Welcome to the North American Subaru Impreza Owners Club Monday September 23, 2019
Old 12-09-2008, 06:42 PM   #26
maramaralula
Member Sales Rating: (13)
Member#: 96050
2005 EP Hatch Rrraw!
World Rally Blue
there you go the h-brace installed!
it even works with JDM tranny undertray
maramaralula is offline   Reply With Quote
Old 12-10-2008, 10:52 PM   #27
DOHC_Holiday
Member Sales Rating: (5)
Member#: 82006
1999 Forester
"Black-13"
Is that a 2-point or a 4-point brace?
DOHC_Holiday is offline   Reply With Quote
Old 12-12-2008, 01:02 PM   #28
maramaralula
Member#: 96050
World Rally Blue
4-point brace
Old 12-12-2008, 02:17 PM   #29
illmatic
Member Sales Rating: (38)
Member#: 3536
2017 SWP BRZ PP, FXT
2002/2003 AW/PSM WRX
Will this fit an 08 FXT?
illmatic is offline   Reply With Quote
Old 12-17-2008, 04:40 PM   #30
justincredible
Member#: 83633
2012 bright green
box
Originally Posted by Tahoe SC View Post
will this work with a skid plate?
I would like to know this as well.
justincredible is offline   Reply With Quote
Old 12-18-2008, 01:43 PM   #31
Vtwrx04
Member Sales Rating: (8)
Member#: 97147
2012 wrx
gray
I just installed mine on my 04 sedan with ALK. Took maybe 20 minutes. Helps that I have a lift and a good impact driver. Maybe its psychological, but it does seem to tie the front of the car together. Hell, for $11.90 I had nothing to lose. Of course the shipping was $16, but still ,only $28 total for an easy install.
Vtwrx04 is offline   Reply With Quote
Old 12-20-2008, 09:25 AM   #32
subiebui
Member Sales Rating: (24)
Member#: 120839
2017 STi
has anyone had these break on them>
subiebui is offline   Reply With Quote
Old 12-21-2008, 02:51 PM   #33
maramaralula
Member#: 96050
World Rally Blue
have it for nearly 3 months, tracked once, still intact!!
Old 12-24-2008, 01:30 PM   #34
subiebui
Member#: 120839
2017 STi
i would hope it could hold up 3 months and one track day
Old 02-21-2009, 02:34 PM   #35
scooby_wooby
Member Sales Rating: (32)
Member#: 79653
2005 LGT
anyone bought this h-brace from this seller?
I'm thinking of getting it..
http://cgi.ebay.com/ebaymotors/ws/eB...3592&viewitem=
scooby_wooby is offline   Reply With Quote
Old 02-22-2009, 03:01 PM   #36
p01ntb1ank
Member#: 134299
what size bolts do u have to buy?
p01ntb1ank is offline   Reply With Quote
Old 02-22-2009, 04:14 PM   #37
xjustinx
Member Sales Rating: (4)
Member#: 196920
03 Wrx
Has anyone ever compared one of these cheap-o ones next to a Megan one?
xjustinx is offline   Reply With Quote
Old 03-12-2009, 04:58 PM   #38
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
In 4 1.
Jerry Xu is offline   Reply With Quote
Old 03-12-2009, 06:41 PM   #39
Rexwagon03
Member Sales Rating: (12)
Member#: 127429
2006 Legacy GT Limit
it goes where the Oem bolts are. you dont need to buy bolts.
Rexwagon03 is offline   Reply With Quote
Old 03-12-2009, 07:55 PM   #40
Imprezed04
Member#: 202396
2004 STi
they also sell a set (front and back) strut bars for about 38.00+ shipping. I bought them, and the install took about an hour, had a small issue with the rear brace lol. But this is an awesome kit, its all aluminum, and welded nicely. I'd recommend these to anyone.
Imprezed04 is offline   Reply With Quote
Old 03-14-2009, 11:24 PM   #41
p01ntb1ank
Member#: 134299
thanks for the response. what are bolts doing on a non existent h brace?
Old 03-15-2009, 12:41 AM   #42
bewarethebear
Member Sales Rating: (11)
Member#: 167825
2005 STi
Cgm
it ties existing points on the car, already bolted, together...
bewarethebear is offline   Reply With Quote
Old 03-15-2009, 01:26 AM   #43
p01ntb1ank
Member#: 134299
sorry, i didn't look at this part of the car
Old 03-15-2009, 08:50 AM   #44
xrw1
Member#: 159772
06 WRX
obp
i bought one of these a few weeks ago and tired to install it. There was a slight fitment problem that led to crossthreading of the 40 ft lb bolt in front. Yeah it was a bit** to take off the cross threaded bolt, but i'm going to enlarge the H brace holes slightly and try again next week.
xrw1 is offline   Reply With Quote
Old 03-22-2009, 10:29 PM   #45
jacky599r
Member Sales Rating: (2)
Member#: 137631
2006 WRX
Red
will this fit if i have a whiteline race ALK.
jacky599r is offline   Reply With Quote
Old 03-27-2009, 02:32 PM   #46
07VTRex
Member Sales Rating: (33)
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
I want to know the answer to this.
