Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2020
Old 01-30-2020, 07:44 AM   #8401
Norm Peterson
Member#: 498642
'19 WRX Ltd 6M dgm
'08 Mustang GT (the toy)
The next step should probably be to find out exactly where/what on the sheetmetal is being rubbed.
There are a number of things that could make the difference between getting a little rub and not. Rear wheel camber, sheetmetal and build tolerances, to list a couple, plus the possibility that the actual offset on your wheels is a little less positive than advertised or that the actual width is a little wider. It is possible to determine wheel width and offset (fairly closely) without having to remove the tire from the rim.
Norm
Norm Peterson is offline   Reply With Quote
Old 01-31-2020, 06:08 AM   #8402
crayolamix
Member#: 511171
I'll try to figure out where its rubbing and take it from there. Thanks mate.
crayolamix is offline   Reply With Quote
Old 02-12-2020, 03:39 AM   #8403
Raccoon WRX
Member#: 511318
2017 WRX Limited
CWP
Default 2015 WRX/STi Aftermarket wheel and tire fitment
My first of (hopefully) many posts to come.
After weeks of practically living in this thread, then another couple of weeks picking the perfect set of wheels, I finally pulled the trigger.
Enkei TSR-X (new for 2020) in Gloss Bronze
18x9.5 +38 on Michelin Pilot Sport A/S 3+ in 255/35/18
Stock suspension for now, no rubbing as of yet.
I love how they came out
Last edited by Raccoon WRX; 02-12-2020 at 11:14 AM. Reason: Added suspension and fitment
Raccoon WRX is offline   Reply With Quote
Old 02-12-2020, 07:42 AM   #8404
thwrightstuff
Member#: 358745
2017 Subaru WRX
World Rally Blue
Very nice man! The fitment looks awesome. Are you running aftermarket suspension or wheel spacers or anything special beyond stock? Any scrubbing going over speed bumps or potholes?
thwrightstuff is offline   Reply With Quote
Old 02-12-2020, 11:12 AM   #8405
Raccoon WRX
Member#: 511318
2017 WRX Limited
CWP
Ah I forgot to mention the fitment!
Stock suspension at the moment, but looking to go with RCE yellows in the near future.
Havenít had any fitment issues so far. I check every now and then for signs of rubbing since these seem to poke slightly more than most of the +38 wheels Iíve seen. But so far so good, knock on wood.
Old 02-12-2020, 12:10 PM   #8406
arempee26
Member#: 491364
These tires are much somehow wider and fatter than any tire brand. I shouldíve went with these tires instead of the Potenzaís RE980AS.
arempee26 is online now   Reply With Quote
Old 02-12-2020, 01:16 PM   #8407
Raccoon WRX
Member#: 511318
2017 WRX Limited
CWP
I had read that the PSS ran a little wider than most tires and so I assumed the A/S version would be similar. I was trying to avoid the stretched look and it seems to have worked out. Whether that means rubbing or not, Iíll have to see.
Old 02-14-2020, 07:44 AM   #8408
thwrightstuff
Member#: 358745
2017 Subaru WRX
World Rally Blue
Has anybody tried this fitment with the Eibach lowering springs?
Old 02-15-2020, 08:23 AM   #8409
Norm Peterson
Member#: 498642
'19 WRX Ltd 6M dgm
Both the AS3+ and the RE980AS list a 10.2" section width. Tread width (a pretty fuzzy thing in my opinion) is slightly wider in the Michelin (9.3" vs 8.7").
Norm
Old 02-15-2020, 08:38 AM   #8410
Norm Peterson
Member#: 498642
'19 WRX Ltd 6M dgm
Haven’t had any fitment issues so far. I check every now and then for signs of rubbing since these seem to poke slightly more than most of the +38 wheels I’ve seen. But so far so good, knock on wood.
I can think of at least one possibility, that being where the outer flange for that particular wheel design is thicker than the inside flange or has a 'wider' shape. That would move the plane of the wheel's outer face further outward relative to where it would be if the flanges were of equal thickness/shape. The tire would tend to look slightly more 'stretched' as well because you'd be seeing more flange.
You may be able to determine if this is the case by measuring backspacing and actual wheel width to arrive at an actual "frontspacing" number. Both of those wheel measurements can be determined without having to remove the tire from the wheel (for wheel width you may need to make three measurements and do some math).
Norm
Old 02-15-2020, 08:51 AM   #8411
Norm Peterson
Member#: 498642
'19 WRX Ltd 6M dgm
Turned out really nice. Bet the handling is pretty 'crisp'.
Norm
Old 02-15-2020, 11:16 AM   #8412
arempee26
Member#: 491364
Norm
When my buddy got his new wheels (same specs to mine) we compared them both and his wheels/tire combo looks much wider imo. They look much better too.
