08-28-2001, 12:26 AM | #1 |
Subtly Outspoken
Moderator Member#: 238
Vehicle:OG05 STi 51E |
Compression Question
What is the optimum Compression ratio that I should acheive for a full blown buildup.....8:1??? 8.5:1??? or even maybe 9:1
What would you guys think??
08-28-2001, 09:01 AM | #2 |
Moderator Member#: 922
Vehicle:16 WRX (white) 04 FXT (red) |
Depends what you're shooting for and what type of power you want. Higher compressions get you more down-low torque, while lower ones can handle more boost and get you more high-end power.
08-28-2001, 12:25 PM | #3 |
Member#: 1426
NESIC
Vehicle:'07 335xi,14 Tundra 848 Evo Race Bike |
Allrighty.. so let's paint the picture of a daily driven MY00 2.5RS running 7psi; capable of a 12 psi on race gas for those special days. I was thinking 9.0:1?? Sound good?
Fitz |
08-28-2001, 12:37 PM | #4 |
Member#: 5786
Maybee having the lower compression would save a few trannies out there. Less torque = Less stress on gears?
Kevin |
08-28-2001, 02:02 PM | #5 |
Subtly Outspoken
Hey Danny...what compression ratio was your 2.2....Built motor...
I want reliability, I WILL have some sort of engne management Tec2, Ultronic or equivilant. I will also have forged piston and rods...I know the lower you go the more boost you can apply but I also wnat the bottem end torque...9:1 is sounding really good right now... |
08-28-2001, 02:29 PM | #6 |
Member#: 673
BAIC
Vehicle:1999 2.5RS-T <RIP> 2000 RS-TURBO'D |
If you have the 2.5, don't go any lower than 9:1 otherwise it will feel like a 2.0L at the low end. But, you'll be able to run LOTS of boost with 8.5:1.
Whatever suits your needs. |
08-30-2001, 03:03 AM | #7 |
Member#: 2038
Vehicle:2000 RS-T Silverthorn Metallic |
I'm running 9:1 and got cams put in and it feels about the same as 10:1. I'm still running the same boost until I can get engine management and injectors, which will be real soon.
08-30-2001, 04:40 AM | #8 |
Subtly Outspoken
Thanks....
Good...That means my research is paying off....
Hey 8....Are you getting this??? |
08-30-2001, 12:32 PM | #9 |
Member#: 7190
I believe that 8.5:1 is the best comp ratio out there for a turbo engine, dependent on target boost pressures. If you are only looking at a maximum of 12psi the you can keep your stock compression ratio and just get good quality (venolia, arias) pistons. You can tune that to run everyday at 12psi on pump gas. ECU and turbo premitting...
However! Why limit yourself?? If you are building the motor might as well make it so you can have all the HP you want! Get something in between 8.5:1 and 9:1. Its a real sweet spot. 8.8:1 would work really well. Then you can run 16 -20 (again, other equipment permitting) on pump gas and 28 on race (c16 anyone? ) if your block will take it..... Your transmission will if you are drag racing. Just don't stay in 2nd gear too long. The tranny isn't that weak. There are ways around holes in the case. Just some thoughts |
08-30-2001, 12:55 PM | #10 |
Personally, I was thinking of building a block to give me good torque and run extremely fast at 12psi as well. I was thinking that 9.5:1 is about right on the ragged edge of safe vs. blown up, so I'll probably go with that and settle for 10psi. At that point I shouldn't have troubles with built Corvettes, while still being able to autocross the car.
I have a friend who having his DOHC EJ25 built by a very reputable tuner. Latest dyno test showed over 400hp at the flywheel at 15-16psi, I believe he is running 9.7:1 compression. Crazy crazy car, I will love to see it on the road/track. I'm sure everyone will get a report on this as soon as it is done, though I suppose it's possible he'll hit a few mag's too. |
08-30-2001, 01:47 PM | #11 |
Worst Mod Ever
Moderator Member#: 369
SWIC
Vehicle:19 CTS-V, 18 XC90 17 GTI |
If my car ever gets finished I can let you know how 8.5:1 is with off-boost response and lower boost settings.
I wouldn't hold your breath waiting for my info though as it may be a while... Aaron http://www.azscooby.com http://www.scoobymods.com |
2.2 High compression questions | cjfike | Normally Aspirated Powertrain | 13 | 11-21-2004 10:35 AM |
2.5 Compression Question | widesuby | Normally Aspirated with bolt-on Forced Induction Powertrain | 3 | 08-06-2003 01:04 PM |
Compression Question | brokemypiston | Normally Aspirated with bolt-on Forced Induction Powertrain | 77 | 01-12-2003 02:04 PM |
Theoretical boost and compression question | pegdrgr | Engine Management & Tuning | 5 | 11-23-2002 04:21 AM |
A follow up on my compression questions and the answers as well.... | Fitz | Normally Aspirated with bolt-on Forced Induction Powertrain | 1 | 09-03-2001 02:14 PM |