I have a whiteline ALK, and when tightening the h brace back down after install i broke the rear welds on the h brace. For the record the torque wrench had not clicked at the 184 ft-lb mark, beacuse the brace broke BEFORE it reached proper torque spec. I was tired for one day and just let it be, but this was a mistake. From day to day my suspension started making mroe and more noise. I figured it was the brace being broke so i decided to replace it. SO i bought another one, this time the SPT one, instead of the crappy ebay one on there before.
SO here i am trying to install the SPT h brace on my wrx w/ Whiteline ALK. Tons of people say they fit but IT CLEARLY DOES NOT FIT. u have to be frigging retarded to say that it does... If you line up the brace flush with the front 2 holes/bolts (subframe holes), you will notice the rear 2 holes/bolts (control arm bracket holes) are about A GOOD INCH SHORT of lining up flush. This is due to the "dropping of the subframe about an inch, beacuse of the provided spacers with the ALK install. SO...what to do?
Well i decided that spacers would require a longer bolts and i had neither of these, so i thought i would try and just bolt it up anyway, stretching the brace to make it fit. I decided since i broke the last brace by doing the fornt 2 bolts first(subframe), i decided to start at the rear(control arm) and bolt the rear 2 first, then get the front two. I ended up tightening the rear two bolts as much as i possibly could with a breaker bar (still prob not the 184 ft-lb req) and the brace was deformed to the point that it was now almost flush with the mounts, BUT THE MOUNTS HAD A GAP BETWEEN THE MOUNTS AND THE CHASSIS. I bolted everything tight as i could get it w/ front two bolts torqued to spec, and went for a drive. So far so good, but a few days later, well...the creaking and noise of stressed and deformed metallic sounds came back. *Sigh*
1 week after driving the suspension is starting to squeak i directly beleive this is responsible for the poor h brace fitment with ALK.
I have searched everywhere for answers to this prob only to find NOTHING. Why do people say that this brace fits when it does NOT. other people say spacers are required, but noone has any pictures to confirm this, or show the method that they found succesfull.
I really do not want to give up this brace because i have an ALK. How can i make it fit will someone please help?
07VTRex is online now   Reply With Quote
Old 03-29-2009, 12:47 AM   #47
Jerry Xu
Member#: 36629
07 2.5i
Old 03-29-2009, 08:47 AM   #48
scooby_wooby
Member#: 79653
2005 LGT
I've had mine for over 3k miles. Drove it back from Va. Beach to Jacksonville and back and had no issues. No squeaking or any noises. Ensure to retigten bolts after 100 mile (just to make sure you don't have any loose bolts). I had some issues fitting the ebay h-brace because one of the holes was off by a 1 or 2 mm. All it took was some muscle and ensureing that all the holes line up and the bolts were fitted before tightning all the bolts. Also, I didn't have to redrill any holes. I guess it just depends on the brace you get. Not all h-braces comes perfect. I don't have ALK so I don't know if it works well with it or not.
Overall, I was happy with the item. Welds were good, not too much of an issue installing it, cheap and there's a noticeable difference when you steer the car. It feels more planted.
Old 03-30-2009, 01:51 PM   #49
Mike37
Member Sales Rating: (1)
Member#: 135480
2007 Impreza WRX
Satin White
I just received the h-brace along with the front and rear strut braces for a total of around $75 shipped. The front and rear bars are installed and I'm waiting on a lift to throw the h-brace on along with a couple other things I have sitting around. The quality of all the parts was pretty decent for what I paid.
Mike37 is offline   Reply With Quote
Old 03-31-2009, 01:34 PM   #50
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
i dont need pictures of the h brace...i need pictures OF THE PROPER SOLUTION TO FITTING AN H BRACE WITH AN ALK INSTALLED
wrx cusco front strut bar, ebay strut bar and new ebay H brace ubi_scoobi SCIC Private Classifieds 12 07-26-2009 12:19 AM
FS:(socal) wrx 02-07 cusco front strut bar, ebay rear strut bar & new ebay H brace ubi_scoobi Suspension/Brakes/Handling 1 07-23-2009 03:27 AM
PS3 Playstation 3 - In hands ready to ship. 60gig Free Shipping, Ebay 2ndGearFling Non-Subaru Stuff 1 11-17-2006 09:38 AM
Ebay H-brace? 2000wrx Brakes, Steering & Suspension 19 08-11-2006 02:35 PM
Cusco lower arm brace VS ebay H brace? realwomble Brakes, Steering & Suspension 11 05-29-2005 07:01 PM