Old 02-22-2020, 06:36 PM   #8413
Stoleyourboard
Member#: 483007
2018 Subaru
ISM
Yeerr
Stoleyourboard is offline   Reply With Quote
Old 02-27-2020, 11:30 AM   #8414
bg02
Member#: 484523
2016 WRX
I currently have gram light 57xtremes 18X9.5 +40MM on 255/35/18 firehawk indy 500s on my 2016 WRX on stock suspension.
Can someone recommend a set of wider summer tires that would allow me to maintain my stock suspension with no rubbing? Trying to get away from the stretched look the firehawks currently have on the wheels.
bg02 is offline   Reply With Quote
Old 02-27-2020, 11:35 AM   #8415
OAKOS Automotive
NASIOC Storefront Vendor
Member#: 18261
2002 Impreza WRX w/
V9 Spec-C EJ207
265/35/18 is what you're looking for.
OAKOS Automotive is offline   Reply With Quote
Old 02-27-2020, 11:43 AM   #8416
thwrightstuff
Member#: 358745
2017 Subaru WRX
World Rally Blue
I think for your wheels, 255 or 265 is fine. As far as actual tires, I would highly recommend Michelin Pilot Sport 4s. They are hands down the best rated summer tire out there currently. They make them in that size.
Old 02-27-2020, 12:57 PM   #8417
bg02
Member#: 484523
2016 WRX
Got it, will take a look. thanks
Old 02-28-2020, 12:26 AM   #8418
vladd
Member#: 158185
17 WRX
CWP
Damn, these wheels look amazing. I wonder how different they'd look in stock size of 18x8.5. Anybody have pics? Thinking about picking up a set.
vladd is offline   Reply With Quote
Old 02-28-2020, 09:38 AM   #8419
soloz2
Member#: 260128
2019 WRX Limited
Lapis Blue Pearl
I see lots of people running 18x9.5 +35, but I've heard this could cause some steering feel issues and is a rather aggressive fitment. I'm looking at wheels and would like fitment closer to stock. I was looking at something along the lines of 18x8.5 +50 enkei ts10, or even a slightly more aggressive kong rennform 18x9 +40. Would I run into any potential issues running either wheel on stock suspension and stock summer tires? I'm leaning towards a fitment closer to stock. I don't like the poked or stretched look and want function.
soloz2 is offline   Reply With Quote
Old 02-29-2020, 04:12 AM   #8420
iriemark
Member#: 404616
2015 WRX Limited
CWP
Do you have pics of the stretch? Iím on the same tire wrapped on 18X9.5 +38mm TE37 Sagas lowered on HKS Hipermax GT coilovers lowered about 1Ē all around and it doesnít bother me much. I do like a beefy tire and will get 265s next time.
For those wondering, I have ZERO rub with this setup with 4 adults in the car.
iriemark is offline   Reply With Quote
Old 02-29-2020, 03:56 PM   #8421
thwrightstuff
Member#: 358745
2017 Subaru WRX
World Rally Blue
Does anybody have any pictures of their stock WRX with the stock 17in wheels, but on the Eibach spring drop? I am torn between taking the cheaper approach of lowering springs and wheel spacers or going for the correct wheel/tire setup.
Ideally, I would like to save as much money because I want to build an FF 427 Shelby Cobra
Old 03-01-2020, 04:59 PM   #8422
skeeter281
Member#: 403893
2015 STi Limited
WR Blue
New wheels for spring. Custom concave offset, 18x9.5 +38. Prob go w 275/35 PS4ís.
skeeter281 is offline   Reply With Quote
Old 03-03-2020, 04:37 PM   #8423
jdmct9mr
Member#: 289223
2015 STI
CBS
Nice man. Canít wait to see these on your car!
jdmct9mr is offline   Reply With Quote
Old 03-03-2020, 08:55 PM   #8424
JimmysRC
Member#: 501341
2019 WRX
Dark gray metallic
Does anyone have experience with the Fitment with an 18x8.5 rim with a 35mm offset concave style? I’m looking at something like the Rota grid. I’ve got a stock suspension and plan to use the factory tires. Got a 2019 WRX premium.
JimmysRC is offline   Reply With Quote
Old 03-04-2020, 09:11 PM   #8425
dpetro1
Member#: 487500
2018 WRX
Originally Posted by JimmysRC View Post
Does anyone have experience with the Fitment with an 18x8.5 rim with a 35mm offset concave style? Iím looking at something like the Rota grid. Iíve got a stock suspension and plan to use the factory tires. Got a 2019 WRX premium.
Should fit fine. Those are only 20mm difference in offset from stock.
Here is a 18x8.5 +44 but it would be very similar
dpetro1 is offline   Reply With Quote
