08-08-2004, 07:42 PM | #1 |
Member#: 2216
Vehicle:0000 Gee See dented |
Need help re. gear grinding since trans./diff. fluid change, info please!
OK after reading a lot of search results, I suspect synchro problems, but unsure how much will this cost me (no warranty!), and how long (hours/days?) will it take to fix, and where to go (dealership, specialty shop?). I've been so busy with work and haven't had a chance to attend to my ride ever since the South Coast Subaru party. My car is 2000 2.5RS Impreza with 74,XXX miles. Any input is appreciated. Please see details below.....
It has been one week since I had tranny and differential fluid change at a local Subaru dealership. The 2000 2.5RS has been driving fine and shifting normally until after I had the fluid change. Ever since then, ALMOST every time I shift from Neutral to 1st on a dead stop, it kinda jerks the lever and clunks. Also, from 3rd to 4th gear transition at 4k rpm it slips and grinds often. Again, these problems started shortly after my gear oil change. Is this a coincidence, or did the fluids change have something to do with my shifting problems? ALSO by the way, my car is 74,XXX miles old, so the clutch still feels normal but unsure if it is wearing out, based on my symptoms. I no longer have warranty, so if something major needs to be done, I'm concerned about the costs...I'm still a starving student. Let me know if you know, please. Thanks! --Long
08-08-2004, 08:14 PM | #2 |
Member#: 7321
NESIC
Vehicle:.... 122 IggPoints Work... ahhh... so tired. |
Did you talk to the shop that did the fluid? Have you looked to see if there is even fluid in there? Replacing the syncros is not cheap or easy... It would be easyer to find another used 5 speed and just swap that in places of yours. If yours is realy done for.
08-08-2004, 08:25 PM | #3 |
Member#: 2692
TXIC
I pm'd you some tips and info just incase you need it.
08-08-2004, 09:21 PM | #4 |
Member#: 64981
Vehicle:---> my shift key doesnt work |
i have an 03 wrx tranny if they are the same
08-08-2004, 09:21 PM | #5 | |
Member#: 10644
International
Vehicle:2001 impreza Blue Ridge Pearl |
Share the tips with the rest of us Kian My car has always made noises ever since I went to redline shock proof. Dead stop, put it into first *cluck* noise. Only time I hear it and it's random too. |
08-08-2004, 09:24 PM | #6 |
Member#: 2692
TXIC
I PM'd him to adjust his clutch pedal higher off the floor to see if it is really releasing all the way
and to try Redline MTL other then that I offered my services to remove the tranny should it need a rebuild Gotta work while Im in college somehow! |
08-09-2004, 01:20 AM | #7 |
Member#: 32955
SCIC
Vehicle:'03 WRX Wagon '89 3S-GTE Alltrac Camry |
Did you have them put in anything but the correct stock tranny fluid? If its not stock fluid and you are having grinding noises, switch back to stock immediatly and you might be able to get the problem to go away (mostly). Do not let it grind or wear the synchros for very long or you will need a new/rebuilt tranny. Good luck.
-Charlie |
08-09-2004, 01:53 AM | #8 |
Member#: 2216
Thanks guys for the feedback. Thanks Kian for your offer to help, I'll keep in mind. I haven't had a chance to go under and look at my car since, but as far as I know, the dealership used whatever stock fluids they normally would use in a tranny & diff. fluid change service. Didn't get anything else done on the car lately either. If there's any more info y'all can give me, please let me know. It's been a pain in recent months...spending $$$ I don't make on replacing my bumper and all brake rotors and pads from wear and tear driving on side streets to an unpaid internship.
08-09-2004, 03:42 PM | #9 | |
Member#: 20768
Vehicle:2020 WRX Silver |
Best advice is to check your tranny fluid. Do you have any. If not, GO BACK TO THE STEALERSHIP SERVICE DAPARTMENT. If you do, bring it back anyway, and tell them what is goin on. I say if all was fine before, and after your fluid were done at the Dealership it aint all fine, they effed something up. Michael |
08-09-2004, 05:21 PM | #10 | |
Member#: 44945
SCIC
Vehicle:06 LGT wag silver |
STi Trans. & Diff. Fluid Change | i_drank_what | Service & Maintenance | 84 | 04-07-2020 01:48 PM |
Getting ready for trans and rear diff fluid change, need recommendations | BGPKR | Transmission (AT/MT) & Driveline | 8 | 03-11-2008 02:29 AM |
99 OBS high mileage tran/diff fluid change | mtntrekker30 | Transmission (AT/MT) & Driveline | 0 | 10-07-2007 08:17 PM |
Need some help with rear diff fluid change | Blazin | New England Impreza Club Forum -- NESIC | 17 | 07-17-2006 02:54 PM |
weird sound after trans and rear diff fluid change | IIdiceII | Service & Maintenance | 1 | 07-16-2006 05:38 PM |
