Welcome to the North American Subaru Impreza Owners Club Wednesday July 15, 2020
Old 01-08-2017, 04:21 AM   #5976
Ftheref187
Member#: 429596
2016 WRX
Crystal Black Silica
Sorry if this is a stupid question but would 18x10.5 +20 with 245 40 tires fit without rubbing? Or would any modification have to be done?
Ftheref187 is offline   Reply With Quote
Old 01-08-2017, 09:48 AM   #5977
6spdwrx
Member#: 421831
Wider tires, fender flare, coilover, camber adjustment. That thing will poke out like a mofo. Or you can join the cambergang hehehe
6spdwrx is offline   Reply With Quote
Old 01-08-2017, 10:28 AM   #5978
302Rex
Member#: 436869
2016 WRX
ISM
Originally Posted by Himynameisgreg View Post
this is with +15mm, please dont do it
302Rex is offline   Reply With Quote
Old 01-08-2017, 03:12 PM   #5979
skeeter281
Member#: 403893
2015 STi Limited
WR Blue
skeeter281 is offline   Reply With Quote
Old 01-08-2017, 08:41 PM   #5980
aniltip
Member#: 394300
2015 WRX Limited
Dark Gray Metallic
Dude that fitment is horrible!!
aniltip is offline   Reply With Quote
Old 01-09-2017, 11:31 AM   #5981
CSF707
Member#: 400497
2015 STi Limited
Galaxy Blue Pearl
Originally Posted by mmhdavid View Post
Do you guys use hubcentric rings?
I'm wondering this too
CSF707 is offline   Reply With Quote
Old 01-09-2017, 05:42 PM   #5982
skeeter281
Member#: 403893
2015 STi Limited
WR Blue
Default 2015 WRX/STi Aftermarket wheel and tire fitment
Yes, they're not "technically" required but they make mounting easier/simpler.
Old 01-09-2017, 09:38 PM   #5983
TylerLieberman
Member#: 416864
2016 STI
Originally Posted by snobrder_ad View Post
What I don't get is that you spend all that time and money in suspension, then run cheap tires... Unless all that camber wears the **** out of them and you go through them like mad...
Camber will wear them out faster, yeah... But seriously... At that height and with those wheels, does he really need RS3s or ZIIs?
TylerLieberman is offline   Reply With Quote
Old 01-09-2017, 10:33 PM   #5984
sork83
Member#: 325152
2016 WRX
CWP
Miro 112 18x9.5 +40 with Pirelli P Zero 255/35/18
sork83 is offline   Reply With Quote
Old 01-10-2017, 02:02 AM   #5985
evei0326
Member#: 451587
Default 2018 STi Six Pot Brembo and 18" wheels
Hello,
I am pretty excited about new STi minus the no fog light.
I have been planning and getting alot of help from this forum. So Thank you.
Now, New Problem......
Time will tell but, With 18inch aftermarket wheels, Will it Clear the new bigger six pot brakes?
Thanks.
http://i.imgur.com/ojDnS51.png
evei0326 is offline   Reply With Quote
Old 01-10-2017, 02:19 AM   #5986
mmhdavid
Member#: 456346
2015 wrx
Ive read that at high speeds the wheels start to feel shaky also, is this true?
mmhdavid is offline   Reply With Quote
Old 01-10-2017, 03:04 AM   #5987
skeeter281
Member#: 403893
2015 STi Limited
WR Blue
I've been up to 140 mph or so and no vibration. If anything is misaligned when you're mounting the wheel to the hub, you'll most likely feel it. I'd get them just to make your life just a little bit easier.
Old 01-10-2017, 11:54 AM   #5988
aniltip
Member#: 394300
2015 WRX Limited
Dark Gray Metallic
I can also verify this isn't true (assuming the wheels are centered properly)
Old 01-10-2017, 11:59 AM   #5989
kaeknows
Member#: 357191
2016 WRX
ISM
rallysport stocks hubcentric rings for 20 shipped, just buy a set and have that peace of mind
kaeknows is offline   Reply With Quote
Old 01-10-2017, 12:02 PM   #5990
RoadSoldier
Member#: 461071
2016 WRX
Ice Silver
Hey guys, I've read through this forum and a few others trying to find an answer without having to post on it. That being said this is my first time commenting or posting on nasioc.
