Welcome to the North American Subaru Impreza Owners Club Thursday July 19, 2018
Old 07-08-2018, 10:53 PM   #1976
gti_speed
Member#: 483443
2016 WRX STI
Ice Silver
Originally Posted by Zefy View Post
Just for fun question, if you remove the subframe spacers from a forester like you've done, does that move you out of sm? Does that not mean you're relocating suspension pickup points?
I would say it falls under 16.0
O. Any minor modification, intended to allow or facilitate any allowed modification, is permitted as long as it does not provide any intrinsic performance benefit in and of itself, does not provide a weight reduction of more than 1.0 lb., and is not explicitly prohibited elsewhere within these rules.
This rule is intended to allow minor notching, bending, clearancing, grinding; the drilling of holes; affixing, relocating, or strengthening of brackets; removal of small parts, and similar operations performed in order
to facilitate the installation of allowed parts or modifications. Minor strengthening, without relocation, of original chassis/suspension pickup points is allowed. Examples include welding washers restricting control arm mounting bolt movement, local reinforcement of control arm chassis mounts, etc.
Competitors are strongly cautioned to make the minimum amount of modification required to affix a given part and to not make unduly tortured interpretations of this rule. Modifications to the firewall in order to allow for increased engine setback, and any modification that changes the location of a suspension pickup point, are explicitly forbidden. Plastic under-trays and covers below the vehicle may be removed or modified as necessary to facilitate other compliant modifications, but not added or enlarged.
gti_speed is offline   Reply With Quote
Old 07-09-2018, 12:21 AM   #1977
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Front subframes are open provided the pick up point doesn't move. Removing spacers would move the location for the suspension pick up points. However, we're talking about a Forester here so no one is going to actually protest you.
I'd guess the lack of camber is something got missed/flipped/moved during the arm install that caused it. A bend in an arm big enough to make that sort of change would be visible while eyeballing it.
Keeping the inside rear on the ground is usually not the fastest way to make a Subaru go around corners in AutoX when you have aftermarket diffs. On anything resembling a gear type rear diff and rules that don't allow a change, then keeping the rear on the ground is faster to a point.
subydude is online now   Reply With Quote
Old 07-09-2018, 01:16 PM   #1978
T-37
Member#: 175624
0304 WRX WRX
SY WRB
Originally Posted by motorbykemike View Post
yep , got one just like it
So helpful
The suretrac isn't adjustable is it? I thought the suretrac was a cam/pawl design and they switched to the torsen in the 05+ cars for increased longevity. It certainly wouldn't be as easy as a plated diff, I guess
T-37 is online now   Reply With Quote
Old 07-12-2018, 08:08 PM   #1979
Xian_1
Member#: 97029
I went down the “keep the inside rear on the ground” rabbit hole on my STU car. Ultimately got it to be pretty decent like that but I don’t know that it was any faster than it was when it was picking the inside rear up. Yeah, it didn’t hop and do funky stuff on corner exit but it was compromised in other ways (wasn’t quite as good transitionally). If I was doing it again, I’d put a diff in the rear and run a different class.
Xian_1 is offline   Reply With Quote
Old Today, 12:56 AM   #1980
gti_speed
Member#: 483443
2016 WRX STI
Ice Silver
Well that escalated quickly...
Old Today, 09:35 AM   #1981
subydude
Member#: 80649
Which turbo?
Old Today, 01:47 PM   #1982
gti_speed
Member#: 483443
2016 WRX STI
Ice Silver
Can't say yet... Also only have a few miles on it and was stuck in traffic and cars were approaching way too quickly. The speed is blinding and I still need to wrap my head around it.
All I can remember is it felt a touch laggy and then boom you get punched in the nuts with torque and then it just pulls and pulls and pulls.
Old Today, 01:56 PM   #1983
subydude
Member#: 80649
Sounds like every garrett based turbo out there (blouch line, 20g, etc).
I laughed at the can't say part.
Now imagine an extra 100 wtq 1,000 rpm sooner (if you had an EFR)
Old Today, 04:06 PM   #1984
gti_speed
Member#: 483443
2016 WRX STI
Ice Silver
With the 7163? That sounds like crazy talk lol!!!
It's literally not on the market anywhere yet. Still waiting on the go ahead to release info.
Old Today, 05:03 PM   #1985
subydude
Member#: 80649
On the new setup I could do more if I used a 7163. Think well over 500 wtq for that turbo. The old setup is a single scroll 6758 and produced the numbers I quoted.
But yeah, that curve looks like a LOT of other turbos I've seen. I'm not poopooing it, just saying it's nothing new, especially on a DAVCS car.
Will my trans swap put me automatically in Street Mod? RebelINS Autocross 6 07-22-2013 05:24 PM
I'm still legal for Street Mod right?(list inside) Davenow Motorsports 4 05-24-2003 03:21 AM
street mod tire question Jaxx Motorsports 2 02-20-2003 07:59 PM
Autocross class... Street Mod? Motohead1 South East Region Forum 11 06-26-2001 10:11 AM
Street Mod news Eric Technical Forum Archive 5 05-31-2000 02:33 PM
