Welcome to the North American Subaru Impreza Owners Club Saturday September 21, 2019
Old 06-12-2019, 12:12 PM   #26
Masterauto
Member#: 198376
18 Alfa GiuliaTi S
LOTUS Esprit ES, ML TDI
Porsche should but this engine in the Boxter/Cayman and folks might forgive them for putting a 4 banger in an $80K car.
Masterauto is offline   Reply With Quote
Old 06-12-2019, 01:09 PM   #27
4S-TURBO
Member#: 67807
.... I do like fish
and grits and pimp ****
So buy the 911. Porsche doesnít mind. As for the 4 cylinder Boxster/Cayman performance, itís a corners car. If a 4 banger improves the balance without losing speed Iím all for it. Flat 4 must have some benefit if Porsche passed on developing the proven and cheaper EA888. As the 718 S sits, itís already a set of tires and strip away from being an 11 second car. For 80k you could do worse. The AMG motor would only make the price go up.
Old 06-12-2019, 04:13 PM   #28
heavyD
Member#: 194216
2018 M2 LCI
Iím not sure if putting a different 4-cylinder in the car would make folks forgive Porsche for putting a 4-cylinder engine in an $80k car. Itís not like the Porsche 2.0L is a slouch as it performs better than the outgoing H6.
heavyD is offline   Reply With Quote
Old 06-13-2019, 10:14 AM   #29
Masterauto
Member#: 198376
18 Alfa GiuliaTi S
It's no 6 either and sales have plummeted. Very different driving experience from 6 to 4 no matter how fast it goes.
Folks don't buy Porsche's for the C02 ratings
Old 06-13-2019, 10:42 AM   #30
heavyD
Member#: 194216
2018 M2 LCI
Sales have plummeted? Not sure where you are getting your sales numbers from as according to these links sales are at worst flat relative to the last decade.
http://carsalesbase.com/us-car-sales...orsche-cayman/
http://carsalesbase.com/us-car-sales...rsche-boxster/
If anything you can see that sales for both these models peaked about 15-20 years ago so you can argue sales plummeting is more the course of the segment and nothing to do with the 4-cylinder engine. Convertible sales have been in a perpetual industry decline so I'm not going to pin that on an engine change.
Old 08-19-2019, 03:28 PM   #31
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
I know this thread has been quiet for a while, but I just wanted to post because I recently watched Engineering Explained's video on the M139 engine.
I'm thoroughly impressed with the engineering that AMG has put into the new 416 hp 2.0L 4 cylinder turbo (M139) engine. They've really raised the bar for other manufacturers. The specific output (HP/L) is something that I would have expected from a Honda 4 cylinder (if they still manufactured engines like they did in the '90s/early 2000s). It's exciting to see engineering teams continue to push the envelope with combustion engines like this as the industry is advancing towards automated electric vehicles.
I'll be interested to see how far the aftermarket can push this engine, especially with E85.
New Mercedes-AMG four-cylinder turbo engine
  • Turbocharged 2.0L inline 4 - handbuilt at AMG
  • 416 hp @ 6750 rpm, 369 lb-ft @ 5000 RPM
  • Redline: 7200 rpm
  • Peak Boost: 30.5 psi
  • Displacement: 1991cc (83.0mm bore x 92.0mm stroke)
  • Compression: 9.0:1
  • Specific output: 208.9 HP/L
  • Engine weight: only 353.8 lbs
  • Twin scroll, roller bearing turbocharger w/ electronic wastegate actuator
  • Forged crankshaft, rods & pistons
  • Aluminum closed deck block
  • Nanoslide cylinder coating
  • Larger & baffled oil sump
  • DOHC 16 valve aluminum cylinder head
  • Adjustable intake and exhaust camshafts w/ roller cam followers
  • Camtronic valve timing on the exhaust side (2 camshaft profiles)
  • Larger, hollow-bored, sodium-filled exhaust valves
  • Dual injection - Direct & Port Injection
  • Electric water pump w/ 2 radiators
  • Air/water intercooler w/ additional cooling from the A/C
  • 8 speed dual-clutch auto
  • "Advanced" 4MATIC AWD system with a "Drift" mode
  • Estimated: 0-60 < 3.9 sec, 1/4 mile < 12.3 sec - depending on the "45" chassis
While not really in the same class as the STI, the AMG GLA 45 will likely be comparable in price to the S209 ($60-65k). Too bad it doesn't come with a manual transmission. And for those that love to "hoon", it comes with drift mode like the Focus RS.
