Welcome to the North American Subaru Impreza Owners Club Thursday September 24, 2020
Old 06-28-2019, 01:15 AM   #1
BugeyeZo
Member#: 462089
Default Question about California smog and a built motor
Whatís up guys,
So Iím going to be putting in a forged 2.5 longblock into my bugeye with big turbo and everything that goes with that. The compression is normal. The heads are jdm big port heads with 264 Crawford cams and upgraded valvetrain, I did not get oversized valves.
My question is if I were to have that longblock and then swap all my exhaust and turbo etc. back to stock for smog and tune it for such occasion will I pass ? And yes I know the tgvs will have to be there for smog.
BugeyeZo is offline   Reply With Quote
Old 06-28-2019, 11:44 PM   #2
subaru_gc8
Member#: 29292
2004 WRX wagon
it should, as long as it is stock you shouldnt have too much problems getting it to pass.. the other question is what computer are you running?
Old 07-12-2019, 02:08 AM   #3
ItalianGuy
Member#: 60685
2005 WRB STi
371whp/368ft-lb on 91
If you swapped all the parts out to stock, the longblock would pass because Cali only cares about visual as long as there are no CELs, but what exactly is a "big" turbo?
Stock location with no visual branding? You're probably fine.
Rotated? No chance in hell.
At the same time if you're going to run a "big" turbo, you're probably going to run with a larger turbo inlet which will require a bigger intake which WILL be noticed.
So again, what exactly is a "big" turbo?
ItalianGuy is offline   Reply With Quote
Old 07-14-2019, 12:17 PM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
thats a lot of stuff to take off and ut back on every 2 years, you have to also remeber the tune will be off so the ecu or the tune will have to be removed as well. the other big problem is the cams and the heads will not be right for the stock tune. the other problem is according to a friend of mine thats a smog tech, when he went to a class to renew his license. the teacher told the class that the state is working on a way to check for tunes. so yeah its just getting harder and harder to get past all this stuff
Old 07-17-2019, 11:40 AM   #5
BugeyeZo
Member#: 462089
Thanks guys
Old 08-14-2019, 11:38 PM   #6
jesseisbeast
Member#: 465688
*cough cough* maybe you should or shouldn't *cough* find a sketchy smog shop who may or may not *cough* pass you for some extra cash *cough*
I DO NOT CONDONE ILLEGAL SMOG but I'm just saying it does happen, and it's probably cheaper and a LOT less work than de-modding/re-modding
jesseisbeast is offline   Reply With Quote
Old 08-27-2019, 06:17 PM   #7
jase858
Member#: 57041
2005 WRX STi
One of the crappy things (among many) living in CA, is that certain makes and models of vehicles that typically are "modded" must go to a STAR certified smog station, which means the shops are closely monitored and adhere to the CA BAR (Bureau of Automotive Repairs).
The last time I smogged my 05 STi, I failed several times. 1) because I didnt have the CARB sticker for COBB intake, and 2) for CEL which turned out to be because I kept my TurboXS downpipe and midpipe on. When I swapped the stock components back in, I passed.
When I failed for the CARB sticker, I thought for sure I would fail the visual for the aftermarket turbo (Blouch 18G), radiator (Mishimoto) and TGV Deletes, but I don't think the tech really was looking at those. I also thought (because my exhaust smelled rich) that I would fail after I put my stock exhaust back on, but nope...i passed.
I think as long as your stock exhaust components are on and your tune is factory, you should be fine. I bought a OBD II reader tho just to be on the safe side to ensure I cleared all my CELs.
jase858 is offline   Reply With Quote
Old 08-28-2019, 11:32 PM   #8
BugeyeZo
Member#: 462089
Thanks man much appreciated !
