Welcome to the North American Subaru Impreza Owners Club Friday September 20, 2019
Go Back   NASIOC > NASIOC Reviews > Car Part Reviews
Old 05-02-2014, 10:56 AM   #1
joek92
Member Sales Rating: (5)
Member#: 353938
2007 STI WRB
18x8.75 +35 225/40
Default Mishimoto TMIC 02-07 WRX/STi
I downsized my turbo but kept my FMIC, which was too big and laggy. So I was looking for top mounts and ran across this thread http://forums.nasioc.com/forums/show....php?t=2596082 which pretty much sealed the deal.
Pros:
Cooler than STi TMIC (I'll be monitoring ait's)
About the same price
Installation (clears ac lines etc.)
Cons:
Can't really think of any substantial ones yet other than looks... that's just opinion because I'm biased towards oem look. Really it looks great. I'd prefer plain or polished aluminum finish over silver paint though.
It delivered yesterday. Nice big box.
I hope to make peak 500 rpm sooner with the TMIC vs FMIC. And I want instant boost recovery between shifts. Yes I know it's an AP dyno but all I'm using it for is variance in peak tq rpm. After the tune I'll get another dyno in the same spot. Boost recovery I'll use my butt dyno
The install is super easy. LUBE THE COMPRESSOR OUTLET ON THE TURBO! The silicon hose will thank you.
More pics and inf coming.
*Note regarding intake temps* My FMIC piping ran directly underneath my short ram intake filter. It got pretty hot. Even when I ghetto fab'd an AVO cold air box + oem snorkel my temps would hit 130. Now the cold air box has a better seal and no hot IC pipes nearby.
joek92 is offline   Reply With Quote
Old 05-04-2014, 09:06 AM   #2
Dakota D
Member Sales Rating: (10)
Member#: 293894
2011 wrx sti
world rally blue
pics appear to be broken
Dakota D is offline   Reply With Quote
Old 07-30-2014, 03:12 PM   #3
toogood131
Member Sales Rating: (8)
Member#: 271731
Chapter/Region: HIIC
2002 WRX Sedan
aspen white
Here's a pic of mine installed. I would recommend it, installation is much easier than a y pipe set up. Gonna get my car dyno'd in a couple weeks, no base numbers though.
toogood131 is offline   Reply With Quote
Old 08-08-2014, 04:20 PM   #4
Mishimoto
Vendor Sales Rating: (-1)
Member#: 207954
Looks fantastic! Thanks for posting this up.
__________________
Mishimoto Automotive
Mishimoto is offline   Reply With Quote
Old 08-21-2014, 09:51 AM   #5
joek92
Member#: 353938
2007 STI WRB
18x8.75 +35 225/40
I've been driving with this IC for a few months. Noticeable reduction in lag, however still too much between shifts. My only other options now are a 04/05 trans with shorter 2-4 and/or 7cm hotside. ... or Methanol
Old 10-09-2014, 02:06 AM   #6
funks
Member#: 69054
2012 Imp WRX STI
Or a Ball Bearing Turbo - transient boost response is pimp.
funks is offline   Reply With Quote
Old 10-09-2014, 09:26 AM   #7
joek92
Member#: 353938
2007 STI WRB
18x8.75 +35 225/40
Does that mean in terms of transient response that a 16gxtr = VF39?
3rd and 4th are still freaking long.
Old 03-11-2015, 11:36 AM   #8
joek92
Member#: 353938
2007 STI WRB
18x8.75 +35 225/40
Grimmspeed top mount splitter fits ok with this intercooler. However, I haven't installed the rubber strip yet.
Saikou Mishi strut tower mount catch cans will not fit in the intended location. I just rotated the bracket 90 degrees and used one bolt.
Old 07-10-2016, 06:44 AM   #9
Rzn8
Member#: 442620
Good to know. Was wondering if any aftermarket splitters matched up and if there was room for an aos/catch
Rzn8 is offline   Reply With Quote
Old 07-10-2016, 07:11 AM   #10
joek92
Member#: 353938
2007 STI WRB
18x8.75 +35 225/40
The gs splitter has worn a small groove in near the ic inlet. I should trim it back with a grinder it would be super easy.
I did install the rubber seal. Just had to bend the splitter flaps out a few degrees for more clearance. It sits slightly higher than stock.
Old 08-02-2018, 10:59 PM   #11
07limitedguy
Member#: 488928
07 STi limited
Satin white pearl
I know this was a long time ago but, do you remember the outcome of the dyno tune?
07limitedguy is offline   Reply With Quote
Old 08-16-2018, 12:35 AM   #12
savoelh
Member#: 471209
Looks good
savoelh is offline   Reply With Quote
