Welcome to the North American Subaru Impreza Owners Club Monday September 23, 2019
Old 08-05-2019, 09:06 PM   #1
Evoballer
Member#: 436019
2018 STi RA #406-500
Peral White
Default NEED HELP ASAP! C-Clip POPPED LOOSE.. WHERE FROM?? On 2018 STi
PLEASE HELP!!!
While doing a Header/ Up-pipe installed today on my 2018 STi. An I had a
C-Clip pop loose but I canít identify where itís from? ... I had the engine slightly jacked up following the Up-pipe instructions and when I lowered the engine this C-clip popped loose from the driver Side but Iím not quite sure where it sprung a loose from? My first thoughts where a bushing or control arm but Iím having trouble locating were. Can someone please help me identify where and from what the clip came loose from. If anyone at all can identify where this clip belongs I would really appreciate the help!!!!
https://imgur.com/gallery/0sv6UOb[/IMG]
Evoballer is offline   Reply With Quote
Old 08-07-2019, 09:32 AM   #2
Evoballer
Member#: 436019
Peral White
Please Need Some Help, Anyone
Old 08-07-2019, 05:36 PM   #3
T-37
Member#: 175624
0304 WRX WRX
SY WRB
I would suspect maybe the steering rack input shaft possibly
Are you sure it didn't come off of the jack? maybe the wheel on that side?
T-37 is offline   Reply With Quote
Old 08-10-2019, 07:36 AM   #4
Evoballer
Member#: 436019
Peral White
I will Dbl. Check the jack but I don't think so.
Where located on the St. Rack are you thinking possible location from where it could of popped form?
I'm thinking your first thought is a very good possibility, due to i was under the car when it sprung loose and that area was my first thought of a possibility!
Old 08-10-2019, 07:47 AM   #5
Evoballer
Member#: 436019
Peral White
Maybe HERE?
Old 08-12-2019, 03:52 AM   #6
Evoballer
Member#: 436019
Peral White
So if anyone has any other suggestions on where this Retainting Ring Clip goes please tell me . I've looked, Looked & Looked through the STI service manual and I can't find where it should be located. All of the clips on the steering rack are enclosed inside CV Boots ECT. and there is no way those could have popped loose with out some disassembly of the Steering Rack. PLEASE ANYONE! I NEED ur HELP!!
Old 08-12-2019, 10:32 PM   #7
subaru_gc8
Member#: 29292
2004 WRX wagon
so just me, I would put the car up on a lift, start taking stuff and shaking it to see if anything is going to wiggle its way out, of not eh Id put it in the glove compartment and see if anything happens... but that just me
subaru_gc8 is offline   Reply With Quote
Old 08-13-2019, 08:20 PM   #8
Evoballer
Member#: 436019
Peral White
So I did a thero examination of the undercarriage wile completing my Up-Pipe/Exst.Manifold install. Since it was already up off the ground. But I did not perform the "Wiggle-Wiggle,Stroke,Shake Test at that time. So o will go do that right now. . . . I did take the car on a decent test drive and I did not hear or feel anything unnatural more so than normal. But I will report my findings fallowing my "Wiggle-Wiggle,Stroke,ShakeShake"Test.
BTW. Thank-You for Your Response!