I drive a 2016 wrx base model and I'm replacing the hideous 17x8 wheels. I'm currently deployed so I'm pretty much modding my car from over seas and can't wait to get home.
I've already purchased some MB Battles 18x9.5 +15 and wrapping them in some 235/40R18 tires. I am not opposed to rolling the fenders when I get home but if I don't have to I'm not going to just curious if anyone has tried anything like this or close to it and if so will fenders need to be rolled for sure?
RoadSoldier is offline   Reply With Quote
Old 01-10-2017, 12:12 PM   #5991
6spdwrx
Member#: 421831
Yeah I'm almost positive it will rub. 245/40/18 tire with 18x9.5+15 was reported rubbing. Height difference between 235/40/18 and 245/40/18 is less than only 0.4 inch.
Old 01-10-2017, 01:43 PM   #5992
skeeter281
Member#: 403893
2015 STi Limited
WR Blue
+15 is pretty bad, dude. Why make your life so hard? Just get wheels that fit a bit better.
Old 01-10-2017, 01:49 PM   #5993
skeeter281
Member#: 403893
2015 STi Limited
WR Blue
Volk CE28, 18x10 +39
Old 01-10-2017, 02:25 PM   #5994
obZen
Member#: 357126
2015 WRX Premium
If I just got those wheels installed myself, I'd be too ecstatic to realize I wrote CE28 instead of ZE40 too
Looks amazing.
obZen is offline   Reply With Quote
Old 01-10-2017, 03:03 PM   #5995
OAKOS Automotive
NASIOC Storefront Vendor
Member#: 18261
2002 Impreza WRX w/
V9 Spec-C EJ207
Originally Posted by evei0326 View Post
Hello,
Thanks.
Notice how there is probably a 3/4inch to 1inch space between the outside of the new caliper and the inside of the wheel drum. An 18" wheel reduces total diameter by 1", but that clearance between the caliper will only decrease by half of that amount, or a 1/2inch. That would still leave a 1/4inch to 1/2inch gap in that area with an 18" wheel.
Plus these new calipers look identical to the JDM STI RA-R which had 18" wheels and still cleared.
-Ty-
OAKOS Automotive is offline   Reply With Quote
Old 01-10-2017, 03:21 PM   #5996
skeeter281
Member#: 403893
2015 STi Limited
WR Blue
Looks amazing.
Haha. Good catch. Just took my CE28's off.
Old 01-10-2017, 03:46 PM   #5997
Kami Speed
Member#: 96479
2006 WRX STI
Obsidian Black Pearl
Thats why you wanted more pics!! Twin life lol.
Looks good. How is that caliper clearance up front. Close huh?
Kami Speed is offline   Reply With Quote
Old 01-10-2017, 03:55 PM   #5998
bloominwrx
Member#: 432352
2004 M3
Silbergrau
How my '16 WRX sat before I sold her.
Wheels: Concave Matte Black 18x9.5+30 Enkei Kojins
Tires: Indy Firehawks 265/45
bloominwrx is offline   Reply With Quote
Old 01-10-2017, 03:56 PM   #5999
RoadSoldier
Member#: 461071
2016 WRX
Ice Silver
Awesome, thanks man I appreciate it! I had it in my mind I'd be rolling the rear fenders for that set up anyways. Also that was reported rubbing on the stock suspension, correct? If you could give me a link to where it states that I'd really appreciate that as well! I'd love to get my hands on anything I can read so I can learn about this stuff some more. Still very new to the game. Thanks again man
Old 01-10-2017, 05:02 PM   #6000
skeeter281
Member#: 403893
2015 STi Limited
WR Blue
It's tight but seems all good so far. I actually wasn't even planning on getting any ZE40's but I came across these local for a pretty good deal and snatched them up. Your pics definitely influenced me though.
