Welcome to the North American Subaru Impreza Owners Club Monday July 13, 2020
Old 03-31-2020, 12:55 PM   #601
super_subie
Member#: 344431
2020 STI
CWP
are the 2020 STI wheels the same as previous models? I only saw the previous model but noted as size 19x8.5...i thought they were 19x9.5?
super_subie is offline   Reply With Quote
Old 03-31-2020, 01:15 PM   #602
nightVzn
Member#: 291558
2020 WRX Limited
To all appearances (correct me if I'm wrong if anybody knows otherwise), the 2020 STI wheels are the same as the 2018-2019 ones with the exception of a machined finish on some spokes. Looks like they even just mildly photoshopped last year's photos for the 2020 gallery.
Specs seem the same otherwise. Although maybe that machining shaves off a negligible amount of weight
S209 gets wider wheels. But only 9" according to page 1 of this thread and the Subaru website, not 9.5.
nightVzn is offline   Reply With Quote
Old 04-01-2020, 09:34 PM   #603
Leonardo
Cowabunga!
Super Moderator
Member#: 185
1999 Impreza wagon
Dark Gray Metalic
Yes, cosmetic differences are what stands the separates the 2020 from the previous years.
Leonardo is offline   Reply With Quote
Old 04-04-2020, 10:56 PM   #604
tirving
Member#: 513183
2012 OB 3.6R Limited
Graphite Metallic Grey
Default I need help figuring out how much my OEM 17" wheels weigh for my 2012 OB 3.6R
OK, I have definitely scoured this thread and, unless I missed it, I can't for the life of me, find weight info for these rims, they're 17", came stock on my 2012 Outback 3.6R. The reason is, I am looking at a set of BRZ rims that will fit and want to know if there's an unsprung weight savings. Am I just missing the stats for this wheel in this thread? I'd like to shave off some weight if possible, from the wheels because I am getting some beefier AT tires.
tirving is offline   Reply With Quote
Old 04-04-2020, 11:05 PM   #605
chanomatik
Member#: 159474
2017 Impreza Sport
Lithium Red - OLDKID
BRZ wheels are definitely lighter.
Old 05-14-2020, 09:01 PM   #606
gellomero
Member#: 427158
2008 WRX STI
Check all over this thread and canít find anything about it but this are OEM Enkei Wheels out of a 2019 WRX with Brembo option, I test them on a 2012 STI and have a bit more then 1/8 of and inch so about 3.5MM of clearance. Tight fitment but no rubbing at all, also the rear Brembo brakes have so much free room that didnít bother to take pictures
Please Moderator feel free to delete post if not allowed.
gellomero is offline   Reply With Quote
Old 05-15-2020, 08:57 AM   #607
Detslider
Member#: 170244
'06 WRX
& '16 OB
Dan, awesome thread! Thanks for doing the research and putting it all in one place. I came here looking for stock specs for a 2006 WRX Wagon and noticed the specs listed here are different than what is on the fastwrx.com site.
I checked the door plate on my car and it says the stock tire size is 215/45R17. Can you confirm if the backspacing is +55 or +53?
Thanks! When the storefront opens again I'll be sure to swing by and do some impulse shopping.
Originally Posted by Mach V Dan View Post
2006-07 WRX
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 21.0 lbs (Mach V shipping scale)
OEM-equipped tire size: 215/45R17
https://www.fastwrx.com/pages/subaru...el-information
2006-2008 WRX wheels:
Bolt pattern: 5x100
Centerbore: 56.1mm
Wheel size: 17 x 7.0"
Offset: 53mm
Stock tire: 205/50R17
Detslider is offline   Reply With Quote
Old 05-15-2020, 11:09 AM   #608
Mach V Dan
Member#: 12029
Originally Posted by gellomero View Post
Check all over this thread and can’t find anything about it but this are OEM Enkei Wheels out of a 2019 WRX with Brembo option, I test them on a 2012 STI and have a bit more then 1/8 of and inch so about 3.5MM of clearance. Tight fitment but no rubbing at all, also the rear Brembo brakes have so much free room that didn’t bother to take pictures
This is interesting because it appears Subaru made a running change on this wheel design. When this style first came out in 2018, it did NOT clear four-piston Brembos. Now (2019 model year and later), it DOES.
...Can you confirm if the backspacing is +55 or +53?
+55.
Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
WTB : Alloy WHEELS or nicer oem subaru wheels to replace my ugly steel wheels MR2fanatic Tri-State Area Private Classifieds 7 04-03-2011 09:24 PM
WTT: OEM subaru wheels/tires for Gold 17" wheels veselik3 NWIC Private Classifieds 2 05-16-2006 03:24 PM
gauging interest: rs 16x7 gold wheels 5 spoke oem subaru wheels anthonyrb98 Private 'For Sale' Classifieds 53 04-27-2006 12:43 PM
Anyone have a set of OEM WRX wheels they want to get rid of? Skibum4444 North West Impreza Club Forum -- NWIC 2 01-31-2003 12:48 AM
Subaru Wheel Specs Snowrider Brakes, Steering & Suspension 3 10-07-2001 09:20 PM
