Welcome to the North American Subaru Impreza Owners Club Wednesday September 23, 2020
Old 10-06-2014, 03:32 AM   #1
Ikkitousen
Member Sales Rating: (6)
Member#: 354304
2012 WRX
LR
Default $80 Megan H-Brace 08-14 WRX/STI
1st impression: the part looks decent, some metal shaving moving around inside the hollow tubes, but it felt sturdy enough for the job.
Installation/fitment issue: When I was installing it, the rear mount on the driver side (control arm to plate, large nut) would leave like a 1/16th inch clearance so I tried to readjust all 4 points and maybe it would sit flush. That didn't work so I saw the reason it was leaving a gap was the bar's mounting point was welding like 1mm too far out, thus hitting the lip on the plate.
So I took out the dremel and basically shaved off the surrounding of the mounting point a bit, and eventually I was able to tie it up and get it flushed.
For $80 I didn't really mind, but it's lame when you get a part that just doesn't fit from the factory.
Ikkitousen is offline   Reply With Quote
