01-03-2007, 08:42 AM | #1 |
Member#: 136488
Building a 2.2 Stroker
Ok everyone heres the deal I just took my 2.0 outta my 02 wrx I want to make it a stroker does anyone out there have any good Ideas for me to get the max horsepower outta the 2.0 block. Any advice you can give me would be greatly apperciated. I have a very unique Scooby and want to make it fast so hit me with whatever you got and if you need any info just ask.
Thanks everyone
01-03-2007, 10:24 PM | #2 |
Member#: 63926
Vehicle:Axis /RAW 2.2 Closed deck EJ 20G stroker |
don't.
it will still be open deck, and that limits your ultimate power before failure. you want unique? try a stroked EJ20G. that would be a closed deck 2.0L, that i've stroked out to 2.2L. it also has piston oil squirters. it's pretty unique, there might be ten motors like mine in the country. get a 2.5 STi short block, get a decent machine shop to put in a set of Weisco pistons, port your heads, get cams, and engine management. other than that.... SEARCH |
01-03-2007, 10:52 PM | #3 |
Member#: 29201
NESIC
Vehicle:BMW M3 Honda S2000x2 |
As a great JDM tuner once said "***12479;***12540;***12508;***22311;***21147;***12395;***31478;***20105;***19978;***12398;***21147;***12381;***12375;***12390;***36895;***24230;***12364;***12354;***12427;." Loosely translated it means "Turbo pressure will have power and speed over the competition." His advice is great, and its true.
01-04-2007, 03:29 AM | #4 |
Member#: 120482
You could get your open deck EJ20 block sleeved and bored for 2.2L then stroke it with a STi crank and get 2.35L. Or like suggested above get closed deck 2.0L block and bore out. Your third option is get a EJ22 block (already 2.2L) and if you want stroke it upto 2.35L.
Plenty of options and s/h blocks from other motors are cheap and worth considering and the 2.5L short block is probably the best bang for buck. |
01-04-2007, 11:38 AM | #5 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
I have an EJ257 crank if you want to stroke it out.
Also you will want to punch it out some too. Bore to 92.5mm and stroke to 79mm and you will have 2123.5cc 96.5mmx79mm you get 2311.2 cc |
01-07-2007, 03:39 PM | #6 |
Member#: 111368
homemade wrx,
How much do you want for the 2.5 crank? is it phase 1 or 2? I'm building a ej22 closed deck block and would like to strok it with a 2.5 crank but have gotten conflicting advice as to which crank will work. Any thoughts... anyone? |
01-07-2007, 06:11 PM | #7 |
Member#: 79798
An EJ22T will need a phase 1 EJ25 NA crank as both motors are phase one. The STI crank can be fitted with some machining to the block. Its a difference of main bearing placement IIRC. It'd be just as good to get the NON-EJ257 crank and just get some kick butt bearings. New NA EJ25 cranks like two fiddy ish at the dealership.
cheers garrett |
01-07-2007, 06:30 PM | #8 |
Member#: 111368
Thanks for the info. Anybody know the part number for the NA 2.5 crank or what models and years they came in?
01-07-2007, 06:32 PM | #9 |
Member#: 111368
What rods should I use with the NA 2.5 crank going into a EJ22T
01-07-2007, 06:55 PM | #10 |
Member#: 29201
NESIC
01-08-2007, 12:03 AM | #11 |
Member#: 79798
I think even the pre 98 legacy motors with the EJ25 would work. I think.
cheers garrett |
01-14-2007, 07:13 PM | #12 |
Member#: 94807
NESIC
Vehicle:'98 impreza RS RBP |
'97 and '98 EJ25 have the phase 1 crank.
subaru quoted me $375 for a new one. |
01-21-2007, 05:59 AM | #13 |
Member#: 94903
Vehicle:1996 Impreza Wagon! Satin Black |
I have en ej25 phase I crank if anyone needs one.
01-21-2007, 03:42 PM | #14 |
Member#: 79175
South East
Vehicle:2004 FXT Red |
01-21-2007, 03:46 PM | #15 |
Member#: 102150
SCIC
Vehicle:10 WRX STi DMG |
i have a 92.5mm Arias forged pistons and an ej25 phase I crank brand new if anyone needs it. the only thing you need to complete is some standra size 2.5L connecting rods.
01-21-2007, 05:49 PM | #16 |
Member#: 106823
NESIC
Vehicle:2000 v8 rsti |
i have a ej20g closed deck shortblock if you want to use that as your platform instead of the open deck.
My 2.1 Stroker Build | NITROS | Built Motor Discussion | 605 | 08-12-2020 02:00 AM |
My 2.1 Stroker build with part numbers so you can do it too! | DSM Nexus | Built Motor Discussion | 79 | 10-06-2011 12:19 AM |
Iheartmysuby's ej20 2.2 stroker build | iheartmysuby | Built Motor Discussion | 24 | 04-12-2011 02:32 AM |
My 2.71L stroker build | z38er | Built Motor Discussion | 9 | 09-12-2009 01:41 PM |
next build 2.3 stroker | TurboJunkie85 | Rocky Mountains Impreza Club Forum -- RMIC | 4 | 12-09-2008 11:36 AM |
