY99 2.5GT) if cost is any concern at all you may want to do a price breakdown if possible. I did and was quite shocked at the dollar to HP ratio.
Poppa smurf is offline   Reply With Quote
Where can I find a good clutch for my car? ImprezaTs Canada Region Forum 4 01-30-2006 01:46 PM
Where can I find a 19psi WGA for my turbo... AaronWRX Engine Management & Tuning 2 08-18-2005 08:09 AM
Where can I find a RB5 wing for my 2.5 RS? poopysnaps Private 'Wanted' Classifieds 9 01-31-2004 05:20 PM
Where can I find replacement rubber pads for my STi pedals? Robmat Interior & Exterior Modification 0 07-21-2002 07:09 PM
('93-'01) where can i find clear directional lenses for my 99' RS? ILUVMY2.5RS Impreza Forum 4 09-26-2001 01:57 AM
