Welcome to the North American Subaru Impreza Owners Club Thursday October 18, 2018
Old 08-31-2018, 11:50 AM   #1
Wayne Suhrbier
Member#: 144044
2006 STI
Default Help Identify component in trunk light wiring
Does anyone know what this is and or for? It doesn't look OE. It was placed in line with the wires for the trunk light in a 06 STI. Trunk light works fine without it. Everything else in the car works fine also without it.
Wayne Suhrbier is offline   Reply With Quote
Old 08-31-2018, 01:33 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
That's a diode. It's there to allow current flow in only one direction, presumably to avoid some unwanted interaction. Probably alarm related.
Old 08-31-2018, 01:48 PM   #3
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
This is OEM, and it is to provide a voltage signal without allowing a current sink. There are a few of them located in the OEM harness.
Check out my AUTO I/C thread sticky in the Management forum if you want to see one of the OEM uses for these:
In this case above, pin L of the ECU is receiving a "AUTO spray active" low-side signal through the AUTO switch component when depressed. If pin L was a low-side pin, it would illuminate the light in the AUTO switch without the diode there any time the switch was depressed (even if the water tank was low). It would also sink current through the ECU pin which may exceed maximum allowable current through the internal ECU circuit.
mrsaturn7085 is offline   Reply With Quote
Old 09-02-2018, 01:42 PM   #4
Wayne Suhrbier
Member#: 144044
2006 STI
cool, thanks. I'll go ahead and put it back in.
Old 09-05-2018, 08:45 PM   #5
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
As an electronics engineer this is what's called an ESD protection diode. Usually to dissipate high voltage electrostatic discharge when touching the wires when air is dry so it does not fry the circuit.
jasonwrx86 is offline   Reply With Quote
Old 09-06-2018, 10:40 AM   #6
Wayne Suhrbier
Member#: 144044
2006 STI
"air is dry" that's a good one Alabama never has dry air. But seriously its good to know. I couldn't think of a reason to have a diode in the trunk light circuit.
Old 09-06-2018, 12:44 PM   #7
mrsaturn7085
Member#: 375462
WR Blue
Look at the diagram I posted - this is not for ESD protection... this prevents the ECU pin from sinking current and turning the indicator lamp on. This forms an integral part of making this circuit work and is not for ESD.
Old 09-06-2018, 01:04 PM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Cool
ESD/EMI, doubt it is either one. Taken from a field service guy/facilities guy for close to 40 years.
My normal issue is between engineers vs. field service.