The AMG A45 S with this engine reached 0-62mph in 3.9 seconds. The downside is that the exhaust doesn't sound as good on the new one.
A video of the "One Man, One Engine" assembly cart:
WRXnick16 is offline   Reply With Quote
Old 08-19-2019, 04:26 PM   #32
godfather2112
Papi Chulo
Member#: 53794
... 2017 BMW M2
2017 F-150
Stupid question but is this AWD or just rear wheel? Just went and built a current gen and with the options I want, it came to $70k. If that number were closer to $60-65k with those options I’d possibly be interested.
godfather2112 is offline   Reply With Quote
Old 08-19-2019, 05:30 PM   #33
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
Originally Posted by godfather2112 View Post
Stupid question but is this AWD or just rear wheel? Just went and built a current gen and with the options I want, it came to $70k. If that number were closer to $60-65k with those options Iíd possibly be interested.
The CLA 45 & GLA 45 have "4MATIC" AWD.
Old 08-25-2019, 06:48 AM   #34
vapore0n
Member#: 21356
2017 Subaru Corolla
STI Limited SE-R Type (R)
Walking around Tokyo, I saw a AMG A45 hatch.
God damn that is nice looking. Wish it would come to the US
vapore0n is offline   Reply With Quote
Old 08-25-2019, 09:49 AM   #35
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
The A35 and A45 are AWD.
But for the same price you could have a C8 that is superior to just about everything less than $125-150K. LOL
bdubblu is offline   Reply With Quote
Old 08-25-2019, 01:08 PM   #36
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
The C8 is a game changer for the price. There's no denying that. But it's not the answer to everything.
You're comparing an American mid-engine, RWD, V8, 2 seater sports car to a German AWD, turbo 4, 5 door hatchback? They're targeted at entirely different crowds. One is a great weekend, nice weather, track toy. The other is a more refined daily driver that's practical (fits your family, a car seat for your kid, your dog, groceries, etc.) and can drive in rain/snow. Too bad neither are offered with a manual transmission.
The M139 engine is handbuilt and, IMO, a game changer for the turbocharged 4 cylinder world. Yes, it's still a 4 cylinder.. they could just add more cylidners, but the engineering and HP/L is impressive nonetheless. I remember when the Honda Type R engines were once handbuilt and had the highest specific output for their time.. a lot has changed.
Type R K20C1: 306 hp/1996cc = 153.3 HP/L
AMG M139: 416 hp/1991cc = 208.9 HP/L
Old 08-26-2019, 01:48 AM   #37
Calamity Jesus
Member#: 44501
that 's, like, your
alternate facts, man.
2009 BMW S1000RR: 193hp/999cc = 193HP/L
2019 BMW S1000RR: 205hp/999cc = 205HP/L
2019 Kawasaki Ninja H2R: 300hp/998cc = 301HP/L (supercharged)
HP/L is a dumb metric in a nation that puts no limits on displacement... but this is not a game changer for anyone except people that actually like M-B's FWD-based (and part-time AWD) POSs.
Old 08-26-2019, 07:07 AM   #38
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
Youíre right on the point about the two cars being totally different categories. I was in my performance mode when I chimed in. Thinking everyone just wants to go fast.
But donít think Iím not impressed with the motor and tech. I own a MB and itís marvelous. I can only imagine how great the drivetrain runs and feels on this car.
That said... still not sure Iíd go for that at its price point.
One last thing: modern automatic transmissions built for sport like an amg would be, are far superior to any manual transmission. Youíd have paddles and the stick to select gears with in certain situations, but old school rowing... thatís a thing of the past. A slow thing of the past...
Old 08-26-2019, 01:21 PM   #39
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
Agreed on both the price point & extinction of the manual transmission. The manual transmission is slower regardless of how skilled of a driver you are.. even with fancy launch control & no-lift shifting. Just look at the difference in the 1/4 mile times for the manual vs auto Mustang GT. The stock 10 speed auto can break into the high 11s.
But I'm still not willing to sacrifice the more engaging driving experience that the manual transmission offers
Old 08-26-2019, 07:39 PM   #40
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
Iím ok with nostalgia as a motivation to have a manual. I love my manual wrx. It is engaging I agree. I just wonder about folks who try to support having a manual for any other reason. Maybe the cost/ ease of maintenance. All I know is Iíve been behind the wheel of some rockets... and I prefer to keep both hands on the wheel.
