#26 |
Member#: 372777
SCIC
Vehicle:2014 WRX Sedan Lmtd WRB |
![]() yeah I think im hybrid as well, because my tuner said it was still using the MAF but its SD.
#27 | |
Member#: 493578
Vehicle:2017 STI White |
![]() Quote:
I will be reaching back out to the new tuner tomorrow to see if he has any thoughts on clearing it up. I'm on MAF, for what it's worth. |
#28 | |
Member#: 320853
![]() Quote:
Have you guys watched the signal from the front 02 at all when this happens? Once it warms up and goes to change cycles it seems to stumble until finding itself again. Happens too fast to get a good log and understanding of why. |
#29 | |
Member#: 428511
Vehicle:2016 STI |
![]() Quote:
#30 |
Member#: 496443
![]() For me it’s worth it because I truly enjoy Subaru’s and this platform. It may not be the most cost effective way to get the power compared to other platforms, but it’s there. Honestly other than this small inconvenient issue, I’ve has no issues on this setup for the last 15k.
#31 |
Member#: 78751
Vehicle:2017 Sti ISM |
![]() Barometric pressure sensor. When I did my big build, it was accidentally taken out. Not until I purchased a new one and installed it did this problem go away. No need to retune for it either.
#32 |
Member#: 496443
![]() Something so easily overlooked, theoretically it makes perfect sense. I just pulled that bad boy off my shelf (drivers side, big connector as compared to the passenger side because it’s where the sensor is). Took me 10 minutes just to find where the harness was tucked away under the manifold lol but I’ve hooked it up and waiting till morning for a full cold start. If this works, I’ll let you guys know and will be cutting the Sensor out of the housing.
#33 |
Member#: 495114
Vehicle:2002 Subaru WRX Blue |
![]() My car has been tuned to just turn the rear 02 sensor off and it hasn’t had this problem.
#34 | |
Member#: 493578
![]() Quote:
I thought this at first too, especially since I also removed the air pump at the same time. Either that or that it was related to the TGVs, except those have been being deleted for years without consequence now. My Baro sensor is still connected, and presumably working. I cut mine off of the cap like I saw some people do, and just left the sensor tucked away in the engine bay. When I log the car, I can see the barometric pressure reading change day to day, location to location, so, I'm assuming it's still working correctly. I'm unsure if my rear O2 is enabled or not. I'm running a cat, and the sensor is there and connected, so I'm assuming the tuner left it on. Edit: Just double checked mine, and it seems to be working. Is reading 14.23 today, and it showed 14.07 2 days ago in a data log. 14.23 seems to be a bit low compared to the airport's reading of the pressure, but I'm also slightly up on a mountain, so....? Last edited by Haive_Music; 01-26-2019 at 12:07 PM. |
#35 |
Member#: 493578
Last edited by Haive_Music; 01-26-2019 at 12:04 PM. Reason: accidental double post |
#36 | |
Member#: 496443
![]() Quote:
I have my rear 02 enabled but only because I have my Wideband tapped into the rear 02 harness to log on the access port. Everything is pre cat and functional / calibrated. |
#37 |
Member#: 496443
![]() Just to clarify you had this issue prior to shutting off the rear 02 sensor. Then when disabled the rear 02, the problem went away? Are you running a Wideband to gauge only with no physical connection to the ECU?
#38 | |
Member#: 493578
![]() Quote:
I have no way of editing my map unfortunately, and still haven't heard anything back from my tuner yet about this. |
#39 | |
Member#: 78751
![]() Quote:
Have you reset your ECU? Sad that didn’t fix. |
#40 |
Member#: 496443
![]() Nothing changed with the idle issue, and yea reset the ECU. This is frustrating. Rear 02 shouldn’t have an effect on the cold start but worth a shot since I’m out of ideas.
#41 |
Member#: 477741
![]() Exactly the same issue here. 2018 STI all the bolt-ons + e85, except turbo. Has died on me once... tuner (brentuning), states that it could possibly be from the e80 fuel, recommended me to put e60 to see if it solves. Nothing yet. Its just a minor inconvenience.
#42 | |
Member#: 496443
![]() Quote:
#43 |
Member#: 477741
![]() Very possible. I wouldn't be surprised if its ECU related. I'll email my tuner tomorrow with this information.
#44 | |
Member#: 493578
![]() Quote:
I've had 2 people tell me it's related to the air pump delete now, but still no word on a fix. It just seems odd to me, as people have been removing those for quite some time now. It would make sense that it would be related I suppose, after about 20 seconds the air pump would kick off, and the car would probably cut the amount of fuel it's injecting to compensate for that. Still, you'd think there would be compensation tables for this, and other years would have seen this issue happening before now. Last edited by Haive_Music; 01-28-2019 at 07:23 PM. |
#45 |
Member#: 477741
![]() The thing is I don't have an air pump delete, not sure if a possible leak could be an issue but ill get around looking at it.
#46 |
Member#: 493578
#47 |
Member#: 493578
![]() Any news on this?
STIAH64 - Did you ever get a chance to disable your rear o2 and see if this resolves the issue? I can't even get the shop who did my tune to call or email me back. I sent them in a log per their request about the issue, and almost 3 weeks later, I can't get them to pick up the phone or right back. |
#48 | |
Member#: 496443
![]() Quote:
#49 | |
Member#: 493578
![]() Quote:
I too feel it's related to TGVs, but again, just like you're thinking, these have been being removed for years now. Why is the issue just now creeping up? More so, I can log my car and see that the TGV setting remains unchanged on start up - meaning, it should be disabled in my tune, so is there something else that's changed or causing the car to think it's still there? I don't know..... Grasping for straws at this point. |
