Welcome to the North American Subaru Impreza Owners Club Sunday December 9, 2018
Old 05-02-2017, 01:19 PM   #1
imprezarz
Member#: 423251
1995 impreza coupe
Red
Default Impreza ej22t swap need guidance
I have both complete cars
1992 legacy sedan ss 5 speed 22turbo
And 1995 impreza coupe automatic
I have read countless places i need to splice the 2 harnesses together in order for the wiring to be proper and other places say i dont need to splice the engine harness together.
I know i need to swap ecu turbo crossmember harness tranny lsd diff and drive shaft and rear hubs 4x disk brakes and the pedals and clutch setup
But cant get a definitive answer on the wiring harness bit
imprezarz is offline   Reply With Quote
Old 05-04-2017, 08:11 AM   #2
lemonline
Member#: 420931
1994 Impreza
Red
What engine came in that impreza? 1.6?
lemonline is offline   Reply With Quote
Old 05-06-2017, 06:13 PM   #3
lemonline
Member#: 420931
1994 Impreza
Red
Ej16?
Old 05-08-2017, 12:26 PM   #4
imprezarz
Member#: 423251
1995 impreza coupe
Red
Sorry impreza is a ej18 automatic
Old 05-09-2017, 02:10 PM   #5
lemonline
Member#: 420931
1994 Impreza
Red
The best way to do it is: download the ecu pinout of both engines. Install the ej22 with all its parts and sensors. Plug your existing wiring harness (ej18) to the new engine. Cut the wires at the ecu plug side and rewire them using the ecu pinout to fit the ej22 pinout. If any sensor wont plug, o is missing one wire, just add it following the ecu pinout. I did it in Ej16 with an ej22, ej18 should be much easy because the ej16 has almost no sensors
Old 05-10-2017, 02:32 AM   #6
suberdave
Member#: 101865
88 GL-10 STi
^ this is bad advise...
I have done many swaps:
EA82>EJ20G
EA82>EJ257
EA82>EJ22 N/A
EA82>EG33
EJ18>EJ207
EJ18>EJ20K
EJ253>EJ207
EJ252>EJ207
To name a few.
Dont try to use the EJ18 harness to run the EJ22t at all.
Strip down the EJ22t harness to what you need to run the engine, cut out the stuff like fans, ABS, A/C (if your not going to use it) youll keep that stuff from the existing car harness.
Use what is left, wire it into the car, and merge it into the existing harness to things like the Fans, Gauges, other sensors that are not on the engine...
If you dont have any idea what your doing, dont start a project like this. you will just end up with 2 cars that dont run. and are worthless. you'll end up selling them for pennies just to get them out of your yard.
Do lots of research. and spend time with wiring diagrams and manuals before you start.
if you need diagrams shoot me a PM ill get you what you need. i have done work with both of those engines before and have the diagrams and pinouts.
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 05-10-2017, 08:53 AM   #7
lemonline
Member#: 420931
1994 Impreza
Red
I have only done one, but it works Great and didn't have to take out the Dashboard, done it in a day, plus I left the original ecu plugs, so If want, I can put the ej16 back on, and just unplug the ecu and plug in the old ecu. No problems so far
Old 05-30-2017, 11:50 PM   #8
lifted_turbod_93
Member#: 468457
1993 legacy
dark blue
I am doing a ej22 -> ej20, and you will definitely need to merge the harnesses. If it is your first time handling wiring, then I would not start unless you have another form of transportation lined up. You would need both harness pinouts and trace the wires and merge all the necessary sensors, it will be very time consuming. I would do countless research and planning, make sure you have every sensor accounted for in your diagrams before you cut anything, and try to only splice in one wire at a time to avoid mistakes.
lifted_turbod_93 is offline   Reply With Quote
Old 06-22-2017, 04:36 PM   #9
cartwheels4amile
Member#: 190405
2002 Impreza WRX
But why would you kill a perfectly good 1992 Legacy SS? :[
cartwheels4amile is offline   Reply With Quote
