02-15-2007, 04:21 PM | #1 |
Member#: 139293
whats the deal with Snow and Ice in the well?!
Iv noticed that my 03 Wagon builds up a very large amount of snow and ice in each wheel well anytime the weather gets that nasty. The stuff just cakes right on. and ices over so you cant just Knock it off. Its even touches the tires sometimes, on the highway you can hear the tire rubbing the unbreakable snow/ice thats caked on. I dont drive in any worse conditions then anyone else, and i dont see it being such a problem on other cars.
so whats with the design and how the hell can I prevent this/break the ice snow without breaking plastic with it. again, its literally grinding on my front two tires, the rear two have MAYBE a paper width between the snow/ice and tire, but the fronts hit especially when trying to turn u hear the tire rubbing, or decelerating (nose dips) you hear the rubber.
02-15-2007, 04:29 PM | #2 |
Member#: 140639
Vehicle:2007 WRX Impreza LTD WRB |
You should see how much Snow/Ice would build up on my 04 Stang
The best way to fix it is to keep the car in a warm place, preferrably a garage. If you don't have one, the only thing to do is wait until it warms up a bit and then try knocking it off with a snow scraper, or at least thats what I do. |
02-15-2007, 04:34 PM | #3 |
Member#: 87067
AKIC
Vehicle:02 Old but tasty SRP |
+1 snow scraper knocks it right out. It happens.
02-15-2007, 04:38 PM | #4 |
Member#: 105654
^ not always.....i hooked up a hose to the hot water line and the ice came right out
02-15-2007, 04:39 PM | #5 |
Member#: 66540
Vehicle:2004 WRX Sedan 2005 Legacy GT wagon |
Ummm...take it to a car wash? I mean really, this is not a Subaru problem this is a car problem. I've never owned any car that didn't do exactly what you're talking about.
02-15-2007, 04:44 PM | #6 |
Member#: 139293
Iv never owned any car that did EXACTLY what i mentioned, we're talking the whole wheel well gunked up it gunks itself up, atleast the other cars I had kicked most of the stuff away and out of the wheel well,
02-15-2007, 06:14 PM | #7 |
Member#: 51358
RMIC
Vehicle:2007 FXT Once a month its blue. |
I keep a gardening tool in my car called a "manual weeder" or somethin glike that. Discovered years ago that its the perfect tool for chunking compacted ice/mud out of wheel wells. I'll try to find you a picture.
Usually can be found at Home Depot and the like...about $3-4. You can see the tip is slightly angled. Helps to keep from scratching the fender liner. Happy Scraping. Last edited by Immerkuhl; 02-15-2007 at 06:17 PM. Reason: pic |
02-15-2007, 07:41 PM | #8 |
Member#: 139293
^ thankyou for providing me with a suggested solution, I am going to pick one up as the temps have not reached above freezing yet. You guys Rawk
02-15-2007, 08:13 PM | #9 |
Member#: 94283
NESIC
Vehicle:'19 Ascent |
I use the manual carwash to clean the snow and ice out of my wheels and wheel wells. I don't usually pay. I just use the spray wand and the slight amount of warm water that comes out to dig out all the frozen crust. It works great.
02-15-2007, 09:28 PM | #10 |
Member#: 135005
Vehicle:1999 Impreza L Red |
Try waxing the wheel-well or applying some spray-on silicone lubricant. Both work fairly well.
02-15-2007, 09:58 PM | #11 |
Member#: 94070
South East
Vehicle:05 LGT PSM |
Be careful when trying to remove it, sometimes you can remove items off your car you dont want off, fender liners, mud flaps and side skirts are easily broken trying to remove ice. It will fall off eventually.
look at where I live I should know. Jay-R |
02-15-2007, 10:30 PM | #12 |
Member#: 140197
TXIC
Vehicle:2000 RSTi Blue Ridge Pearl |
i have the same problem with the snow/ice and such. i see many other cars in the area with the same issue as well. my fiancee's eclipse spyder does the same things. you just have to try and keep it cleaned out, with a good strong tool to scrape it out (careful not to scratch the paint tho). that is the best i have found. i aleady broke one snow brush this year cleaning the wells out. good luck to you, everyone in snow areas has to deal with it.
02-15-2007, 11:10 PM | #13 |
Member#: 135893
NWIC
Vehicle:2017 STI WRB |
Yeah, I've had tires get hot from the friction of rubbing against the packed wheelwell snow.......
Me ------> Why does my car smell like burned rubber? I'm in the freakin snow...... |
01-09-2008, 03:02 PM | #14 |
Member#: 103157
Vehicle:2005 WRX Wagon Black |
I live in Gunnison which gets around -15 in the winter nights most of the time and I get this problem on my wrx wagon, I just used a hammer to pound the ice out cause it was packed really hard and was frozen solid
01-09-2008, 03:12 PM | #15 |
Member#: 131915
Vehicle:2007 WRX sexy white pearl |
line your fender wells with salt if you know theres gonna be a lot of snow?
Hooray for Surprise Snow and Ice in Charlotte!!! | Glenn Hough | South East Region Forum | 3 | 02-04-2009 09:20 AM |
Question: What is the deal with portrayal of crime in Japan based movies? | Janq | Off-Topic | 55 | 06-19-2006 01:47 PM |
What is the Deal with Cobb and FIS? | fastcb | Texas Impreza Club Forum -- TXIC | 20 | 08-19-2005 10:05 PM |
what is the deal with people patting me on the head? | Disoriental | Off-Topic | 36 | 02-03-2004 12:21 AM |
